deSitter
Reged: 12/09/04
..is to the owner! Should an airplane fly through the beam, you could be in deep doo-doo under the Patriot Act:
http://www.msnbc.msn.com/id/6775100/
Bad idea all around, IMO.
-drl
Reged: 07/06/07
-drl
Unless you live near an airport, and are pointing up in the glide path, the chances of:
1. This happening. 2. And someone aboard the aircraft noticing.
Are vanishinly small. This incident happened three years ago, and it's obvious the guy was very much trying to cause trouble. IOW? You will have to work and work hard to get yourself in trouble this way.
I have been using a green laser both with my university astronomy students and at star parties where I am a speaker--when I'm called upon to do "sky tours"--for years and have yet to have any black helicopters land in my backyard. Hell, I can't even spell "Gitmo."
Certainly anyone using a green laser should be responsible and careful. But "the gubmint might come get you" is no reason to give in to a Nanny State mentality and stop using a useful AND LEGAL tool.
-------------------- Uncle Rod
Rod's New Book:
Choosing and Using a New CAT
Available now!
steveoid
Reged: 02/10/08
Loc: London,England
Having just bought a 5mW laser I used it for the first time last night attached to my large binoculars. The beam was excellent for locating objects where pointing a large 90 degree viewing angled binocular and finding an object is almost impossible. I looked very carefully into the part of the sky where I was going to point just to make sure there were no aircraft near. It’s a fine piece of kit and I will be responsible on its use when I am out observing. Steve
-------------------- Celestron C8
120mm ED Pro refractor.
80mm ED Pro refractor (solar observing)
Baader Herscel wedge.
Quantum 6- X20,X30 & X37 100MM binoculars.
Helios 10.5 x 70mm HD binoculars
Heq5 Pro mount.Eye pieces
Celestron ultima 2x barlow.
FR/FC lens 6.3 Celestron.
2" WO Dielectric.
Hyperian eyepieces.
Vixen lanthamum eyepieces.
Watec120n+ ccd camera.
GeorgeDuke
Reged: 04/24/03
Loc: PARADISE! (So.Florida)
I would like to get a real answer from someone who knows. How far does a beam from a 5mw green laser actually travel. I know it looks like it travels right up to Jupiter etc. but that is an illusion. From what I have been able to gather, the beam actually travels about 1,000 feet or so. I know there are high powered lasers available but the 5mw is all we need for our Astronomy use so let's stick with that. As Ron said above, unless you are at the airport, or at the top of a skyscraper, or in another airplane, you can't even see the pilot unless he leans out the window to look down at you. And then I doubt if the plane would be low enough. Most new devices invoke panic in a segment of the population until they become omni present. There is also a fear among imagers that a laser beam will ruin one of their images. I read somewhere of tests done and it was not possible to get the laser beam to appear in one of the deep sky images. In fact pointing the imaging scope right at the person using the laser they could not get a picture of the beam without combining multiple images.
-------------------- George
SkyShed POD XL-3
LX200GPS 203mm f10
StellarVue SV102ED2 Feathertouch Ser#0018
LXD75 GOTO with Orion 16" pier extension
Baader Hyperion 8mm ,13mm, 21mm and 8-24mm Zoom + FTRs
2" GSO ED barlow, Orion 2" Prism Diag. 2" SV Dielectric
Midnight Dan
Reged: 01/23/08
Loc: Brockport, NY
How far does a laser travel? There's no one answer to this. Yes, it depends on the power of the laser (and the condition of the batteries). But even more important is the quality of the sky. The more particulates, humidity, etc. the more light will be absorbed and scattered. On a good clear, stable night, it can travel a VERY long distance.
Keep in mind that how far the beam is visible by you, is a very different thing from how far away you'll see it if it's aiming at you. Think about car headlights. When you're driving a car at night, your headlights will not illuminate the road very far in front of you. But people coming at you in the other direction can easily see your headlights over a mile away.
Same is true for the laser. The beam may not be visible for more than a thousand feet or so, but it can still be blinding bright for a VERY long way beyond that to someone looking at it.
