Pages: 1 | 2 | 3 | (show all)
Chris_H
Reged: 11/24/03
Loc: Norway
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: APM M.Ludes]
      #5330300 - 07/22/12 07:38 PM
23%, does that include the secondary baffle? A 23% mirror doesn't mean squat if the total CO ends up at 40% with the baffle
How come you didn't go for a DK design instead (cooling wise)?
ValeryD
Vendor (Aries)
Reged: 11/26/05
Loc: Kherson, Ukraine.
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: pbsastro]
      #5330645 - 07/22/12 11:55 PM
But I think the big key for success is cool-down time.
Roland said many times his Maks have a secret trick to make them cool much faster. I think even equivalent Aries Maks do not have this trick. That is why till now AP Maks have no competition.
Pedro
During designing of these telescopes me and Roland exchanged by handred e-mails or more, discussing all the sides of scopes construction. So, there is no reason to think that Aries' Maks are different ideologically. They are quite similar. More so, the cooling system in Aries' Maks is somewhat more efficient and our scope cools a bit faster.
However, this is only a second main point of these Maks. The main one is optical design and optics performance.
Valery.
APM M.Ludes
Vendor (APM Telescopes)
Reged: 05/01/03
Loc: Germany
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: Chris_H]
      #5330805 - 07/23/12 03:24 AM
Hi Chris 23 % C.O. total yes, as Roland and Aries also have.
DK is a cheap way doing scopes, coma like F/5 newtonians, open tubes , spiders, dusty mirrors etc etc...we let others d such systems
Chris_H
Reged: 11/24/03
Loc: Norway
      #5331073 - 07/23/12 10:20 AM
Well the Mewlon seems to pull it off so it can't be that bad!
Wow, that sounds awesome! If you master the looooong cooldown problem we face here in the north, I might just have to add this to the list as well! Going to be an expensive year...
APM M.Ludes
Reged: 05/01/03
Loc: Germany
      #5331451 - 07/23/12 02:35 PM
long cool down and after that a stable image, is far better then turbulences all night in a open Tube !!!!
Astrojensen
Reged: 10/05/08
Loc: Bornholm, Denmark
      #5331510 - 07/23/12 03:02 PM
I have a carbon fiber C8. It never cools down and has turbulent images all night...!
Clear skies!
Thomas, Denmark
Chris_H
Reged: 11/24/03
Loc: Norway
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: Astrojensen]
      #5331660 - 07/23/12 04:30 PM
I hear you, Thomas. A "long cool down and after that a stable image" doesn't work when the darn thing NEVER cools down My old 180MAK was like that - and this is a 10"!
Anyway, it will be interesting to see what you come up with Markus!
Astrojensen
Reged: 10/05/08
      #5332536 - 07/24/12 04:04 AM
There's no doubt the feat can be pulled off, making a 10" mak with relatively fast cooldown, that is. A-P did it, as far as all the reviews go. I am not sure I've seen a review of any Aries maksutovs.
It is a mystery to me why a $1000 C8 doesn't come with a cooling fan, while a $400 8" dobsonian does. That just doesn't make sense.
Clear skies!
Thomas, Denmark
APM M.Ludes
Reged: 05/01/03
Loc: Germany
      #5332629 - 07/24/12 07:41 AM
Hi Thomas
is your 8" scope build like a modern fast cool down telescope should be build ? No, everything is done on it that it never cools down :-)
EddWen
Reged: 04/26/08
      #5333014 - 07/24/12 12:21 PM Attachment (39 downloads)
Markus and Matthias recently built me a 400mm f/10 Rumak.
It has an open back tube with 3 fans. The tube has venting ports just behind the meniscus. The Astro-Sital mirror is polished on the back side for good heat transfer.
The scope has an internal heater for the meniscus which I've not had to use because it is dry in Arizona.
Cool down has not been a problem. I roll of the roof of the observatory when the Sun sets, point the scope up, switch on the fans and go have supper. An hour or so later, the scope is ready to play.
