msc
Reged: 08/10/06
Advantg/Disadvantg of BV/Binoc
      #1095248 - 08/15/06 02:40 AM
(moderator note) In response to the Binocular Summation thread Binocular Vision Summation
came this reply. Here shows title change and cut to new thread. edz
Ed, truly an amazing job.... I understand all the components here, but never really grasped the full macro view that you have provided.
I am curious how all this applies to bright daylight terrestial viewing.... i.e. bino viewer (BV) vs. binoculars. Let me take a stab at it, see if I digested everything, correct me, add some thoughts, etc.
1. During daylight viewing, the min. light loss of the binoviewer is not an issue. But the wider scope apt. will allow you to acheive higher magnifcations with less aperture diffraction vs. the smaller (but equivalent) binocular apt. Chalk this up to a huge PRO for the Bino viewer vs. the binocs.
2. The BV/Scope with bigger apt., will produce wider exit pupils (per equivalent binocular), but considering the brightness levels, the wider exit pupils are a welcomed benefit as they will only be slightly greater than eye pupil, making it more comfortable to hold the view in each eye. Of course, this is a general statement and varies based on what magnifications you are dealing with.... I am using 40 - 60x, as anything less than this, well, you wouldn't be handling gear this big to begin with. Since the exit pupil is now slightly bigger than the eye pupil, there is a slight increase in diffraction and light loss, but this is minor compared to the ease of viewing, IMO. This is quite the opposite of astro viewing where the eye pupils are huge and the exit pupils are tiny (from very high magnfication) Another PRO for the BV/Scope.
3. Bino viewer has interchangeable EP's, and you can vary the AFOV and TFOV based on your needs. At best you might have two choices with a binocular, if any. (always referring to the big binocs, 40x100 range) Another PRO for the BV/scope.
4. Since you're only buying ONE objective and ONE tube, you can end up with higher quality glass and a more compact package with the BV/scope for the same dollars spent. Of course this varies with what you're comparing, you can't select a 200mm refractor for comparison :-) It must be within reason here. Another PRO for the BV/Scope.
5. With a BV, you only have one objective, this reduces the risk of mismatched magnifications causing retinal rivalry, or stressful fussing the two images. Also, with two objectives spaced very far apart, (much greater than IPD), many suffer from ill effects such as cardboarding, (3d subjects appearing 2d) and spatial relationship issues, and also improper perceived size of objects for some how are hyper IOC sensitive. Many suffer these ills from improper stereo vision but are never able to quantify why they get a headache or stress in their eyes. Again, a PRO for the BV. BTW, its remarkable how powerfrul the 3d effect is with a BV.... considering there is no stereo to begin with. The brain is obviously fooled.
I can list some other advantages of BV for terrestial use, but I would consider them less significant, such as easier to mount BV, easier to point upward, some scopes like Borgs break down for easy travel, scope can provide super high magnification views, can be used for photography, etc. etc.
Now, can someone give me some binoc. PROS, or BV CONS, for terrestial use? Of course, in the magnfication ranges we are talking about here. Seems to me, the BV is one heck of a daytime terrestial viewer! TYIA
Edited by EdZ (08/15/06 11:49 AM)
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Advantg/Disadvantg of BV/Binoc new [Re: msc]
      #1095381 - 08/15/06 06:34 AM
Light loss is only not an issue if you choose not to address it. In bright light it's not, but in twilight it would be an issue. Could be the difference in seeing your target or not. Equal sized apertures = 40% light loss in BV. Equal sized exit pupils equal 50% brightness loss in BV. But both at non-comparable magnifications.
Well, anytime you go to a wider exit pupil than eye pupil you have a reduced effective aperture. In addition, you would need to deal with the sometimes uncomfortable long eye reliefin the BV to get exit pupils that large. However, if you are comparing wide exit pupils, one would need to assume you are already comparing to a binocular with an equally wide exit pupil and hence there would be no gain. And of course binoculars with equally wide exit pupils would be twice as bright. But all that said, normal lowest power BV usage gives some indications that it might be fair to say when using scopes of about 6" to 8" or larger, a BV is not getting much below 50x to 60x, at least not without vignette, therefore generally cannot achieve such large exit pupils, unless of course you start with a much larger scope than binocular, which would void this comparison.
To keep within reason for comparison, some Binocular Telescopes have nearly unlimited choices of eyepieces. Mine do. Compare similar equipment.
A BV/scope/mount/counterweight/tripod is certainly not more compact than a binocular telescope/tripod. And I'd say it's a real stretch to assume always because you only have one aperture it is higher quality. An easy counter to that statement could be, it is much easier to figure a smaller aperture, therefore you could always have a better shot at getting a higher quality system with the two smaller apertures.
Interesting. Hadn't heard this before, although I don't doubt it. But you need to pick a side, like you did with everything else. If people have trouble with stereopsis, it's likely they'll have the same trouble with both instruments. Or, if binoviewers don't create the effect of stereopsis, then how do so many people claim to see it? You can't have it both ways.
Well, some other things to consider with a binoviewer; sometimes the BV does not have maximum clear aperture to use wide field-stop lower powered eyepieces without significant vignette, therefore in most cases you could never reach the same lower powered views without significant light loss due to vignette. Generally, the longest eyepieces that can be used in a BV without vignette are about 30mm, unless you have a significantly higher priced BV with a larger clear aperture. You need a BV with clear aperture of 27mm to use a 30mm eyepiece. Some BVs have only 21-22mm CA, limiting use without vignette to about a 24mm plossl. So if you try to put a 40mm or 50mm eyepiece in your BV to get same size exit pupil as a binocular, you are cutting off far more light than you think. Fixed power binoculars don't have this problem as most employ the use of about 20mm eyepieces. My binocular telescope has clear aperture at the prisms (IIRC) about 28mm. (Read my previous post on Issues with Exit Pupils.
