John Wunderlin
Reged: 10/01/04
Loc: Mineral Point, Wi
Mount PST to Dobsonian?
      #5663398 - 02/05/13 11:21 AM
Has anyone ever tried mounting a PST to a Dob? I just picked up a PST and would like to do this. I have an EQ platform for my dob, so this would allow me to having tracking for whitelight and Ha at the same time- very handy for outreach...
csrlice12
Reged: 05/22/12
Loc: Denver, CO
Re: Mount PST to Dobsonian? new [Re: John Wunderlin]
      #5663425 - 02/05/13 11:35 AM
As long as the dob doesn't catch fire........
John Wunderlin
Reged: 10/01/04
Re: Mount PST to Dobsonian? new [Re: csrlice12]
      #5663429 - 02/05/13 11:37 AM
Yes, I have a solar filter for the Dob
btb
Reged: 07/07/06
Loc: Northeast Indiana
      #5663502 - 02/05/13 12:22 PM
I have not mounted a PST to a dob but I do have both. The PST does have 1/4 X 20 threaded holes for photo tripod mounting so drilling a couple of holes in your dob is possible. Now do you want to drill some holes or are you looking for some other kind of mounting options? Also depending on where you mount your PST you are going to need some counter weights on your reflector.
Edited by btb (02/05/13 12:24 PM)
Zamboni
Reged: 01/03/05
Loc: Colorado Springs
      #5663505 - 02/05/13 12:22 PM
What kind of dob do you have? If it's a solid tube 6" to 10" then you could get a set of tube rings from Orion where one of the rings has a built in piggyback adapter and just clamp that to the tube.
John Wunderlin
Reged: 10/01/04
Re: Mount PST to Dobsonian? new [Re: Zamboni]
      #5663521 - 02/05/13 12:31 PM
I've thought about the tube ring- I may even have one laying around (yes I buy too much astro gear). My Dob is a 10" XTi- one of the first and it's showing its age, so I'm also not opposed to drilling holes. I would like it to be fairly easy to setup/break down.
Paul Hyndman
Reged: 07/13/04
Loc: Connecticut Shoreline USA
      #5663771 - 02/05/13 03:23 PM Attachment (12 downloads)
Seems like a much better mounting solution than mine.
So long as you remember to always have the Newt' and any finder scope covered/filtered, you'll be good to go. As a bonus, it's always interesting to compare active regions in white-light vs Ha in real-time and I'm certain you'll enjoy it.
Bon appétit!
Paul
John Wunderlin
Reged: 10/01/04
Re: Mount PST to Dobsonian? new [Re: Paul Hyndman]
      #5663848 - 02/05/13 04:04 PM
Overengineer much?
Actually I may have found my answer- not sure if this would be strong enough for the PST's weight, but it would allow alt/az adjustments so I could line up both scopes:
http://www.optcorp.com/product.aspx?pid=223-672&kw=&st=0
Paul Hyndman
Reged: 07/13/04
      #5663902 - 02/05/13 04:34 PM
Another solution is to use a precision adapter (with 1/4"-20 threads). These are relatively inexpensive and work quite nicely, allowing almost micrometer-like adjustment on both axes.
Paul
MikeBOKC
Reged: 05/10/10
Loc: Oklahoma City, OK
      #5663903 - 02/05/13 04:34 PM
These will attach to the bottom of the PST viia screw. Then mount a 7 inch Vixen style dovetal to the Dob OTA and kist slide the PST onto it and screw tight.
http://www.astronomics.com/astro-tech-dovetail-accessory-adapter-vixen-black_...
I piggyback my PST alongside my TMB92L with a dovertail mounted on the top of the refractor's rings. Gives me side by side white light and H-alpha.
btb
Reged: 07/07/06
      #5663926 - 02/05/13 04:45 PM
Are you going to mount right on tube or build a longer bracket to mount to? A PST is about 3 pounds if I remember and that contact point with the single screw looks a little small. Have you thought about where you want to mount the PST? On top of OTA puts the eyepiece kind of high and in an awkward position, especially if you do outreach programs with kids. If you mount on the side like a normal reflector eyepiece you lose your alt/az adjustments.
btb
Reged: 07/07/06
Re: Mount PST to Dobsonian? new [Re: btb]
      #5663945 - 02/05/13 05:00 PM
My comment was in reference to the mount that John linked to, not any others they were posted while was typing my reply.
John Wunderlin
Reged: 10/01/04
      #5663955 - 02/05/13 05:04 PM
Paul
We have a winner! That's perfect- thanks much!
John Wunderlin
Reged: 10/01/04
      #5663962 - 02/05/13 05:08 PM
I'm planning on mounting it near where the tube attaches to the base. That will be kind of low, but it should help with balance. I'm also planning on adding a better counterweight system. My scope is so heavily modded and has so many attachments it's almost unrecognizable as an XT10i
btb
Reged: 07/07/06
      #5663990 - 02/05/13 05:20 PM
Would a bracket like this be one be of any use, you for an idea? Might need to turn upside down. Should work with the precision adapter.
Edited by btb (02/05/13 05:23 PM)
John Wunderlin
Reged: 10/01/04
      #5664010 - 02/05/13 05:29 PM
Thanks- I think the only thing I want yet will be a way to attach the slow-motion control to the base- I won't want to leave it on all the time. There are a ton of options for camera connectors I just need to weed through and find something. A quick release would be good as long as it doesn't introduce any movement.
kfiscus
Reged: 07/09/12
Loc: Albert Lea, MN, USA
      #5664300 - 02/05/13 08:45 PM
To throw a wrinkle into the works, I also use a PST for outreach, but no one looks through the PST itself. I use a Meade electronic EP and a 12-foot cable into a small monitor. I've piggybacked the PST on a 8" LX200 and even a glass-filtered Astroscan. The winning setup turned out to be the PST attached to a standard light-duty tripod at its shortest height riding on one of my EQ platforms. I have no picture of the setup. I made a 1/4" plywood disk that rode the paltform and had 3 rings attached to its surface to keep the tripod's feet where they belonged.
GeneT
Ely Kid
Reged: 11/07/08
Loc: South Texas
      #5664333 - 02/05/13 09:17 PM
No--I use my PST as a grab and go.
Paul Hyndman
Reged: 07/13/04
Re: Mount PST to Dobsonian? new [Re: kfiscus]
      #5664384 - 02/05/13 09:51 PM Attachment (8 downloads)
I've used a similar approach with a CaK PST piggy-backed onto my Ha setup. It provides another aspect of the active regions as well as something for those waiting to get to the eyepiece.
Here's my 90/90/30 setup at one of the NEAF sessions. We'll be there again this April, and hope to meet up with a lot of you there!
Paul
Reged: 06/16/04
      #5664689 - 02/06/13 06:20 AM
Paul
My experience with similar "precision slow motion adapters" is that they are not very rigid. Workable for a 35mm camera with a short focal length lens but not for a scope.
11 registered and 16 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
