harryS
Reged: 12/24/05
Hi everyone
I have a cheap pair of Bresser Binos..Yesterday they fall on the ground and since then I see everything double through the binos... Can I fix it somehow or it is not worth it?
refractory
Reged: 02/05/05
You can always use them as a salt an pepper shaker.
Jess Tauber
EdZ
Professor EdZ
Reged: 02/15/02
It doesn't cost anything to attempt to fix it. read Collimation.
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Wes James
Reged: 04/12/06
Edz is right- what have you got to lose? Study online/search out binocular repair to find what you can- and then see if you can figure out what's wrong- and what you can do to correct it. Could be some inexpensive experience you gain. Nothing ventured- nothing gained. Would love to take apart a pair of binoculars just to play with them- see how they're put together/adjusted, but certainly wouldn't do it with a good pair.
-------------------- Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
Sarah88
Reged: 11/18/05
First of all Harry - check to see if the barrels are straight - I've seen a pair of cheap binos get dropped, and one barrel ended up askew, where it fits into the prism housing.
(plastic barrels - one had been knocked a bit sideways, and wasn't seated properly in it's thread)
Unscrew em both, then back in, and make sure neither has got cross-threaded.
Worth checking out before you try fiddling with collimation screws.
-------------------- ED100, OD250L
15x70, 10x50, 7x50
54.7N 2.7W
Edited by Sarah88 (08/07/06 01:10 PM)
upsguy
Uff da
Reged: 10/01/05
Loc: schaumburg, il.
my 7 year old has a "cheap" pair of 7x35 that i borrowed when i went to a wrestling meet with my older son.when i opened the door to my truck and picked them up from the front seat, i dropped them. one of the barrels hit the curb first and when i checked them, they were really bad. angry with myself, i reacted so fast by banging them on the curb, hitting the same barrel on the other side and actually collimated them that way
-------------------- Jim
Meade lx90 8" uhtc
Meade 80mm refractor
Orion 70mm refractor
Barska 15x70
Obies 11x56
Canon 400D
Canon SX100IS
harryS
Reged: 12/24/05
thank u all for your replies
harryS
Reged: 12/24/05
after all it was what Sarah said...the barells were plastic and one was off position...I unscrew it, put it back and everything is ok now...
Thank u Sarah
pcad
Reged: 01/17/05
Loc: Connecticut
Sarah,
Well done, good advice.
Peter
-------------------- Peter
Telescopes 25 - 318 mm
Binoculars 15 - 88 mm
Microscope 50x - 1000x
BillC
on a new path
Reged: 06/04/04
Loc: Washington, USA
>>>. . . hitting the same barrel on the other side and actually collimated them that way ---------------- jim<<<
Hi Jim:
Do you mean you collimated them OR made them better than they were?
Bill
-------------------- William J. Cook, Chief Opticalman, USNR-Ret.
Founding Editor, Amateur Telescope Making Journal
johnno
Reged: 05/03/04
Hi Bill,
There you go,
No Need for experience,just bang em on the ground,Collimation,Spot on.
No need to tell you, I am only Joking.
Best Regards. John
upsguy
Uff da
Reged: 10/01/05
Hi Jim:
Bill
i figured i'd use the word collimated. after they fell i was gonna throw them out, but since the views were acceptable (for what they were) i just whacked them and they straightened out pretty good. i can't say the views are better, but i can't tell the difference before or after. probably just a freak deal.
Meade lx90 8" uhtc
Barska 15x70
Obies 11x56
Canon 400D
Canon SX100IS
DJB
Reged: 02/23/05
Hi Wes,
I bought a SARD SD Mark 21 binocular last year--fungus was having a good time living in them! This is an older WWII unit.
Anyway, I did a cut away, as I mentioned once before on the forum. By that I mean, I cut the binocular in two halves. Then, I cut about 45% of the one half away. This left a very nice presentation of EVERYTHING inside.
This project took me five nights to complete the project. Three nights were required just to refine the edges of the metal and the lenses plus the touchup paint. I must say that it came out to be exactly what I had envisioned.
Perhaps you could too.
Best regards, Dave.