Also the beam splitters in some BVs do not split light equally 50% to each side. There was recently a full comparison set of photos showing the differences in light between sides of various binoviewers. Even a small percentage difference in the light delivered to each eye will somewhat reduce the affect of binocular vision. A difference in 2% from equal or 50% split is a difference of about 8% in the light between the two sides of the BV.
It's easy to list advantages/disadvantages when you pick only one side. But it's not nearly so easy to claim any advantage when you analyze both sides against the same criteria. My point here is not to belittle binoviewers over binoculars, but only to show that the simple points above all have two sides and either side of the coin can be selected and supported using the same points.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
msc
Reged: 08/10/06
Re: Advantg/Disadvantg of BV/Binoc new [Re: EdZ]
      #1096155 - 08/15/06 04:10 PM
Sheeesh, I posted this to the other thread, but it got lost in cyberspace, luckily I did not loose it.....
edz, thanks for the comments. I can understand why you felt I was being biased towards BV, but in reality I am not, I just could not find too many disadvantages of the BV / Scope, albeit in the the tiny segment I presented it in - mainly, bright light day time terrestial viewing. Hence why I begged for the opposing positions I may have missed. I want the feedback, trust me, it will help me in my purchase decisions and add to the enjoyment of viewing. Nothing like bad gear decisions :-)
But even after reading your comments, I still suspect that if the BV/scope has a sweet spot compared to binocs, its clearly in the bright day light terrestial viewing. It would be interesting to see a matrix of the different uses, then highlighting the pros / cons in each of the viewing situations; bright day light, twilight and dark astro viewing.
Your comments.....
As for not addressing light loss.... I should have been more clear, in this comparison, one would always select a wider aperture scope vs. the Binocs, to level the playing field..... I was thinking more in line with equal size physical packages.
> In addition, you would need to deal with the uncomfortable long eye relief.
ed, can you please explain what this means? Are you suggesting long ER offered by EP's is uncomfortable? Why? Just because an EP has longer ER, doesn't mean you have to use it, (you can still move closer to the glass then the ER value, right?), of course the longer ER would benefit spec wearers. In addition, the ER is set by the EP design, so if one wants short ER, then select EP's with such? Based on your comment, I feel I am missing something here....
What binocs have unlimited EP selection? Interesting....
Stereo issues.... what stereo problems are being described with the BV? I am interesting in knowing. I agree BV's also can have stereo issues, however, their is less potential for problems when you have only ONE objective, that was my point. Of course, there is lots of potential with problems with a poorly designed BV also. In addition, having two EP's from a different batch of lenses, can also produce different magnfications for each eye, another source of retinal rivalry. The liklihood of this is actually much greater in a BV vs. high end Binocs, as I am sure the Binoc maker examines this issue in QC. Not true with BV, its a hodge podge of pieces, assembled after the fact. So chalk one up for Binocs here... :-)
Excellent point regarding clear aperture issues with BV. In my scenario, I only considered the shorter EP's at 40x magnfication and higher, as when going lower power than this, a huge rig is not the best tool....but sometimes its all you have, so your point is duly noted.
Again, I was not belittling binocs, but rather picking a slim area of use (bright daylight), which still seems to favor the BV system by a little bit, at least IMO, so far. (obviously with larger apt. then comparable binocs). Hence the reason I was soliciting the Binoc PROS, or some BV CONS, which I appreciate your contributions.
Ed, your description of false exit pupil is a VERY clever finding, something most people would have surely overlooked. You should be credited with "coining this phrase", as I am sure we will see it often in the years to come, as the BV is opening up huge possibilities for two eye viewing to the scope market.
It seems the false exit pupil is sort of, an anomoly that is a by-product of tinkering with stereo vision. (i.e. one objective, but two EP's) I kept thinking of the implications this false exit pupil would create.... And as you stated, it seems this becomes an issue at low magnfication as exit pupil becomes much larger than the eye pupil, creting an over riding source of diffraction, (eye pupil diam).
However, even at very low magnfications and 50% larger Scope apt vs. binoc apt, I can find no examples where the added diffraction of the eye pupil will degrade the view lower than 265 lp/mm projected on the retina, which is more than the eye can resolve. Of course the Binoc will deliver higher rez as the eye pupil is much less (or not at all) the limiting diffraction factor. But after 200 lp/mm the human eye can not appreciate any more resolution. So this issue seems academic only. Would you agree with this assessment for daylight viewing?
Now for twilight viewing, this is NEVER an issue as the eye pupils is much wider diameter, eliminting the potential shortcoming.
I welcome any input...... specially some good insight on binocular systems.... I need to go study more at bigbino.com
EdZModerator
Professor EdZ
Reged: 02/15/02
      #1096229 - 08/15/06 04:51 PM
I refer to the long eyerelief of eyepieces such as 30mm and 40mm plossls. It's not bad enough to try and get your eye centered to eliminate the kidney bean of these long eyepieces. It's even harder to eliminate it when you are trying to do the same in two eyes. Therefore very long eye relief eyepieces that are prone to kidney bean issues are not always good choices for binocular viewing. edz
BTW, the eye relief distance, or exit pupil distance is the point at which you would see the entire filed of view and see all the light from all the rays. You do not see all at any other point.