-Dan
-------------------- Scopes: Celestron NexStar 8SE, Orion EON 72mm ED/APO, Orion ShortTube 80
Mounts: NexStar Alt/Az GoTo, Orion Astroview (EQ3) w/single axis drive
Eyepieces: Baader Hyperion 21mm 13mm, 8mm, 5mm; GO 32mm SWA;
Other: 2x & 3x Barlow, 0.63x Focal Reducer, Dew-not strips, DewBuster controller
Jason D
Reged: 10/21/06
Loc: California
True... But let us do the math... If someone shines a 5mW laser beam at someone's eye with 7mm eye-pupil standing 1000 feet away, then the person holding the laser has to hold his/her hand steady within 2.5 arc seconds tolerance for at least 1 minute to cause permanent eye damage. If human hands can be this steady then who would need a scope mount. Jason
-------------------- XT10 classic with premium optics
Tri-knob CR2 with compression rings
Round Table Platform
4.5" StarBlast
6" StarBlast6
TV EPs
denodan
Reged: 10/06/04
Also the laser beam will not remain a tight narrow beam, it accually increases in size the further it goes, the light spreads out, so at 1 kilometer, or so,the dot maybe the size of a tennis ball,etc, the further the beam the more the dot will spread.
KDizzle
Reged: 09/12/08
Loc: Woodinville, WA
The laser collimation also comes into effect. The Zhumell laser poitner I have diffuses quite a bit over distance. So muhc so that when measuring from about 100 feet away, the size of the green 'dot' that it creates is actually about 2 inches diameter! Ironically this is good because when you are 100 feet away, trying to see a dot the size of a pea is also not so easy. I don't know how much it diffuses over 1000 ft, but I could only iamgine that it becomes much more diffused - a dot with a diameter over a foot wouldn't be too unexpected imo.
Here is a picture of the dot from about 40 feet away; clearly it is half an inch diameter, eh?
walt r
Reged: 02/13/07
Loc: Doylestown, PA
A very low power LASER can be seen from quite a distance when the beam is directly towards you. Many years ago for a communication experiment a 1mW HeNe LASER was set up on the roof of a university building (I think it was in Phoenix) and aimed at the universities observatory 20+ miles away. When the researches arrived at the parking lot the LASER was the brightest light on the city skyline and the beam had spread to several hundred feet wide. LASER diodes are not as well collimated (beam divergence is greater than a gas LASER) but it is still quite bright to look at from many miles away.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
deSitter
Reged: 12/09/04
Well I didn't mean to imply panic, other than what the gov't will do to you in case of a harmless accident. I do in fact live right under the busiest waypoint on final approach to the busiest airport in the country, so any laser activity at night is out of the question.
Actually when it comes to teaching people the constellations, I've never had any problems just pointing out the stars with my 0-watt fore-finger.
-drl
-drl
New Mexico Craig
Reged: 09/05/07
Loc: The Land of Enchantment
LMAO! Good point (literally)!
craig
-------------------- Celestron CPC 1100 (aka "the groove tube")
The Motto of the Solar System :"Id quot circumiret, circumveniat."
Dipole
Reged: 12/21/06
Loc: Right behind you
Ok, I did a test...
I pointed my 5mW green laser pointer to the horizon directly West. My buddy swears he saw a dim green spot on the back of my head.
Midnight Dan
Reged: 01/23/08
Loc: Brockport, NY
Well that does it! I've had my good laugh for the day!
-Dan
deSitter
Reged: 12/09/04
Ok, I did a test...
ROFL - yeah but was it warm?
The temptation to play Luke Skypointer would be too great I think and beams would be flying.
-drl
Edited by csa/montana (09/22/08 06:35 PM)
New Mexico Craig
Reged: 09/05/07
Post deleted by csa/montana
Reged: 07/06/07
-drl
-drl
If you put your forefinger to good use, more power to you. For most folks, even living near airports, laser use is completely safe, and is much more effective with large crowds at dark sites than the Fickle Finger of Fate.
Rod's New Book:
Available now!
cam1936
Reged: 08/01/08
Loc: Alberta, Canada
-drl
Guy tried to blame it on his daughter. What a coward.
-------------------- C8-SGT
Nikon 10x50 Action Ex
Canon 350D
Manfrotto tripod
Various EPs and accesories
Jason D
Reged: 10/21/06
Loc: California
I did hear a novel use for these things - you can cause streetlights to go off for 10-15 minutes if you manage to zap the daylight sensor.
Is that true??
Because if it is, I am now going to definitely get myself one!
Whoops... Looks like this thread just crossed the red line. I will give this thread a day at the most before it is locked by one of the CN moderators.
