ppfilbert
Reged: 02/03/11
Economical refractor
      #5612800 - 01/08/13 10:06 PM
Well My OLD C8 is close to dead. images through it are awful even after collimnation. Im buying a 300MM APO camera lens for piggyback but i want a New Refractor. Sadly i know very little about refractors, all i have ever had is an SCT, but many imagers tell me i NEED a refractor. thing is there are SOOO many types models Doublets, triplets ACHRO APO ED ect, jeesh.
So heres where im at i might be able to swing 1000$, but likely 700$ or so, prefer less honestly. im imaging with my camera so clarity is needed. i only need an OTA, i have a good CG5-gt. so As CN has always been good on advice , i REALLY could use some advice and Intel on what i might think of buying. an ES 102 Achro is 399$ but is it worth it, or good enough. or do i need to step up to a 899# triplet APO.
Thanks in advanc efor any intel or help.
dlpville
Reged: 07/09/07
Re: Economical refractor new [Re: ppfilbert]
      #5612850 - 01/08/13 10:45 PM
The issue with using an achro is that chromatic aberration rears it's ugly head as a noticeable difference in image size depending on wavelength; this is what causes the color fringing in achros. The objective size of an apo isn't a deal killer, because you can shoot more exposures and stack them.
Best advice I've seen is go ahead and find an apo that fits your budget, even used ones will give you results that you'll be proud to display.
ppfilbert
Reged: 02/03/11
Re: Economical refractor new [Re: dlpville]
      #5613518 - 01/09/13 11:16 AM
ok looking about i find the Sky-watcher pro 100MM apo for 749$. perfect in my range. But how would it be Unguided on a CG5-gt?this is a HUGE amount of Money for me, i pretty much get the chance to spen like this Once a year (income tax) and this will be all my money available. i just dont want to make a mistake
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5613528 - 01/09/13 11:25 AM
A good choice would be either the Orion ED80 or the Skywatcher version. FPL-53 glass and a proven AP scope. You'd need a field flattener and the Orion version works well with it. For versatility, the Orion 0.8x reducer works too and gives 480mm at f/6.
rflinn68
Reged: 03/09/12
Loc: Arkansas
Re: Economical refractor new [Re: terry59]
      #5613631 - 01/09/13 12:25 PM
I really like my AT65EDQ. It cost $599 brand new and has a built-in field flattener. I think everyone is sold out of them again but I see them a lot used for even less money. It is a 420mm focal length scope at f/6.5 and has the FPL-53 element. Lots of good photos out there that were taken with this scope. It even comes with a dovetail and some really nice mounting rings.
rflinn68
Reged: 03/09/12
Loc: Arkansas
Re: Economical refractor new [Re: rflinn68]
      #5613636 - 01/09/13 12:28 PM
This looks like a really good deal as well!
ppfilbert
Reged: 02/03/11
      #5613695 - 01/09/13 01:02 PM
It indeed does, sadly im in Prep stage, Funds become available when Income tax come back, bout feb 14. so got a month. you honestly think im better off going Used rather than New, im Just very nervous about buying used unseen even from here, though i have a much better feel here. i know i can prolly get about 1.5 times the scope used, just scares me
ppfilbert
Reged: 02/03/11
      #5613799 - 01/09/13 02:14 PM
welll another friend telling me I need to Stay with a faster scope. recocmending the ES 80MM ED triplet. Anyone have the scope can share images they have captiured?
watcher
Reged: 11/21/07
Loc: St. Louis, MO
      #5614087 - 01/09/13 04:59 PM
Not into imaging myself, but faster is not necessarily the best. I know that good results depend on your imaging equipment and preferred targets, as well as local sky and light conditions.
I love refractors, but a scope for imaging is another thing. Imagers can tell you better how fast a scope you might like if they know your equipment and other factors, but if you don't really need a short 80 or even 60mm scope, you might be a lot better off with an 6 or 8" Astro-Tech imaging Newt or maybe a 6" Rithey-Chretien. If it's a better match for your criteria, it could save you some bucks. If your heart tells you refractor, regardless of everything else, or if a fast refractor really is the best fit, I would suggest looking for a used TMB 80SS, or better yet, a 92SS with a Feathertouch.
dhaval
Reged: 07/21/08
Loc: Round Rock, TX
Re: Economical refractor new [Re: watcher]
      #5614191 - 01/09/13 06:11 PM
If you are truly going to get a refractor, I would say, go get the AT90EDT. It is a solid refractor for imaging with an amazing focuser - will easily hold a ton of load without flinching. I have not imaged with some of the 80mm scopes, other than the ES80ED APO, but can vouch for the image quality of the ES80APO after a focuser upgrade. I would also look very closely at the AT65EDQ given that it comes with a flattener - I am not sure about its focuser though, so an upgrade maybe required.