One of your points in your first post was about how the BV can achieve large enough exit pupils to rival the brightness in a binocular. My whole point is there are very few if any eyepieces that will permit you to do that. The ones that will are not suited or are not easy to use for binocular vision. edz
Anumber of the Oberwerk BT models are non-proprietary, and some of the APM and other similar BTs from other distributors are the same. The Miyachis have limited proprietary choice, but include several selections. I believe the Vixen BTs are non-proprietary. edz
The binoviewer presents a binocular image to the eyes and hence to the brain. Stereopsis is a function of binocular vision. Do you think it would be that much different in a BV vs a binocular? edz
This is an issue shared equally by both instruments. Most of my eyepiece pairs were NOT bought at the same time and I don't have any issues with magnification. edz
I'm not sure where your going with these numbers here, but to see 200 line pairs per mm in a binocular that would probably not focus closer than 100', would take you a MINIMUM of near 300x in a 16" aperture. For the apertures and magnifications being discussed here it might be better to think in terms of 60x to 50x to see 40 lp/mm to 50 lp/mm.
For a 100mm binocular telescope at best you could see 40 lp/mm if using about 60x to 70x. For an 8" scope with binoviewer, you'd be able to see 80 lp/mm, but you would need about 140x to see it. These are about 1.5mm exit puils. raise the exit puil to 3mm with these same instruments and you would only be able to see 20 lp/mm or 40 lp/mm. Raise the exit pupil to 6mm and the line pairs you would be able to see would be down to 10 for the 100mm binocular and 20 for the 8" scope. edz
Edited by EdZ (08/15/06 05:51 PM)
photonovore
Moonatic
Reged: 12/24/04
Loc: tacoma wa
      #1096506 - 08/15/06 06:52 PM
I feel the only advantage that's really demonstrable of BVing is in telescopic viewing vis a vis monocular viewing at magnifications where the diffraction limit becomes accessable. Binocular telescopes will provide more illumination (per given aperture) but whether or not this is practically advanatgeous depends upon what the target's intrinsic brightness is--one must maintain photopic illumination levels to maximize acuity after all but on bright objects this isn't really much of a practical problem as there is already a surplus of light to work with up to 50x/inch magnifications anyway, beam split or not.
If the exit pupil becomes larger than the eye pupil the diffraction limit of the image is always that of the of the fraction of the telescope pupil still accessed by the eye. In such a case the smaller eye aperture vis a vis the exit pupil effectively stops down the telescope pupil (primary aperture) by whatever the ratio of reduction happens to be. For example, a 5mm exit pupil accessed with a 3 mm eye pupil would reduce the diffraction limit of a 5" telescope to that of a 3" aperture. However at the magnification scales possible in such a situation the diffraction limit of neither size aperture is accessable anyway! So it's pretty moot in astronomy except as this situation affects brightness reduction, which is significant.
Mardi
4" achromat, ETX-70.
Whitepeak Lunar Observatory Website
msc
Reged: 08/10/06
      #1096603 - 08/15/06 08:03 PM
Ed....
For some reason, I never experience this. When I view through an EP with 20mm ER, but locate my pupil at 5mm position, I see the entire image circle? What am I missing here? I have read this ER statement in many places... and I always interpreted as meaning, you can NOT go further back than the ER position, but surely not a problem coming closer to the glass?
Can you please give me some examples here.... I am not understanding what you are saying....but I think there is something important in this message. I was referring to getting larger exit pupils through the BV, since it has a larger apt, was that your understanding?
YES, I DO! I have spent many years researching stereo effects... and their is a huge reduction in stereopsis effects when you use one objective vs. two. I mentioned some of them earlier.... but to be specific, these issues would not surface for astro viewing.... only close terrestrial viewing. My point regarding mismatched magnifications is.... binocular makers (at least higher end) will check magnifications of each optical train to be within a tight tolerance before shipping the product. Whereas with BV, this is not the case since the user is assembling the components.... so more potential for problems, but most good EP's probably have strict QA also, so it may not be an issue....but, there is no real reason for RP makers to keep tight tolerances on fl, unless it was known prior the EP's were to be used in stereo. Of course, for Astro, even slight mis matched magnification, the brain can easily overcome... again, terrestrial viewing runs the bigger risk here.
Often the outcome of these problems are never quantified by the users, as they do not have the knowledge to ascertain what is occurring.... instead, what you hear is... I don't like the BV, it gives me a headache, I get slightly lightheaded, my eyes hurt, etc. etc... all symptoms, based on how bad the stereo issues are and how sensitive the user is to the stereo issues, these symptoms can surface in minutes, or maybe not for several hours, so its a mixed bag. Just something for people to be aware of....
As for seeing 200 lp/mm ..... sorry I was not more clear. I referring to the diffraction limited resolution caused by the aperture diam, i.e. comparing binocs vs. BV. For example.... the most the eye can theoretically resolve is 200 lp/mm. (of course this varies on many factors, as we are human, we age, etc.) The 200 lp/mm is based on cone density of the retina.... so whenever a projected image is above this range, the eye /brain can not appreciate any more resolution. So based on your previous thread, you mentioned the effects when the exit pupil is greater than the eye pupil. This creates a new diffraction limited apt to be considered. So I ran some scenarios to see if this newly introduced, eye pupil diffraction, ever degrades the projected image below 200 lp/mm. If it did, this would be strike against BV/scope combo as the false exit pupils could diffract the views, while the binoc view would not do the same, as the exit pupils are true.
