Stellarvue SV80S Dew Shade "Droop" problem...
      #5613594 - 01/09/13 11:59 AM
Hi. Recently I purchased a used SV80S (LOMO 80/480 optical group) that suffers from a flaccid dew shade. That is, whatever is used to keep the dew shade properly extended during use has lost its Mojo. Apparently this is a common defect of these scopes.
For those of you who have had a Stellarvue scope with this affliction, how have you corrected it? What is the "little blue pill" equivalent for addressing this symptom. If you could walk me through the fix, I'd be greatly obliged.
- Jim
Binojunky
Reged: 12/25/10
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: jrbarnett]
      #5613610 - 01/09/13 12:11 PM
When their scopes are new Stellarvue suplied spare strips of felt to replace the worn stuff that is original, its a matter of holding the collar on the rear of the dew shield and unscrewing the dewshield itself, being carefull not to unscrew the lens cell at the same time,carefully remove the dew shield and the offending strips of sticky backed felt will be reveiled.
Put the new stuff on top on top of the original and ease the dew shield back on without curling back the new felt,I found the procedure a tad fiddly and uses a thin flat edged screwdriver to help.
Sticky backed felt can be found at the local craft shop of give Stellarvue a ring, they should be able to send you some, a far simpler way is to just use a rubber band behind the dew shield to stop it dropping down when elevated, good luck,DA.
Binojunky
Reged: 12/25/10
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: Binojunky]
      #5613613 - 01/09/13 12:13 PM
PS Jim, hold the dew shield and unscrew the collar, this will prevent any chance of unscrewing the lens cell, its been a while since I performed the procedure, sorry, DA.
Rich V.
Reged: 01/02/05
Loc: Lake Tahoe area, Nevada, USA
      #5613626 - 01/09/13 12:20 PM
Have SV send you a piece of their sticky-back black flocking material. The LOMO objective cell has this material wrapped around it to make a tight friction fit against the inside of the dew shield.
Unscrew the dew shield from the retaining ring, cut a few small pieces and attach them on top of the existing material, evenly spaced around the lens cell radially. You'll have to experiment a bit; it doesn't take a lot of material to do the job.
When you've added the right amount, the dew shield will fit nice and tight again.
Rich
      #5614012 - 01/09/13 04:20 PM
Thanks guys. I'll see if I can track down some sticky sided black felt flocking on my own.
Denimsky
Reged: 01/21/07
Loc: BC, Canada
      #5614077 - 01/09/13 04:53 PM
I got the extra felts and instruction for free after contacting StellarVue.
Mary
Reged: 01/29/08
Loc: Highlands Ranch, CO
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: Denimsky]
      #5615185 - 01/10/13 10:22 AM
Jim,
I just put a rubber band behind the dew shield....
Mary
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: Mary]
      #5615431 - 01/10/13 12:27 PM
Thanks Mary.
I'll do that on an interim basis. I do want to "restore" the scope to its original functionality though at some point, though. I'm planning on using it for an article I'm working on, and want it to look pretty in the pictures.
I've also asked Starlight for a quote on a replacement clamping screw for the bent one. Little by little I'll get the scope back in fighting trim.
Mary
Reged: 01/29/08
      #5615681 - 01/10/13 02:52 PM
Sounds like you have a good plan Jim! It will be a beauty when you are done! I am very interested in your upcoming article!
Mary
stratocaster
Reged: 10/27/11
      #5615920 - 01/10/13 05:23 PM
Jim, did you purchase this scope as a result of looking through a fellow observer's SV LOMO when you viewed the pup?
Jared
Reged: 10/11/05
      #5615989 - 01/10/13 06:17 PM
One other thing to check on your scope... The SV8S0's (at least the ones with the LOMO objectives) have adjustable back plates rather than lens cells. When I bought mine it was off by quite a bit--enough to actually be visible at the eyepiece, and that takes a lot with a refractor. I'd recommend checking your collimation with a nice 2" laser collimator such as a Howie Glatter or a Farpoint. It's an easy adjustment with a good laser and should be relatively permanent. it's definitely worth double checking yours since you know it has been banged around a bit (based on the one bent screw).
Jared
Reged: 10/11/05
      #5615991 - 01/10/13 06:19 PM
Forgot to ask. What color tube did you get? Just curious--I wouldn't want to think you were copying me...
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: Jared]
      #5616202 - 01/10/13 08:17 PM
Would I do that , Jared? It's blue.
Stratocaster:
Yep, I bought this one after using Jared's a couple of years ago to observe Sirius B.
Scott in NCModerator
Mad Hatter
Reged: 03/05/05
Loc: NC
      #5616241 - 01/10/13 08:44 PM
C'mon, Jim--not descriptive enough. Inquiring minds want to know: Stardust Blue or Midnight Stardust?
Re: Stellarvue SV80S Dew Shade "Droop" problem... new [Re: Scott in NC]
      #5616566 - 01/11/13 12:55 AM
Plain old Stardust blue. In fact, the dew shade and tube are slightly different texture and hue, leading me to suspect that the underlying materials may differ a bit.
Mary
Reged: 01/29/08
      #5617010 - 01/11/13 10:46 AM
You mean Beautiful Stardust Blue!!!!
Mary
      #5617033 - 01/11/13 10:56 AM
Of course that's what I meant, Mary.
I've also asked Starlight about a replacement coarse focus knob as the one on the unit I received has faded to eggplant and plum on its way to gold due to UV exposure (probably set up indoors at a window for extended periods).
What I'd really rather do is have Stellarvue just port my optics to one of the new OTAs in white with the 2.5" focuser, and call it a day. I can repair the FT and part it out to recoup part of the costs of my misadventure on the used scope that wasn't what it was held out to be condition-wise.
Binojunky
Reged: 12/25/10
      #5617116 - 01/11/13 11:43 AM
Big fan of Barbie Pink myself, DA.
      #5617166 - 01/11/13 12:15 PM
Yeah, me too.
Though it's more "pale Pepto pink" I'd say.
Binojunky
Reged: 12/25/10
      #5617552 - 01/11/13 04:23 PM
Oh god I,m in love, all it needs is a Mink fur lens cap and its going to be a long loving relationship, now if only it can be trained to fetch a cold beer from the fridge?,DA.
39 registered and 48 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