Things to keep in mind if you are buying a refractor -
1) Buy a well color corrected refractor
2) Ensure you get a decent focuser on the scope - either as part of the scope (TMB92SS, AT90EDT) or upgrade the stock focuser to either a Moonlite or FT
3) For imaging, you don't need a whole lot of aperture, 3in to 4in will do nicely, however, ensure the scope is sufficiently "fast" - F7 or lower, otherwise, you will have to find a reducer for your scope
4) Lastly, you will need a flattener, unless you buy refractors with 4 lens design
As you try and narrow down the field, what you will find is that you will very quickly go over budget. If money is your single limiting criteria, then I would say, go with a large aperture, significantly faster reflector - an AT10in imaging newtonian will be perfect!
Let us know how things work out.
Dhaval
ppfilbert
Reged: 02/03/11
Re: Economical refractor new [Re: dhaval]
      #5614244 - 01/09/13 06:35 PM
the AT90EDT is great , but its about 300$ out of my price range. i really need to keep it under 1000$, would prefer under 800, but i can swing it if necessary. as for ad-ons those would all be down the line a few months to lil more. perhaps if i find a Good Qua used one i might pop, but outside of 1K i just cant play
dhaval
Reged: 07/21/08
Loc: Round Rock, TX
      #5614293 - 01/09/13 06:59 PM
Post a wanted ad - given that you are still a month or so away from making the actual purchase, you might get lucky! I sold mine a few months ago for $900 and that included the rings and mounting plate.
Dhaval
desertrefugee
Reged: 08/06/07
Loc: Arizona
      #5614664 - 01/09/13 10:57 PM
I guess I'd ask what's wrong with the C8? I know this is the refractor forum, but a C8 - which you already have - working at C6.3 makes a pretty formidable imaging tool.
Dead seems so...final.
rflinn68
Reged: 03/09/12
Loc: Arkansas
Re: Economical refractor new [Re: desertrefugee]
      #5615258 - 01/10/13 11:03 AM Attachment (26 downloads)
A C8 is definitely not for a beginner in astrophotography. I own an AT8IN f/4 astrograph, an AT65EDQ, and a C8 with f/6.3 focal reducer. Focal length is too long on the C8 for a beginner. AT8IN is too heavy for imaging on a CG5. The AT65EDQ on a CG5 is IMO the best beginner set up one can buy. The focuser on the AT65EDQ is great for a factory focuser. I see no need at all to upgrade. The wife and I are beginners and just bought our autoguider and the frustration level imaging with the AT65EDQ has all but disappeared. This is our first stacked and processed image we ever took. Once we master the 65mm/CG5 combo then we will drag out the AT8IN and CGEM DX again. For some really good pictures to see what this little 65mm is capable of go to Astronomics website and check out some of the images they have posted. This is 80 minutes worth of 4 minute exposures (20X240sec) taken with an unmodified T3 camera at ISO 800.
rflinn68
Reged: 03/09/12
Loc: Arkansas
      #5615298 - 01/10/13 11:22 AM
Also here are some comparisons between the AT65EDQ and the ES80. The AT65 is $200 cheaper than the ES80. The AT65 has premium FPL-53 optics while the ES80 uses a FPL-51 equivalent. The AT65 is a quadruplet with a built-in field flattener while the ES80 is a triplet and will require a field flattener that will add even more to the price difference. The AT65EDQ also has a very nice focuser that is rotatable, a very nice feature to have on a imaging scope.
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5615328 - 01/10/13 11:35 AM
The AT65EDQ also has a high incidence of problems with pinched optics. I seem to remember that you were fortunate and didn't have that problem but many do.
rflinn68
Reged: 03/09/12
Loc: Arkansas
      #5615349 - 01/10/13 11:48 AM
I havent heard of that problem
terry59
Reged: 07/18/11
Loc: Colorado, USA
      #5615365 - 01/10/13 11:56 AM
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/5001067/page...
rflinn68
Reged: 03/09/12
Loc: Arkansas
      #5615408 - 01/10/13 12:13 PM
Interesting. That seems to be from the batch before these last ones were released and they seem to have that lined out now. Some really good reviews in those links as well. I havent heard a single bad thing about the newest ones that were just released and they've already sold them all. I'm sure Astronomics took care of all their customers problems. They've always took care of me when I've had an issue with some equipment.
AstronomicsAdministrator
Vendor if you must, AKA The Mighty Kong.
Reged: 06/07/04
Loc: Right Here
      #5615448 - 01/10/13 12:39 PM
There has not been a high incidence with pinched optics. There was around 10 out of 1000 that have had the problem. The pinching came from the retaining ring on the flattener being overly tight. The issue is the "problem" can only be discovered under temperature changes. In house where the temp is above 68 degrees everything is fine. Only as the temperature drops and the temp is cold will the pinching occur. By simply loosening the retaining ring around the flattener to finger tight the issue goes away. So the problem is really a non issue that is impossible to find unless the circumstance align themselves just right.
40 registered and 38 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
