Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 | 16 | (show all)
amicus sidera
Reged: 10/14/11
Loc: East of the Sun, West of the M...
Re: Pimping your 102mm gt OTA.. Like what? new [Re: t.r.]
      #6072882 - 09/10/13 10:11 AM
Why shouldn't it work...Televue has been using Emery Cloth in its tubes for years.
You know, I'd heard a rumor that they were doing that. Think I'll be keeping any type of grit far from my optics, thanks anyway!
As far as using flocking to line dew shields, how does one determine that all moisture has evaporated from the absorbent flocking material prior to capping the objective? Sounds iffy to me.
Fred
jag767
Reged: 06/20/13
Loc: Massapequa, NY
Re: Pimping your 102mm gt OTA.. Like what? new [Re: amicus sidera]
      #6072924 - 09/10/13 10:35 AM
Fred
Cap it the next day?
Sarkikos
Reged: 12/18/07
Loc: Scotophobe Maryland, USA
Re: Pimping your 102mm gt OTA.. Like what? new [Re: Ed Holland]
      #6073011 - 09/10/13 11:14 AM
I recently experimented with home made "flocking". 100 grit sandpaper, sprayed with a light coat of matt black paint.
worked very well on the baffle tube of my Mak.
Just a thought for those wanting to maintain the budget theme
Ed
I would prefer not to.
Sarkikos
Reged: 12/18/07
Re: Pimping your 102mm gt OTA.. Like what? new [Re: jag767]
      #6073025 - 09/10/13 11:17 AM
Fred
Yep, that'll work. When I arrive home from the dark site, I make sure everything I used is uncapped to air out while I'm sleeping. I don't cap things and put them away until I get up six-to-eight hours later.
Ed Holland
Reged: 06/16/10
Loc: San Jose, CA and Oxford, UK
Re: Pimping your 102mm gt OTA.. Like what? new [Re: spongebob@55]
      #6073959 - 09/10/13 09:20 PM
It seems to help... but I have not tested rigourously. The 3M aluminium oxide paper I used is pretty well bonded together to start with. For the inside of a dewshield, I think this is pretty safe stuff. It also seems to be a rather good light trap
Ed
Sarkikos
Reged: 12/18/07
      #6074046 - 09/10/13 10:24 PM
I've also heard of folks grinding up walnut shells and mixing with flat black paint for flocking.
PeterR280
Reged: 05/27/13
Re: Pimping your 102mm gt OTA.. Like what? new [Re: Sarkikos]
      #6074073 - 09/10/13 10:38 PM
why not just buy some flocking?
Sarkikos
Reged: 12/18/07
Re: Pimping your 102mm gt OTA.. Like what? new [Re: PeterR280]
      #6074464 - 09/11/13 06:48 AM
Yes, that's what I did. ScopeStuff and ProtoStar sell it. I just bought some from ScopeStuff.
spongebob@55
Reged: 12/26/11
Loc: Bergen Co. New Jersey
      #6074493 - 09/11/13 07:12 AM
Has anyone just taken off the dew shield and lightly sanded the glossy plastic and/or flat black painted the inside?
spongebob@55
Reged: 12/26/11
      #6074627 - 09/11/13 09:14 AM
Does someone know what the thread is on the end of the focuser tube? I was thinking of getting a Baader Click Lock if there's one available for those synta threads. Would make it so much easier and precise to rotate the diagonal instead of loosening/tightening 2 screws all the time....
Sbob
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #6075265 - 09/11/13 02:37 PM
oof! I don't think I would do that. Walnut shells are so hard they are used for cleaning firearm cartridges for reloading. if any dust from them got on a lens, and was wiped....
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #6075272 - 09/11/13 02:39 PM
That's what I did with mine. just sanded it. no paint.
cavefrog
Reged: 11/11/08
Loc: loozyanna
      #6075292 - 09/11/13 02:46 PM
Sbob
I am not positive, but I do not think Baader clicklock is made with that thread. because of these recent threads about the C-102 scopestuff is backordered on These
Ain Soph Aur
Reged: 08/11/11
Loc: West Tennessee
Re: Pimping your 102mm gt OTA.. Like what? new [Re: cavefrog]
      #6075581 - 09/11/13 05:39 PM
If it is a M56 thread, then there is a 2" Clicklock that would work. Keep in mind that the adapter would cost around $100 and for another $50-60 you could replace the entire focuser with the excellent GSO.
REC
Reged: 10/20/10
Loc: NC
Re: Pimping your 102mm gt OTA.. Like what? new [Re: Ain Soph Aur]
      #6076523 - 09/12/13 08:35 AM
Since I had such a good experience with the WO BV in the scope last night, I'm thinking of replacing the focuser with a GSO 10:1. The BV needs a stronger focuser.
t.r.
Reged: 02/14/08
Loc: Upstate NY
Re: Pimping your 102mm gt OTA.. Like what? new [Re: REC]
      #6076540 - 09/12/13 08:50 AM
It is kind of funny, to load this $60 scope up, with my Leica zoom ($500), dielectric diagonal ($100) and or a binoviewer ($1000)! Everything I stick into the focuser is many times more expensive than the scope itself...but oh, do the accessories ever let the lens loose to perform to its full potential! The jury is still out, but I may use this scope as my first choice grab-n-go scope over the C6!
spongebob@55
Reged: 12/26/11
      #6076544 - 09/12/13 08:52 AM
Sbob
Thanks for that link. I was a bit surprised by how expensive that is, especially relative to the $59. I already put in vinyl bolts but you really have to crank down on them, especially with a quality 2" diagonal and a glass gernade EP. I guess this accessory would hold better, especially with the brass bolts, but I think I'll hold off for now. But thanks for the link!
Sbob
Ed Holland
Reged: 06/16/10
      #6076845 - 09/12/13 11:59 AM
Well my experiment was just that.. an experiment because I had no other flocking material. It worked well enough that I'm happy to leave it in place.
of course I understand the concerns about grit particles, but it seems fairly robust to me.
REC
Reged: 10/20/10
Loc: NC
Re: Pimping your 102mm gt OTA.. Like what? new [Re: rtomw77]
      #6077032 - 09/12/13 01:38 PM
For the extra weight, I have a 2.5lb ankle weights that I just "wrap" around the front of the tube. I then can slide it up and down the tube the counter balance whatever I'm hanging off the back. Like last night I had a binoviewer and two EP's so it got pretty heavy back there.
REC
Reged: 10/20/10
Loc: NC
Re: Pimping your 102mm gt OTA.. Like what? new [Re: gunfighter48]
      #6077056 - 09/12/13 01:45 PM
Wow, you where up over 180x and still looked good? I'm happy with my ES6.7 for 150x in mine.
27 registered and 33 anonymous users are browsing this forum.
Moderator:  Scott in NC, FirstSight, panhard, star drop
