kenneth john
Reged: 07/06/06
My name is Ken and I live not far from portsmouth,UK I have just brought a second hand 10 inch lx200 classic ,and wondered if any one could help me. I have been looking on the Internet for some information about a problem I have with this telescope but no luck so far,the problem I have is in right ascension,when I put the R.A. Lock on,I find that their is still some play,I can move the arms left and right about 5mm.any help to over come this would be much appreciated as I would like to have a go at astrophotography.
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
Your lock is possibly getting warped. You can either unwarp it yourself or you can send it in to get repaired. I had the same problem crop up with a LX200 I owned. I choose to part the scope out since I didn't want to pay to get it repaired or do it myself, also it was an excuse to get a bigger telescope. When you store the telescope store it with the locks unlocked, also when you transport it keep the locks unlocked.
-------------------- Preston
Celestron 11" Nexstar GPS XLT
Lunt LS60T/Ha 60mm f/8.33 (on order)
It’s not finishing something when your tank is empty that makes you a stronger person. It’s brushing yourself off and refacing the foe that defeated you with the same determination and willingness to fight that you had when you began your journey.
kenneth john
Reged: 07/06/06
Hi: what do you mean by warped
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
It could also be loose. Loosen the set screw on it, rotate the lever back a bit and retighten.. See if you can lock it any better that way.
-------------------- Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
kenneth john
Reged: 07/06/06
Hi Jeff,the RA locks but their is still a couple of degress movement and no more.
Ben Ritchie
Lost in Space
Reged: 01/31/05
Loc: Bosham, UK
Hi Ken, welcome to the forum - i'm just along the coast from you.
-------------------- Astro-Physics 130EDT StarFire, 80ED (x2), 305mm f/5 dob, VLT
Astro-Physics 1200GTO, evolved HEQ5/pro
Coronado SM60/BF10, 3-6 Nagler zoom, 8 & 13 Ethos, 28UWAN
kenneth john
Reged: 07/06/06
Hi: BEN As you can see i am having a bit of trouble at the momment with this access play in R ascension.looked all over the web to try and get some answer's but so far no luck.nice to here from you ben.
Bill W.
Reged: 10/09/05
Loc: Western PA, USA
As Jeff said your RA clutch may be loose. When the RA lock is locked look at it and there is a small allen wrench screw. Loosen your allen wrench screw then release your RA lock and move it counter clockwise a little bit. Then retighten the screw. Now relock your RA and see if it still has play in RA. I just had to do that last night. Mine was slowly working loose. Don't go too aggressive on the adjustment.
-Bill
-------------------- Orion Atlas EQ-G (EQMOD), SBIG ST-2000XM & AO7
Stellarvue SV66ED
Skunk Hollow Observatory
NeoDinian
Reged: 10/05/05
It after that, it still moves, open up the base and check the gears and engagement of them. You may have worn gears, or little engagement. If so, look into a set of Bucks Gears.
Rockford, Il.
Coming soon:
kenneth john
Reged: 07/06/06
After some of your comments i decided to take the base of the bottom of the scope,and their lay the problem, the two screws that hold the worm gear housing were very loose, so i tightened them up,and now all the play has gone,
NeoDinian
Reged: 10/05/05
Easy find, Easy Fix...
Glad it was nothing serious.
Rockford, Il.
Coming soon:
Bill W.
Reged: 10/09/05
That's great news!
-Bill
Stellarvue SV66ED
Moderator: Joad
