Privacy Policy |
Please read our Terms
of Service | Signup and
Troubleshooting FAQ | Problems? PM a Red or a Green Gu
uh, User
Tophat3
Reged: 07/20/10
Loc: Columbus,Ohio
Re: Side by side or stacked for refractors?
[Re: FoxTrot]
#5636226 - 01/22/13 04:43 AM
+10 on that! I think I just had a stroke!! I've never seen anything like that.Even in my dreams!!
bilgebay
Reged: 11/06/08
Loc: Türkiye - Istanbul and Marmari...
[Re: FoxTrot]
#5636259 - 01/22/13 05:46 AM
With some Photoshop skills, you can do even better guys
bilgebay
Reged: 11/06/08
[Re: bobmarleyou812]
#5636289 - 01/22/13 06:30 AM
How about these ?
I designed and manufactured this side by side system myself. Very easy to balance and very versatile. The bar is 25" long.
Ain Soph Aur
Reged: 08/11/11
Loc: Tennessee
[Re: DaveJ]
#5636309 - 01/22/13 07:06 AM
Personally, I prefer side-by-side for visual as shown in this photo.
Hi Dave. How do align the two scopes with your set-up?
smee
Reged: 10/19/10
[Re: FoxTrot]
#5636413 - 01/22/13 08:54 AM
Barry, SkyCapt, you guys are just bragging now...! Fox
Or maybe they are pretty handy with Photoshop!
BarrySimon615
Reged: 03/01/04
Loc: New Orleans, LA
[Re: mattyfatz]
#5636428 - 01/22/13 09:02 AM Attachment (15 downloads)
You could do it both ways......times 3 or 4!
Barry, That's a neat setup. I'm curious to learn more about it. What sort of mount is that and what's its capacity? Do all those scopes point at the same thing? Can you make adjustments to allignment the scopes on the same target? What is the hardware underneath?
Not mine, somebody sent me that picture and it has been in my files for several years. Obviously most of the scopes and the mount appear to be made by William Optics.
In respect to the question asked. I have mounted stuff both ways, side by side and piggyback. Both have their balance challenges. If piggyback you are adding still additional weight even further away from the RA rotational axis requiring even more weight.
The picture below is of my Brandon 130mm f/8 apo which was in my possession from 1992 to 2005. I was the second owner of the tube assembly which you see mounted on a Losmandy G11 (one of the first purchased in 1992). I added the 3" guide scope which I built from Unitron parts. Also pictured on this setup is a "rich-field" 60 mm scope as well as the Brandon 40 mm finder (Brandon sourced their component parts - cells, focusers, tubes, fittings from the same source that supplied Unitron). The two tubes that I put together (the 3" photo-guide scope and the 60mm rich field were painted with Rustoleum "Harbor Blue" which is a close match. Total payload weight was 33 lbs. This and the fairly long moment arm really tended to push the G11 mount close to it's limit, not over it, but close to it.
Since I sold the scope in 2005 I believe it has had at least two more owners.
Barry Simon
DaveJ
Reged: 01/07/05
Loc: NE Ohio
[Re: Ain Soph Aur]
#5636515 - 01/22/13 09:55 AM
Hi Brandon,
The alignment of the two 'scopes as shown in that photo posted above was pretty darned close. I cut thin pieces of packaging plastic into rectangular pieces and experimented by placing a couple of them between the bottom edge of the front rings and dovetail rail of the 102 refractor. I got the alignment almost perfect and was quite happy with myself. After the scopes moved to the opposite side of the mount, the alignment wasn't as perfect so I went back to the drawing board and wound up replacing the rings with these. Perfect alignment is now as easy as adjusting a 50mm finder to its OTA. I intend to get another photo the next time I'm out, but the weather in NE Ohio isn't exactly solar-viewing-friendly at the moment. One will follow, I promise.
t.r.
Reged: 02/14/08
Loc: Upstate NY
[Re: DaveJ]
#5636620 - 01/22/13 10:43 AM
That Brandon stack was a beautiful set-up!
Jim Curry
Reged: 10/29/07
Loc: STL
[Re: Sky Captain]
#5638314 - 01/23/13 06:59 AM
Kerry: I've always admired a well stacked scope!
35 registered and 24 anonymous users are browsing this forum.
Moderator: Scott in NC, Bowmoreman, KWB
