astrodevices
Vendor-Astro Devices
Reged: 10/26/07
Loc: Sydney, Australia
Re: NEW: Nexus - multifunctional telescope interface new [Re: tezster]
      #5465165 - 10/11/12 11:05 AM
Hello Terence,
Thank you for your comment.
I was referring to using Nexus with a motor controller like the one used on Halfhitch mounts or ServoCAT. In that case you need to use one of our utilities/applications to perform a two star alignment as SkySafari does not have a native support for Nexus.
In case of using a 'Push-To' telescope you can use SkySafari Plus/Pro for the two star alignment - in this situation Nexus does not need to calculate the drive rates and it does not calculate the current telescope coordinates (the telescope coordinates are calculated by SkySafari Plus/Pro).
A 9V battery does not last that long... It depends on the temperature and the battery type. A rechargeable NiMH 9V battery will last a couple of hours. It is certainly recommended to use an external power source like a 12V SLA/gel battery. Your 8Ah battery will last a few days powering Nexus.
Best Regards,
Serge.
rboe
Reged: 03/16/02
Loc: Phx, AZ
Re: NEW: Nexus - multifunctional telescope interface new [Re: astrodevices]
      #5465412 - 10/11/12 01:48 PM
I'd need cables from my encoders to the Nexus for my push to dob. Can you folks supply those?
astrodevices
Reged: 10/26/07
Re: NEW: Nexus - multifunctional telescope interface new [Re: rboe]
      #5465820 - 10/11/12 06:57 PM
Hello Ron,
Yes, the encoders cable can also be purchased together with Nexus. The cost varies from $15 to $25 depending on the type of encoders.
Please note that Nexus is using the same type of cable for encoders as SkyCommander, BBox, Argo Navis.
Best Regards,
Serge.
rboe
Reged: 03/16/02
Loc: Phx, AZ
      #5466564 - 10/12/12 09:36 AM
Great! I noticed they looked like the Argo Navis (on an earlier project I made mine two discreet cables vs. your siamese). I need to get cracken on my scope rebuild so I can justify getting this device. Just got the WiFi box for my NS11 and it is the cats meow.
astrodevices
Reged: 10/26/07
      #5573644 - 12/16/12 05:59 AM
Hello Everyone,
Nexus is now fully compatible with Android based devices. Nexus is acting as a WiFi Access Point and any WiFi enabled device can connect to Nexus. There is no need to jailbrake/root the device. Nexus works with Android based devices as easy as with iOS based devices.
To celebrate the festive season the price of Nexus has also been reduced by $50.
Best Regards,
Serge.
7 registered and 6 anonymous users are browsing this forum.
Moderator:  BRisley, bilgebay