(formula compliments of Jared)
Scenario 1 - (worst case) Very bright light terrestrial viewing, using BV, I will assume the smallest possible pupil diam. is 3.0mm, as the BV robs half the light to each eye... so to calculate the projected lp/mm to the retina...
Variables…
3 diam, mm eye pupil
550 fl scope
100 aperture scope
100.0 EP fl, mm
6 x - magnification
17.0 eye fl
94 mm, effective fl of entire optical train
0.9 f stop of entire system
1,500 diffraction constant
1,604 lp/mm projected on retina
18.2 mm, Exit Pupil diam.
0.17 eye pupil/exit pupil, diffraction factor
265 lp/mm projected on retina
after pupil diffraction if any.
In this case, the larger false exit pupil is causing the eye pupil diameter to become the diffraction limited factor (.17), or reducing resolution 83%. But even at this very low 6x magnification, the resolution is still greater than the eye can resolve (200 lp/mm).
Now, without going through an exhaustive check on this post, if you work these numbers, you will see that you can never drive the lp/mm projected to the retina lower than 265 lp/mm, with a 3mm or larger pupil diam. Until of course, the eye pupil/exit pupil factor (.17 above) becomes greater than 1. At which case, all diffraction comes from aperture diameter and this exercise is mute. I assume with half of the light lost in the BV, you can NOT get an eye pupil smaller than 3mm. However, even at 2.5mm, the same applies. So this was the basis of what I was describing. It seems in theory, the false aperture produced by BV could degrade the view by the added pupil diffraction it induces (vs. binocs), but it seems that is NOT the case. Or maybe I just missed the scenario where false pupils do degrade the view? So my point is, false pupils cause the eye pupil to become the limiting diffraction factor (as opposed to scope apt.), but not to the point of degrading the view, as it does not fall below the yes max. resolution limit.
Does this make sense? Is the math flawed? If not, then I would suggest, the larger false exit pupils is actually beneficial outcome of a BV/scope, as larger exit pupils create a more comfortable viewing experience....i.e. not allowing the view to black out when pupil alignment is not perfectly coaxial with the EP. Albeit if the exit pupil is too large vs. the eye pupil, noticeable light loss will occur, as in the example above. But the example above is not realistic at 6x magnification. As these huge contraptions are not made for 6x magnifications, often we would just use our small binoculars at these magnifications. At about 30x + magnification the eye pupil diffraction factor becomes a mute point. At 20x magnification, the eye pupil diffraction factor is .61, or a 40% loss of light, in bright light viewing, I would consider this an acceptable trade off, i.e. viewing comfort in lieu of slight light loss.
EdZModerator
Professor EdZ
Reged: 02/15/02
      #1096640 - 08/15/06 08:28 PM
Variables…
550 fl scope
100 aperture scope
100.0 EP fl, mm
6 x - magnification
17.0 eye fl
Sorry none of this made any sense to me. I didn't see any math here? I could not follow what you were doing.
edz
member#21
msc
Reged: 08/10/06
      #1096677 - 08/15/06 09:02 PM
Ed, you did not designate what part of the math you did not understand, I will assume its just the final few lines.....
I will explain, SEE IN CAPS FOR CLARITY.....
Variables…
550 fl scope
100 aperture scope
100.0 EP fl, mm
6 x - magnification
17.0 eye fl (THIS IS THE FL OF THE HUMAN EYE)
94 mm, effective fl of entire optical train (EYE FL * MAGNFICATION)
0.9 f stop of entire system (EFFECTIVE FL / SCOPE APT)
1,604 lp/mm projected on retina (1500/FSTOP = DIFFRACTION LIMITED AERIAL RESOLUTION)
18.2 mm, Exit Pupil diam. (SCOPE APT / MAGNFICATION)
0.17 eye pupil/exit pupil, diffraction factor (EYE PUPIL DIAM / EXIT PUPIL DIAM)
265 lp/mm projected on retina THE LOWER OF, 1,604 LP/MM, OR (1604 * .17)
ED, IN THE LAST DEFINITION, I USED THE NUMBERS INSTEAD OF THE TITLES SO IT WOULD BE EASIER TO FOLLOW.
Let me know if this makes sense now, sorry for not elaborating more on the original post....
EdZModerator
Professor EdZ
Reged: 02/15/02
      #1097183 - 08/16/06 06:17 AM
I have no idea how this originated. I cannot tell how you made your assumptions or what they represent. I don't know where you got your constants from or what they represent. And I don't know how this relates to binoviewers or binoculars.
Sorry
edz
But I did reread this from your previous post
Do you realize this 'most that can be resolved' can only be accomplished at very high powers, probably accomplished with exit pupils of about 0.5mm? Also do you realize that no binocular magnifications can achiev this. As I pointed out above, magnifications that we would be using on the order of 25x or 40x to 50x might allow you to see potentially 10 lp/mm or 50 to 80 lp/mm, but never as high as 200. In fact, I don't own any instruments that could be used at any powers that would allow me to see as high as 200 lp/mm.
Refer to my previous post for examples of lp/mm that could be seen at what sizes scopes and at what powers. But just to give another example, the same 16" scope I refered to before that could see 200 lp/mm at 100 feet using 300x, would be able to see 1000 lp/mm at 300x if you could focus on those line pairs at a distance of 20 feet. That would be 0.3 arcseconds resolution, the limit of the scope.
