Don25
Reged: 10/20/03
Loc: Delaware, U.S.A.
Adjusting focus on right eyepiece
      #1087548 - 08/10/06 01:06 PM
Quick question...
To get the adjustable right eyepiece (diopter) to yield best focus, on most Binoculars....do you guys tack up a sheet of Newspaper, or use some type of testing pattern, that you place a certain distance from your binocular, to really get the right side "dialed-in"??
I just got a new Pentax Papilio (6.5x) Binocular, and I'd like to know what type of "system" you use for getting the right side eyepiece to correctly match the left side. I usually just tack up a newspaper, some distance from the binocular, but I'd like to see if someone has a better Mouse-Trap.
Don
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Adjusting focus on right eyepiece new [Re: Don25]
      #1087563 - 08/10/06 01:13 PM
I focus each eyepiece on a fairly close but easy double star.
That might not be the preferred method with a 6.5x papillio
edz
Don25
Reged: 10/20/03
Re: Adjusting focus on right eyepiece new [Re: EdZ]
      #1088322 - 08/10/06 09:08 PM
EdZ, that's a possible idea, I didn't think of that one. I'm pretty impressed with the Papilio's so far as a general use, up close/Museum/Insect binocular. I have an older pair of Swift Audubon ED 8.5x 44 for the other stuff.
Don
patter1
Reged: 01/19/05
Loc: Canada
      #1088347 - 08/10/06 09:23 PM
I suspect that stars or double stars will show how well you're focused, better than anything else.(when I focused my binoc to infinity as perfect as I could in daytime, under the stars I found I was off a bit).
Congrats on the Papilio 6.5, I'll bet the low magnification and all the benefits that go along with that make it a joy to use in the daytime (and indoors!). I was thinking of getting one but I really needed at least 18mm eye relief and a smaller body, so I got a roof prism 8x25 instead.
Patrick
8" f/6 NewStar dobsonian
Orion Starblast 4.5" f/4 mini dobsonian
42mm SuperView, 17mm Nagler T4, some other cheapies
Omcon 7x50, Oberwerk 11x56, Olympus DPS-R 7x35, Olympus Magellan 8x25
homemade 50mm right-angle bino-scope prototype
Don25
Reged: 10/20/03
Re: Adjusting focus on right eyepiece new [Re: patter1]
      #1088816 - 08/11/06 07:42 AM
Patrick,
So far I'm pretty happy with the Papilio's. I've just used them a little around the House for checking out the Butterfly's on the Butterfly Bush. I think when I've used the Swift's for Astronomy, I had the same thing happen as far as the focusing being off a little; i.e. the focusing was off a little bit compared to using them at night.
Don
6 registered and 13 anonymous users are browsing this forum.
Moderator:  EdZ
Home
