SteveRosenow
Reged: 07/10/12
Loc: Shelton, Washington
Re: BackyardNIKON, ask me anything! new [Re: JoseBorrero]
      #6339546 - 01/27/14 08:09 PM
I own a D5100 and will gladly beta test.
What cords are needed?
I may need a 50-foot run of whatever is needed, as my telescope is outdoors. >_<
guyroch
Vendor (BackyardEOS)
Reged: 01/22/08
Loc: Under the clouds!
Re: BackyardNIKON, ask me anything! new [Re: SteveRosenow]
      #6339720 - 01/27/14 09:35 PM
The D5100 does not support BULB over USB so you will need both a USB cable for camera control and a serial cable for BULB.
Thank you
Guylain
end
Reged: 08/31/11
Loc: Houston, Texas, USA
      #6339970 - 01/27/14 11:52 PM
Q1:How will you support long (>30second) exposures for Nikon's that don't support bulb over USB? How about mirror up mode?
Q2:Any chance that your current BYEOS customers will get a discount on BYNikon pricing?
guyroch
Reged: 01/22/08
Re: BackyardNIKON, ask me anything! new [Re: end]
      #6340391 - 01/28/14 08:41 AM
A1: With a serial cable, there is no other way. This is the same for older Canon cameras. The jury is still out on mirror lock for BackyardNIKON. I have not toyed with it just yet.
A2: Yes, most likely, but I don't know how much of a discount yet. Probably between 15% to 30% off... but I won't commit just yet.
Guylain
James_826
Reged: 02/09/12
Loc: Beggs, Ok
Re: BackyardNIKON, ask me anything! new [Re: Seanem44]
      #6340487 - 01/28/14 09:31 AM
Would the D300 be supported?
guyroch
Reged: 01/22/08
Re: BackyardNIKON, ask me anything! new [Re: James_826]
      #6340695 - 01/28/14 11:09 AM
The D300 does have an SDK so it should work.
Guylain
end
Reged: 08/31/11
Re: BackyardNIKON, ask me anything! new [Re: guyroch]
      #6340932 - 01/28/14 12:47 PM
Thanks. Which serial cable would you recommend?
guyroch
Reged: 01/22/08
      #6341040 - 01/28/14 01:38 PM
Well, this is where it gets tricky with Nikon.
Most cable vendors will use infrared instead of a hard wired cable endt-to-end. The issue with infrared is that you need the infrared beam to be pointed at the camera all night long, a bit of a nuisance.
Shoestring Astronomy has a Nikon cable that will fit most Nikon with their DSUSB unit. I'm about to purchase one myself for testing.
Hope this helps,
Guylain
end
Reged: 08/31/11
      #6341078 - 01/28/14 01:54 PM
I have considered the shoestring option in the past. I figure I have waited this long, I can wait a bit longer. After you have released BackYardNikon I'll buy whatever serial cable solution you feel works best.
Here is another question. I don't know how common an issue this will be, but I have both a Canon and Nikon and ideally I'd like to be able to take pictures with both simultaneously. Do you expect that both BackYard options will be able to work together?
guyroch
Reged: 01/22/08
      #6341158 - 01/28/14 02:28 PM
Depends what you mean by "work together"?
Guylain
end
Reged: 08/31/11
      #6341640 - 01/28/14 06:50 PM
I just mean, do you expect that I could have both programs running on one computer simultaneously and collecting data at the same time. For example what I'd like to do is image with my C11 and AT65EDQ at the same time so I can have both a wide field and high magnification image of the same target at the same time. They don't need to talk with one another but they would need to stay out of one another's way.
guyroch
Reged: 01/22/08
      #6341735 - 01/28/14 07:39 PM
YOU BET
One won't even know (or care) that the other one is running
Guylain
rob288
Reged: 05/13/08
Loc: South Canterbury, New Zealand
      #6342079 - 01/28/14 11:08 PM
Great news will be great to use your software with our Nikon D800's, versions 3 is looking great for Backyard EOS 3 premium, thanks for all the effort you put in.
EFT
Vendor - Deep Space Products
Reged: 05/07/07
Loc: Phoenix, AZ
      #6342646 - 01/29/14 09:38 AM
Guylain,
Do you have a list of which Nikon cameras support BULB over USB? I know my D90 does not but I think that my D100 does.
Ed.
guyroch
Reged: 01/22/08
Re: BackyardNIKON, ask me anything! new [Re: EFT]
      #6342692 - 01/29/14 09:59 AM
Only the latest models do sadly.
The D5200, D5300, D7100, D800 does support bulb over USB AFAIK. I'm assuming all cameras built after these models will.
The D5100 and D7000 do not. However, they have better sensors for astronomy. So it all depends what your goal is.
I believe none the D## (2 digits) model support bulb over USB.
Hope this helps,
Guylain
SteveRosenow
Reged: 07/10/12
      #6347335 - 01/31/14 02:28 PM
Question for you.
How long of a cable set would I be able to work with?
Reason I ask, is that my tripods are a good 40 feet or more from the house, and if I can at least control the manual guiding, I can let the computer control the exposures from inside the house.
Is there special hardware that would allow this?
guyroch
Reged: 01/22/08
      #6347389 - 01/31/14 02:59 PM
For USB cable anything longer than 10 feet you should get an active repeater cable.
Guylain
skywolf856
Reged: 01/25/08
Loc: SE Michigan
      #6348141 - 01/31/14 09:56 PM
Would the older D80 have a chance?
Mine does use a wired remote.
guyroch
Reged: 01/22/08
Re: BackyardNIKON, ask me anything! new [Re: skywolf856]
      #6348204 - 01/31/14 10:37 PM
It should
Thank you
Guylain
Whichwayisnorth
Reged: 07/04/11
Loc: Southern California
Re: BackyardNIKON, ask me anything! [Re: guyroch]
      #6352280 - 02/02/14 11:16 PM
BackyardNIKON
BackyardNIK
NIKBackyard
NIKBack
Nickleback
There you go. For now on I am calling it Nickleback.
4 registered and 8 anonymous users are browsing this forum.