Where are you getting your 1500 lp/mm from? What does this represent and how was it measured? How did this become a constant? What kind of maximum instrument was used to determine that value and at what power and at what distance? How is it used in reference to a 5" aperture? It seems to be the basis for your calculations, so where did it come from?
member#21
EdZModerator
Professor EdZ
Reged: 02/15/02
      #1097309 - 08/16/06 09:18 AM
Your missing a portion of the light. Not all rays are visible at other than the exit pupil distaance. that's where all rays come together to form a completely illuminated image.
That was my understanding. Now think about how you would do that. In a larger scope, which usually has a longer focal length, you need a longer eyepiece to get low power. generally a much longer eyepiece than would be found in a binocular. The restrictions of longer focal length eyepieces, filed stops, clear aperture and kidney bean all come into play with these much longer eyepieces that would be used in a BV. Not many are best suited for the task at hand.
this statement of yours pretty much lets me know that you agree or at least seem to think the BV provides stereo images. But then this opens to question, how much?
Is the huge reduction enough to be a non-issue? Or is the affect still there and somee people have a problem with it? This would be helpful to fully understand. Either a huge reduction would allow being able to say to people who claim 3D, there is no stereo affect with a binoviewer, or the acceptance that there is a stereo affect and acknowledgement that people can see 3D with a BV means that it is similar to a binocular. My only question is, which is it?
edz
member#21
msc
Reged: 08/10/06
      #1097733 - 08/16/06 02:18 PM
Hi Ed, thanks for the response.....
I would be happy to explain any parts you don't understand.... I think the information is very relevant to diffraction limits for close terrestrial viewing, BV vs. Binoc.
> Do you realize this 'most that can be resolved' can only be accomplished at very high powers.
Your confusing two issues here. When resolving distant planets, more magnification is the "order of the day", indeed. But this discussion was regarding terrestrial viewing, where any viewing instrument can see an animal at 100 yards (including the un aided eye). So what my posts are addressing:
1) how much magnification you can achieve with x size apt., before apt. diffraction begins degrading the view. Of course larger apertures always win, but at the expense of weight and size.
2) More relevant to this thread though, this exercise addressed the "potential" pupil diam. diffraction effects as a result of the false exit pupil sizes which you discovered. You mentioned in your original thread, a BV forces "larger than normal" exit pupils vs. a straight scope or binocs, which we all agree. You then went on to explain how having a larger exit pupil vs. eye pupil diam. will create additional diffraction, as when the exit pupil is larger than the eye pupil diam, the circumference of the eye pupil now becomes a contributing diffraction source. (as opposed to the scope apt being the only source of apt diffraction) Your original thread went on, and used a factor of eye pupil diam. / exit pupil... which you then multiplied this factor against the Scope/binoc apt. diam. (for light loss and diffraction) I am in agreement with all this Ed. What I was curious about - was "how and when" this false exit pupil can actually degrade the image (from diffraction) due to the lowering projected resolution on the retina... i.e. degrading the projected image, below a resolution value the retina is capable of resolving.
The small exit pupils of .5mm that you refer to are at very high magnification, ~ 200 x, and at this magnification, surely the exit pupil is smaller than the eye pupil diam. So none of this applies....but 200x is rarely the case for terrestrial viewing, as this thread is about binoculars vs. BV for terrestrial viewing. In astro, this discussion is irrelevant. But many people consider the differences between BV/Binocs for terrestrial use.
We are talking about two different resolutions here. You refer to the resolution the eye can resolve off a reflected target. I am referring to the aerial resolution, or the projected resolution of a "abberation free" optical system - on to the retina. Thanks to another poster on this forum, Jared, he offered cross references between the two, 100 lp/mm projected resolution on to the retina is equivalent to approx., the unaided human eye resolving a 3 lp/mm reflected target at 10" viewing distance. This cross reference made perfect sense to me, as the best human vision can only resolve up to 6 lp/mm on reflected charts, hence the max. 200 lp/mm projected resolution onto the retina. (which also perfectly coincides with the human retina containing 400 cones per mm, or 200 cones pairs per mm)
When lenses are tested with optical test equipment, their ability to resolve is expressed in aerial resolution (in scopes we use the term projected resolution as everything is being projected onto the retinal). The basis for this is, many lenses are used in an optical system, whereas the lenses begin to degrade the total resolution with more lens elements. Hence why they isolate the aerial resolution of each element and test with sophisticated lab equipment, as the human is not capable of discerning such resolutions. As an example, the best photographic lenses can produce aerial resolution in the 600 - 800 lp/mm range. Scope optics are also some of the best optics made (of course this varies based on the quality of the scope) as everyone is chasing the "best possible view" for the dollar.
If you take your scope and focus on a close target and eliminate other seeing obstacles, you can test this for yourself. I have done this many times and the results are very consistent amongst many optical systems I own. To simplify the approach and see the effects, simply use the well used magn/inch method below as a reference.... and be sure the exit pupil is smaller than the eye pupil diameter, so you know for sure where aperture diffraction is coming from.
magnification per apt. diam (in inches) - Example - 43x magnification / 4" apt = 11.
At, 11 magnification per inch, the optics can produce a max. 200 lp/mm projected on the retina.
Therefore,
11x magn/inch (and < 11x) will produce "diffraction free" views.
