Privacy Policy |
Please read our Terms
of Service | Signup and
Wes James
Reged: 04/12/06
I recently purchased a pair of Vixen BT80M binoculars that need a bit of touch-up on the collimation. Anybody have any assistance to offer here as to how to do it? Can it be done by a user? Searched the site, found nothing- when I Googled the subject, I came up with a couple of hits for the instruction manual for these- but nothing clicked when I tried to view it. Indicated it had downloaded a file, but it wouldn't display. I'd appreciate any help anyone has to offer on this topic. Have touched up my Oberwerk 25x100's hope it can be done as easily!
-------------------- Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
Edited by Wes James (08/06/06 06:28 PM)
cota_scope
Reged: 05/16/04
Loc: sioux city ia
try looking underneath the rubber grip around the prism assembly, there might be some collmation screws not for sure though.or there might be some tiny collimation screw around the bottom of the helical focusers, regards john
zx12
Reged: 12/29/05
Loc: Rhode Island
Hi Wes,
I have a set of Vixen BT 125 binos that use interchangeable eyepieces like your BT80. The instruction sheet that is provided with it gives a simple solution to slightly mismatched images at higher magnifications. Basically, you unlock the collar and rotate either eyepiece until the images merge. Try it while viewing Jupiter as it helps to have a target that is somewhat bright and sharply defined. It works very well in my Oberwerk BT 100 as well. This should solve your problem unless you have a severe alignment issue with either the prisms or the objectives themselves.
-------------------- AP 160 Starfire/AP 1200GTO
Stellarvue SV809D
Vixen BT 125 HFT-MA
Oberwerk BT 100/45
Tak 22x60 Astronomer
Nikon 10x70 FMT-SX
Leica 8-12x42 Duovid
WO 66mm SD
Wes James
Reged: 04/12/06
Thanks for the reply, John- and Mike as well. I tried rotating the eyepieces last night- and did it, as a matter of fact while looking at Jupiter! The moons provided a good target. It didn't really help- however the eyepieces I'm using are matches Sieberts... and, assuming they really are closely matched, might not make much difference being rotated- I don't know. Simply speculation on my part. However- I did find- this afternoon- instructions on these bino's online, and they have collimation instructions- so will have to have a closer look and see what they say. Should be able to correct the problem with them, thank goodness! Thanks for the replies, guys-
Atlantic Beach, FL
Wayne Parrish
Reged: 02/23/04
Wes, What was the link to instructions on collimating the BT80.s ? If you'd rather I can send a PM. Thanks, Wayne
Wes James
Reged: 04/12/06
Hi, Wayne- The link was: http://www.buytelescopes.com/container.asp?dest=/manufacturers/vixen/vixen_product_pdf.htm Wes
Wayne Parrish
Reged: 02/23/04
Thanks Wes ! I have saved it for future use.Now that I know how to collimate them I may try another pair. Wayne
9 registered and 21 anonymous users are browsing this forum.
Moderator: EdZ