4.5" StarBlast
6" StarBlast6
TV EPs
Jim Romanski
Reged: 01/02/05
Loc: Guilford, Connecticut
I use mine as a finder and its the best pointing device I've ever used.
There's a much publicized case of the guy in NJ that shined his laser at a plane flying low by Teterboro airport. I do not believe that you can even see the beam at normal cruising altitude (not that I plan to test that out nor should anyone). I believe that the FAA has confirmed this as well. In any case, it's a simple matter to avoid using it when a plane goes by that part of the sky.
I think the airplane issue has been over-hyped (the TV show CSI even used a green laser taking down a plane as a plot for a show last season). That said, while this kind of laser won't mess with a planes electronics there is such a thing as a laser that can.
About 35 years ago my Dad worked for a small engineering firm in NJ that did some pioneering work on Lasers. Back then a laser was a large collection of prisms and mirrors and a fairly large device. It took a lot of power to operate one as well.
One day they were outside testing a large pulse laser. A little while later they noticed an FCC truck driving around. They turned on a radio and found that they had jammed the entire dial with noise and realized that the new power supplies they were using were unshielded. Since they were right next to a small airport they must have jammed the entire communications frequency and disurppted all the flights. Ironically this was Teterboro airport!
They shielded their gear and that was the end of it. So I guess technically you can bring a plane down with a Laser. Just not the way you'd think.
I thought you might like this story so I'm quoting myself above from this post a couple years ago: Green Laser Pointer
There are some good links back in that thread too.
-------------------- Jim
17.5" Dob "Project"
13.1" Coulter
8” Cave
NP 101 on a CG-5
25x100 binos
Naglers, Ethos, etc.
Luigi
Reged: 07/03/07
Loc: Massachusetts
The laser light goes on forever, just like light from distant stars, until all the light is absorbed by something. Looking at the beam the way we do when using it on the sky, the light seen is what's scattered mainly by dust in the air. With no air and dust, you wouldn't see the beam. All laser beams eventually diverge as a consequence of diffraction.
-------------------- 17.5" f/5 Discovery Truss
IM715 7" f/15 MCT, Eon-120ED
Lunt 60mm Ha on a Nexstar mount.
CG5A coffee grinder, Orion Skyview Alt-AZ
35,19,15 Pans.9 Nag. Meade 24.5 4kSWA, 4.7 5kUWA.
BO-TMB 7mm planetary. Edge-on 3mm.
Zeiss Diascope 85
Zeiss, Leica, Canon IS, Fujinon, Nikon binos
One each generic rescue Greyhound (pictured)
sixela
Reged: 12/23/04
Loc: Boechout, Belgium
But it isn't focused for a very long distance. I doubt you'd notice anything by the time the beam is as wide as a football (soccer ball to you US people).
400mm f/4.46 David Lukehurst truss Dobsonian on Tom Osypowski equatorial platform
Orion Starblast (114mm f/4 reflector, Alt/Az)
Luke S
Reged: 07/16/08
Just a quick scan of some laser pointer specs give beam divergences on the order of 1.2mrad, so if you take that as the full angular size of the spot produced, some quick back of the envelope calculations give a beam diameter of about 12ft for an altitude of 10,000ft so for a commercial jet at 30,000ft the beam diameter is about 36ft. If a pilots pupil is .2" in diameter (to keep similar units) at 10,000ft the pilots eye receives about .0002% of the original laser energy.
Of course this all assumes I did correct math before noon, which is not always true.
Now, on the other hand, if you are doing something like this http://www.physics.ucsd.edu/~tmurphy/apollo/apollo.html you do need to worry about it. They have "plane spotters" that make sure the sky is clear before they fire the laser pulse.
New Mexico Craig
Reged: 09/05/07
Excellent point, Luke S.
I forgot about that : the Apollo Project has approved observers shining lasers at the Moon (mirrors specifically placed on the Moon, that is) on a regular basis!
"The beam is about as visible as the Milky Way", they say.
Apollo Project pics
Dipole
Reged: 12/21/06
In practical terms how far do you need the beam to be visible to indicate where you have pointed the scope?
I'm thinking a lower power laser pointer may use less juice and work about as well.