22x magn/inch will produce views which are degraded 50% by apt. diffraction.
(vs. what the human eye is capable of resolving)
44x magn/inch will produce views are are degraded 75% by apt. diffraction. (50 lp/mm projected to the retina)
Again, assuming you have good optics (I am sure a pair of $15 binoculars can defy this formula as lens abbearations will rule) and eliminate other seeing variables, which means focusing on a relatively close target with no, or very few seeing variables, such as a bright lit target indoors at 50ft, then hopefully you will see the resolution fall-off as described above. I often use a block wall 100 ft away outside, in the morning, to reduce thermals. For me, the results are near perfect to the benchmarks above. Others I have tested seem to have the same findings. I am curious how others on this forum would fare at this simple test. Anyway, if you have a high quality optics, this is an excellent way to isolate the variables and "see" the diffraction in varying degrees.
As I mentioned earlier, this projected resolution method of un abberated optics is a simpler method to determine the projected resolution on the retina. When aperture diffraction (from scope apt. or eye pupil diam.) begins to degrade the image below 200 lp/mm, we can begin to attribute the degraded view to "aperture diffraction." As mentioned prior, the 200 lp/mm comes from the fact the retina contains 400 cones per mm, or 200 "cone pairs" per mm, which I have expressed "cones pairs" as line pairs, as its simply an expression of density. It's no different then expressing digital sensors as pixel pairs per mm, which often we see mentioned as lp/mm.
Of course it's always possible there can be other contributing factors to degradation, but this discussion revolves around aperture diffraction only. As mentioned early, there is also the human element here, (age, quality of retina, brains interpretation, retina density, etc.) so this exercise will only get us "in the ballpark", which in optics, is never easy :-) It's not uncommon to miss the ballpark and be in the wrong country :-)
I am sure you do Ed, a decent pair of $100 binocs can accomplish this with ease.... hence this discussion.
The formula is, 1500/f stop = aperture diffraction lp/mm. This is resolution limit imposed by diffraction, expressed in lp/mm. As you know, there is other ways to express diffraction, but coming from a photographic background, this is the preferred method when dealing with reflected targets and human vision. This formula has been around since the early 1800's and has been used in photography since then. Myself and many photo colleagues use this formula daily, for most of our lives. It is an amazingly accurate value, and prvoven by countless tests, by the best researchers out there, including Zeiss. Since there is no human element, aperture diffraction its VERY predictable, hence this thread. I have included at the bottom of this post, a reference from the LF photography home page that explains this in more detail.....
If the scope is 800mm fl, then 800/125mm apt = f 6.4. 1500/6.4 = 234 lp/mm, the max. aerial lp/mm the lens can project. But when you introduce it in the form of a scope, you have to alter the effective fl to account for magnification of the entire system, including the fl of the human eyes, as the eye becomes a lens in the optical train before the light rays hit the retina. Hence why my calculations showed the effective fl of the entire optical system, effective fl of the combined "objective fl, EP fl, human eye fl", then applied the aperture diffraction to this combined "effective fl".
Additional diffraction information.......
Diffraction
A beam of light passing through a circular aperture spreads out a little, a phenomenon known as diffraction. Diffraction is a physical phenomena which is unescapable. The smaller the aperture, the more the spreading. For photographic lenses, diffraction depends only on the f-number N.
Strictly speaking, diffraction is a function of aperture size or the physical size of the hole and that is how it would be defined in a physics textbook. Which means that the larger area aperture in a 300mm lens at f/16 (as compared to a 50mm lens at f/16) should provide lower diffraction. However, diffraction patterns are angular patterns and as such are dependent on how far from the aperture you place the screen used to view it also. In photography, the aperture is at the optical center of the lens and the screen is (for infinity focus) one focal length away. The physical size of the diffraction blur is then the focal length divided by the apparent size of the aperture i.e., the definition of the f stop. Thus, in photography, diffraction is only a function of f stop and not a function of the focal length. In simpler terms, the larger aperture of the 300mm lens does offer lesser diffraction at the diaphragm (i.e., less bending around the diaphragm) but since the light now has a longer distance to travel (as compared to the 50mm lens), the smaller bending still results in a fair bit of blur at the viewing screen. N Dhananjay
The image of a point light source (such as a star) after diffraction appears not as a point, but as a central circular spot surrounded by a series of dark and bright rings. See references for details and formulas. Because a point source is imaged as a disk rather than a point, it will appear blured, and this limits the maximum resolution of the lens. The formula R = 1500/N explaned below, gives the maximum resolution of the lens as a function of the f-number N.
The central spot size due to diffraction, called the Airy disk, has a diameter of d = 2.44 x lambda x N. Note that this formula depends on the f-stop and not on the physical aperture of the lens. For a wavelength near the middle of the visible, lambda = 550 x 10 exp(-9) meters , d = 1.34 x 10 exp(-6) x N meters, or d = N / 750 if d is in mm. No lens can make a spot smaller than that value. 86% of the power is in the Airy disk, so it can be viewed as the image of the point. However unlike in the case of defocus, the brightness within the central diffraction spot is not constant, but it decreases from the center to its border, where it reaches 0, resulting in a dark ring. If we use the Rayleigh's criterion that two points are resolved when the dark ring of one coincides with the center of the Airy disk of the other, the corresponding resolution is R = 2/d.
fstop resolution limit
N R (lp/mm) d (mm)
11 136 .014
16 93 .021
22 68 .029
32 46 .042
45 33 .059
64 23 .085
Mark9473
Reged: 07/21/05
Loc: 51°N 4°E
      #1097835 - 08/16/06 03:14 PM
I have a problem understanding this if the eye entrance pupil is larger than the binocular exit pupil.
