Re: A Quality set-up for double stars, $700 or less ?? new [Re: Jon Isaacs]
      #5791622 - 04/11/13 12:10 AM
Yup, the Double-double is a fairly easy target in a 60mm. Trapezium E and F, though, are not easy in a 3-incher. The are doable, provided that the scope is well-baffled and seeing cooperates. E and F are *much* easier in a 4" refractor; ~100-120x seems optimal. I find all unequal doubles doable in much smaller refractors than they are in larger scopes of other designs. I believe it has to do with the refractor's inherently better glare suppression. For example, I find Sirius B pretty easy in a quality 3" refractor at just under 100x. Read the double star forum posts about Sirius B. You'll see all kinds of crazy suggestions along the lines of it requiring 10" to 12" and high magnifications.
The thing about double stars is this: there are literally thousands of them visible in any sized telescope. Sure, a larger scope might let you split tighter doubles (but not always; just ask my club mates using 10" to 15" Dobs not being able to split Sirius when a 3" will do so), but there's always an equivalent aesthetic experience available in the smaller scope. In other words, you can find a double near the limits of a 3" scope that looks a lot like a dimmer pair at the limits of a 12" scope. In fact, I think doubles are almost more fun in a small scope less hampered by seeing. That said, 4" is a good compromise if you can swing it within your budget.
Reged: 06/16/04
Re: A Quality set-up for double stars, $700 or less ?? new [Re: jrbarnett]
      #5791936 - 04/11/13 08:54 AM
Sirius B is still widening... getting easier, 10 years ago it was 6 arc-seconds instead of 10 and much more difficult. When was the last time you split Sirius in an 80mm?
DaveJ
Reged: 01/07/05
Loc: NE Ohio
      #5792038 - 04/11/13 10:04 AM
Good luck finding a 4" f/15 achromat and a suitable mount for $700. In fact, good luck finding a new or used 3" f/15 with modern 1.25" focuser (rather than a 0.965" unit), at all.
Hi Jim,
Far be it for me to reveal something of which you are not aware, but here is a brand spanking new 101mm f/15 with what to me looks like a 1.25" or 2" focuser: link. The cost might be a problem, though...
buddyjesus
Reged: 07/07/10
Loc: Davison, Michigan
Re: A Quality set-up for double stars, $700 or less ?? new [Re: DaveJ]
      #5792550 - 04/11/13 02:46 PM
those skylight scopes are a wonderful scope to look at. I believe it is best to order in advance as they sold out of previous ones quickly. http://skylight.myshopify.com/
Widespread
Reged: 05/11/11
Loc: Bowling Green, Kentucky
Re: A Quality set-up for double stars, $700 or less ?? new [Re: buddyjesus]
      #5792565 - 04/11/13 02:58 PM
The brass counterbalance system looks interesting.
Reged: 06/16/04
      #5792590 - 04/11/13 03:15 PM
Hi Jim,
I think they are around $2000... big and long.... might as well get a 120mm Eon or SkyWatcher...
DaveJ
Reged: 01/07/05
Loc: NE Ohio
      #5792612 - 04/11/13 03:28 PM
Me? I'm quite satisfied with my TEC 140.
Reged: 06/16/04
      #5792671 - 04/11/13 04:03 PM
That was probably over the $700 limit too.
mark379
Reged: 02/07/09
Loc: New Jersey
      #5793349 - 04/11/13 09:45 PM
Something similar to Pat's setup may be attainable. an ed 100 on a Astro tech voyager may be the ticket. If you buy used, you should be within your budget. An ED 80 might be a decent choice as well, but a longer f/l refractor works better IMHO.
Best,
Mark
Jaimo!
Reged: 10/11/07
Loc: Exit 135 / 40° North
Re: A Quality set-up for double stars, $700 or less ?? new [Re: mark379]
      #5793609 - 04/12/13 12:12 AM
Would this scope fit the bill? 102mm f/11, I've had my eye on this for a while...
http://handsonoptics.com/index.php?main_page=product_info&cPath=1_112&...
Jaimo!
Astro One
Reged: 02/20/13
Loc: San Bernardino County, CA.
      #5793658 - 04/12/13 01:00 AM
Thanks to everyone who helped out with my query. I am now in the process of buying a 4" Orion 100ED for $400 (recommended to me by Jim Barnett). Also, I am also working on getting a Vixen Porta Alt/Az mount. Next I'll need a dovetail mounting plate, scope rings, and, an 8x50 RACI finder. I've already got eyepieces. $700 or less... well maybe just a pinch more! Thanks again for all of the help, Steve
Reged: 06/16/04
Re: A Quality set-up for double stars, $700 or less ?? new [Re: Astro One]
      #5793677 - 04/12/13 01:13 AM
Steve:
Sounds like a good rig... agenda astro generally has good prices on rings and dovetails.
Edited by Jon Isaacs (04/12/13 03:02 AM)
buddyjesus
Reged: 07/07/10
      #5793706 - 04/12/13 01:42 AM
your gonna love it! I will upgrade my achromat after I buy a big scope to complement it.
9 registered and 31 anonymous users are browsing this forum.
Moderator:  zjc26138, tecmage, rflinn68