Midnight Dan
Reged: 01/23/08
Loc: Brockport, NY
Problem is, how far the laser is visible depends on the atmoshperic conditions. On a night with clear air, there is not a lot to reflect the beam, so it's difficult to see unless you have the full 5mw. On a medium night, lower power may work ok. On a night with a lot of stuff in the air, you may need more juice to power through it. Of course if it's that bad, you probably woudn't be viewing anyway.
-Dan
sang33ta
Reged: 07/08/08
Loc: UK
A kid in the UK was done for shining one at a police helicopter here too.
I would have to say "I was measuring the distance to your vehicle, officer"
If I was in court I'd have to say "so, just how may planes have been downed by laser pointers then?"
-------------------- Hioptic 152mm f12.5 Maksutov
Celestron Advanced CG5-GT Mount (Mr Noisy!)
Meade 4000 Super Plossl Set
Casio QV-2900UX
Got fed up of waiting for Meade ETX-150 so put this together for £500/$1000
1965healey
Reged: 06/23/07
Loc: San Antonio, TX
As the sister of a Los Angeles County Sheriffs' Department helicopter pilot I figured I'd go to the pilot and ask him a few questions.
Q. Can green and/or red light lasers be seen from the air?
A. Yes, both can be seen.
Q. Has anyone ever pointed a laser at your helicopter?
A. Yes, both the green and red lasers have been pointed at the helicopter while we were in flight.
Q. What happens to the beam if it is directed at you?
A. Nothing if it shines on the body of the helicopter.
Q. What happens if it shines in or on the canopy?
A. If it shines on the canopy then the entire interior of the craft is lit by a bright red or green glow. Similar to having a flashbulb go off inside the craft. The pilot and observer both have their dark adaptation ruined. If the pilot is looking directly at the point source of the laser when it makes contact with the canopy then he'll have much of his center vision affected.
Q. What do you do if this happens?
A. We have to turn away from the source of the laser. If we are in pursuit we have to break off until our vision recovers, this can take a minute or two. Time enough to lose track of the bad guys.
Q. Do you try and find the source of the laser?
A. Yes, if we find them they're questioned and if the "tag" was deliberate they are arrested for interfering with an officer while on duty. They are also reported to the FAA who may file separate charges on the federal level.
Q. What do you recommend that some one do who wants to use a green light laser for astronomy in a populated area.
A. Never use one near an airport or heli-pad. Watch and listen for aircraft that may be approaching. In L.A. County/City we ask that if you're going to use one in the city or in a town that has an air patrol to call the station and let them know your location and give them your phone #. If the patrol needs to operate in your area you'll be called and asked to not use the laser while the helicopter is in the area. Don't leave the laser turned on. Point it where you need to point it and then turn it off.
My brother was very serious about the danger that a laser can present to pilots. He's usually pretty laid back about things and will joke about lining the floor of his helicopter with bullet proof vests and then putting one on his seat as well during the Rodney King riots. The patrol was shot at and hit a few times by rioters. Talking to him about lasers was like talking to my dad, he got real serious real quick.
His response to your comments....
1. You can't measure the distance to a vehicle or an aircraft with that type of laser.
2. All it takes is one.
-------------------- 1965Healey (Karen)
Woodlawn Lake Observatory
Celestron CPC 800/FT MIcro/APT Wedge
SV NHNG 80mm #0261/CG5-GT
Celestron Omni 150 XLT
Losmandy rails/rings
Starizona CWeight system
Celestron Neximage
Sony a100 DSLR/ZigView S2
Meade DS60's w/Autostar (2)
Meade LPI/Meade DSI-C/DSI ProII
750cc Honda Shadow Spirit (Thanks Dad!)
1965 Austin Healey 3000 MKIII
bdjeep
Reged: 01/29/07
Loc: Bolton, MA
I'm not sure if this has been posted, but I found this web page particularly helpful in explaining all of this.
Reged: 07/06/07
[ My brother was very serious about the danger that a laser can present to pilots. He's usually pretty laid back about things and will joke about lining the floor of his helicopter with bullet proof vests and then putting one on his seat as well during the Rodney King riots. The patrol was shot at and hit a few times by rioters. Talking to him about lasers was like talking to my dad, he got real serious real quick.
I'm sure he was. However, again, there is no problem using green lasers on the sky as long as you exercise a little commonsense. I've never had a problem, and don't feel motiviated to call the cops and let them know where I am everytime I want to use my laser.
Rod's New Book:
Available now!
Mobius1
Reged: 08/28/05
Loc: Madison, WI / Gurnee, IL