Mark
Leica 8x20; Vixen 8x42; Swift 8.5x44, 10x50 and 20x80; TS 7x50; Orion 15x63
WO Megrez II 80 FD + Baader 90° T2 Amici
msc
Reged: 08/10/06
      #1097973 - 08/16/06 04:50 PM
Ed...
I understand the explanation, but I NEVER once experienced this... with my eye almost slammed on the glass, I see every ounce of image that I see at the ER position. Do you not experience this also? I always notice people slamming their eyes into a Bino viewer for this same reason....
Well, this is getting into semantics. True stereo vision as it relates to depth perception requires two images of the subject, both taken from a different prospective, such as our Inter Pupil spacing in natural viewing or in binocs, .... but NOT in BV. In a BV, depth perception produced by two distinct images does NOT exist. So any depth we feel is "perceived" or "simulated" by the brain. But the BV capitalizes on the fact the brain uses many depth cues to interpret depth, not just two distinct images....this is evidenced by many of the 2d images you look at to trick your vision into seeing depth, a popular one was a series of books called Magic eyes. So it's possible to perceive depth, (sometimes amazing depth) where NO depth exist from two distinct images produces from two sources, such as our two eyes, or two objectives in a binoc.
What was stunning to me, after years of stereo research... my TV BV creates a wonderful and quite natural depth feel, even though it's ALL "simulated depth". IMO, I believe the BV is creating perceived depth by capitalizing on EVERY OTHER depth cue the brain uses to create the depth illusion to us, - except true depth :-) ! Keep in mind, this discussion so far only relates to relatively close terrestrial viewing.
The other depth cues the brain uses are resolution, sharpness, contrast, AFOV (big factor), using both eyes (even bigger factor). IMO, a BV in a sharp scope with very sharp EP's used at low magnification literally overwhelms all the other depth cues of the brain, enabling the brain to offer us the feeling of depth. One of the biggest factors of perceived depth in 2d imagery is "immersion". Immersion is felt by your angle of view. This is evidenced by the semi spherical movies you see in big Amusement parks or National parks visitor centers, museums, etc. When you stand, and are surrounded by the projected movie image, the immersion is so great, you brain begins to simulate that depth which actually existed when the scene was photographed. But yet, it was recorded with one lens, one film.... and projected with one lens, one film and is viewed with the un unaided eye. The depth feeling is so powerful, you are instructed to hold onto the handrails in front you, as the effect is so powerful, your brain actually places you in the scene, and the movement can alter your senses to the point of swaying or even falling. Anyway these movies, are a perfect demonstration how the brain can reproduce near perfect depth from 2d imagery. When these movies are done well, with super high rez images, I often get a much better depth feeling vs. an Imax 3d movie that was recorded with dual images and projected with dual images, and appropriate eye wear must be worn to achieve the two different images into each eye. (there is many different methods of getting two different images into each eye, but that is off topic here) Again the point being, when you overwhelm the brain with enough depth cues, it has the ability to reproduce depth.
I also have experienced the exact same when testing stereo viewers. Often I can use 2 identical images in a stereo viewer, but the views are so sharp, and the AFOV so big, the brain sees depth where no depth exist in the images. Now when I introduce images with depth (two distinct images shot with two side by side cameras) even more depth is introduced and appreciated.
Trust me, the TV BV I have been using has caught me by surprise and is opening up new viewing possibilities for me, hence my interest in fine tuning the oddity that a BV represents, i.e. One image, split into two views. Other than stereo microscopes, I have never seen this type of optical trickery in terrestrial or amateur astronomy gear, till recently. So I am willing to bet, the final chapter has not been written on this... your threads really stimulated many of us to think about this, and maybe advance what you have started....
For starters, a BV produces a single, flat, 2d image. So does a scope with single eye viewing. However, even with a high quality scope with single eye viewing, at very low magnification, the resolution is so sharp (always when seeing conditions are right), contrast is so high, edge sharpness is superb, it will overwhelm some of the brains depth cues discussed above and you can sense a 3d feel.
Now, I believe it's this slight depth felt in a single eye view, is the starting point of understanding how the brain can simulate or perceive 3d effects where there is NONE. Single eye viewing in a scope at very high rez, specially on bright subjects, demonstrates a slight depth effect. Look at local trees with your scope, can you tell which tree is in front of the others? It's quite easy... try to stay at super low magnification so "Depth of Field" does not cloud the issue too much. Anyway, this tiny bit of depth in a single eye view I believe is created by the ultra sharpness of the optics. With the optics adding contrast to the image and edge sharpness, with a low enough pupil diameter, say 2mm, (which is the perfect balance between the eyes abberations vs. pupil diffraction), you can actually see a view NOT possible with the unaided eye when viewed at a close distance to represent the same magnifications. IMO, it's this high resolution / high contrast, trickery, that induces the brain into simulating depth.
Now, project that same image into both eyes.... now the brain goes into depth mode - as with 2 eye viewing, our brain is in depth mode 99% of the time, except when looking at a 2d image. So our brains are trained, when each eye sees an image (either distinct or the same image), then depth should exists.