Some of this is due to our location in the high country of central Arizona. We have a rapid drop from daytime temperatures until about 9:30 – 10:00 pm. The rest of the night has a rather mild decline in air temperature. Also, the inside temperature of the observatory does not reach the outside air temperature as it is insulated.
When I considered getting the scope, I originally planned for either air-conditioning the observatory to keep it near night time temperatures, or building a mirror cooling system using Peltier devices to cool it more rapidly to ambient conditions. So far, I haven't done either. I may do the latter just for fun, as I think it cool.
I will make a thread about the scope when I have a chance. Too many hobbies, although retired.
Astrojensen
Reged: 10/05/08
      #5333223 - 07/24/12 02:39 PM
Precisely my point.
Why do they insist on doing it the wrong way? Haven't they learned anything in the last 40 years? I myself have thought of asking someone to machine a new tube for the optics, as the optics themselves are very good on this particular C8. It is very sharp and bright, but all the tube seeing almost always limit its performance. On those rare evenings when the seeing is perfect and the temperature stable and the tube is thermally stable, I've been able to use 800x on it on double stars with no image breakdown and well over 1000x on planetary nebulae.
Clear skies!
Thomas, Denmark
contedracula
Reged: 10/11/11
Loc: Queens, NYC and Sarasota FL
      #5420541 - 09/14/12 08:20 AM
Hello Markus,
have you good news about the project?
Seems to be a RR of Planetary Mirror Telecope, can you tell me the progress?
Gianluca
Sarkikos
Reged: 12/18/07
Loc: Nyctophobia, Maryland, USA
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: contedracula]
      #5420612 - 09/14/12 09:19 AM
I wonder how this would compare to my 10" f/4.8 Newt which is already running at 23% CO?
Sarkikos
Reged: 12/18/07
      #5420617 - 09/14/12 09:24 AM
A maximum weight of only 29 to 30 lbs for a 10" Mak is very impressive.
My 10" Newt solid-tube OTA is about 39 lbs with rings and balancing weights.
Sarkikos
Reged: 12/18/07
      #5420628 - 09/14/12 09:32 AM
Thomas,
I have a 6" Rumak. It takes longer to acclimate than my 10" Newt which does have a fan for the primary mirror. I suppose I could take the Rumak apart and drill holes along the meniscus for venting. But I'm reluctant to disassemble a Mak. I've never done it.
My 90mm Mak has a flippable secondary. Not a good design IMO, but it does allow me to keep one of the ports open for quicker cool-down and thermal adjustment during the night. I've covered the open port with screen to keep the bugs out. Now, how difficult would it be to design Maks with large vent holes with protective screening at optimum locations to allow acclimation, and have slidable covers built-in that can completely cover the holes if needed?
However, I take my Newts apart all the time for upgrades and tinkering. Easy sneezy. I've already drilled vent holes above the upper edge of the primary in my 8" f/6 Dob and installed a baffle above the holes to help direct rising warm air out of the vent holes. I'm thinking about doing the same thing for my 10" f/4.8. Nothing to it.
contedracula
Reged: 10/11/11
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: Sarkikos]
      #5421454 - 09/14/12 07:32 PM
I've C14HD and becames in cool down about 3 hours!!!!
The MN78 with one rear fan, only 15 minutes
Gianluca
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #5422133 - 09/15/12 10:41 AM
Gianluca
There are fan solutions for the Edge HD scopes.
Edited by BRisley (09/15/12 05:27 PM)
Sarkikos
Reged: 12/18/07
Re: 10"F/4.6 MakCass with 23% C.O. new [Re: EFT]
      #5422156 - 09/15/12 10:53 AM
Pretty much what I said should be done with these Maks. But it should be done at the factory!
contedracula
Reged: 10/11/11
      #5422227 - 09/15/12 11:41 AM
@Ed
I got it! ;-)
You have a PM
Gianluca
Sarkikos
Reged: 12/18/07
      #5422400 - 09/15/12 01:52 PM
Yep, that's the ticket!
3 registered and 5 anonymous users are browsing this forum.