Your brain as no training or previous knowledge on using both eyes, seeing an unusually sharp image (not like a 2d reflective print which has much limited contrast, brightness and resolution vs. low power magnification scope viewing) and not interpreting this as true dual stereo vision (i.e. two distinct images, as in true stereo vision) The only exception to this, maybe people who use stereo microscopes all day, as their brain receives very unusual training, i.e. seeing 2 sharp distinct views of the identical image.
To further this concept, in photographic printing, I have noticed for many years, when a 2d print is made on translucent back lit medium, at extraordinary high levels of resolution, contrast and edge sharpness (now often attributed by digital manipulation), people viewing such, all comment..... Ahhhh, it seems 3d, almost like there is depth, like looking through a window. This furthers my position on how we can trick the brain....
Another huge variable in tricking the brain is the AFOV. When those same back-lit images above which were printed at 50" and viewed relatively close, are now reduced to 14", and viewed relatively close, we stop hearing the, " I see depth" comments. This I relate to sheer AFOV, clearly one of the biggest depth cues.... with little or nothing in the periphery, our brain realizes this is not a real view, as the eye never sees tiny circles with no periphery.
So a Bino viewer, at low magnifications, with very sharp optics, well lit subject, large AFOV EP's preferably 80 degrees, comfortable viewing (not allowing black out in the eyes, problems with ER, glasses, etc.) then this BV has just provided every single depth cue to the brain, except ONE - distinct images. And that's the cue most would think contributes the most. So this again demonstrates how creative our brains are, as it seems our brain fills in the only missing piece - true depth! So the more depth cues (and the quality of the depth cues) you give the brain, the better your brain will fill in the missing ones.
Now for astro viewing, it's a different ball game, as our eye spacing and brain is not capable of perceiving depth past relatively short distances. With Astro BV'ing, the magnifications are often very high (except maybe the moon), resolution is often very diffraction limited. However, wit the right EP's, we can still offer a large AFOV and good contrast can still go a long way to trick us us into slight depth simulation. But with Astro / BV, I think a safer definition is, we feel like we are in a spaceship, looking out a huge window. In which case, even at this vantage point, these distant objects provide no depth from our natural stereo vision. Our brain is required to use its other depth cues to determine spatial relations.... So with astro, its a mix bag, much of it probably depending on the quality of the view, AFOV, the contrast of the scene, the size relations of the subjects in view, and even the colors. But clearly the BV even in astro provides tremendous immersion and slightly better sharpness than one eyed viewing, all very favorable IMO, vs. one eye viewing. I would be very curious to hear from BV users with lots of experience viewing deep space.... would they describe what they see as immersive (spaceship view) or depth. Anything is possible, and the manual on this topic has not been written. We are all writing it as we go along.
But I think the most dramatic sweet spot of a BV falls into terrestrial viewing..... as in most cases we are comparing the BV/Scope with binocs, in which case, the simulated depth allows us the use of a single bigger apt. (vs. two smaller ones in a binoc) and a smaller package, with the potential to go to any magnification with a change of EP's (which is possible in some binocs) Also, per dollar spent, I believe the BV/Scope, you get you much better views after you pass the normal binoc range of 15 - 20x magnification. Below 15x magnfication, a pair of Canon IS binocs just can't be beat for the view vs. dollars spent. From my analysis though, BV /Scope fills that 15 - 60x range more cost effectively, better optically (higher magnfication views at the same diffraction thanks to larger aperture) and produces a smaller, lower weight system vs. the old standard - Binocs.
I would be interested in hearing other opinions....
EdZModerator
Professor EdZ
Reged: 02/15/02
      #1098236 - 08/16/06 07:35 PM
When the exit pupil is small, much smaller than the eye pupil, you may never notice any light loss. In this instance the oblique rays are outside the exit pupil diameter, but may still be within your eye pupil diameter. None-the-less, they would not be concentrated in the image.
Low powered viewing can be different. In this case exit pupil is often maximized at just less than or equal to eye pupil. In the case where exit pupil equals eye pupil, any position other than exactly at the exit pupil distance will cause the oblique rays to miss the eye pupil. You cannot get all the light the exit pupil has to offer unless you place your eye at the exit pupil distance. You may not have recognized this in your viewing experiences, but that does not change the fact that it is occuring.
This answers your question in regards to why I explained above that long eye relief eyepieces that might be required to get low binocular-like powers out of a binoviewer may not be a comfortable choice for viewers. I have some long eye relief binoculars that, when used without glasses and my eye up against the binoculars, show significant vignette of the light at the field edges. I have some long eye relief eyepieces that when used in a scope, with the eye placed too close, you can't see anything at all.
Any binocular or eyepiece when used with eyes out beyond the exit pupil distance will show a narrowed field.
edz
member#21
msc
Reged: 08/10/06
      #1098283 - 08/16/06 08:18 PM
> You cannot get all the light the exit pupil has to offer unless you place your eye at the exit pupil distance. You may not have recognized this, but that does not change that it is occuring.
Ed, I fully follow you here, and please don't misconstrue my persistence with being combative.... it just so happens, I am working on an optics project right now, and this is one of the issues being addressed...hence why I am trying to "see" this problem.
Now, maybe where the lines are getting crossed here.... possibly I have not experienced the "perfect storm" in the bino viewer yet. Part of the problem is, I have a hard time trying to figure out what my pupil size is, when looking in the bino viewer, as that's all part of this equation. It's possible my eye pupils have always been much wider than the exit pupils, so I have not seen this effect yet? That is the only thing I can think of....
EdZModerator
Professor EdZ
