Privacy Policy |
Please read our Terms
of Service | Signup and
llanitedave
Humble Megalomaniac
Reged: 09/26/05
Loc: Amargosa Valley, NV, USA
I agree, and I think it's silly to try. We should devote those resources to developing spin-up vehicles that supply artificial gravity to their inhabitants.
"S.O.E." (Sauron's Other Eye) 16" Royce conical mirror: A permanent work in progress.
10" Homebuilt dob, old Coulter mirror
Next Project: The "Eye of Sauron" Observatory!
trever
Reged: 08/18/03
Loc: North Alabama
Talk about new fuels... How about Diet Coke and Mentos?
If everyone is confused, google it. I also saw it this week on Mythbusters.
-------------------- Trever
Coronado PST Solar Telescope
Vixen A80MF 80mm Refractor with Porta Mount
Orange Celestron 8 inch SCT on AS-GT mount
Zhumell 20x80 Astronomical Binoculars
Orion Paragon HD-F2 Tripod
matt
Vendor (Scopemania)
Reged: 07/28/03
Loc: Chaville, France
IMHO the biggest challenge is protecting against comsic rays. Today we know of only two ways: heavy water tanks, or magnetic fields which are hazardous in themselves. I would give ten years of my life to go on Mars, but would not like to see astronauts going there condemned to suffer cancer or leukemia when they come back.
-------------------- Matt
CI700 mount with various scopes on top.
John Hoare
seantoir
Reged: 04/25/04
Loc: Area 14, Kildare, Ireland
John Hoare posted:
Unfortunately scientists and engineers have become to comfortable with the fact that if you apply enough force a brick will fly. Such a solution is both inelegant and prone to disaster, just look at the American shuttle program.
I would not consider the space shuttle a "disaster" or "inelegant" at all, and neither would most who follow the various space programs. 115 flights and only two failures (98.3% success rate) is actually pretty good for a launch vehicle (one of the top rates in the history of active launch vehicles). The Space Shuttle has functioned pretty much the way it was designed to. To get a space vehicle of the shuttle's size and weight to launch like a rocket, carry a very large payload, operate in low-earth orbit, and then land like a glider to be re-used is a remarkable feat, and is a tribute to the engineers and technicians who designed, built, and launch the shuttle.
However, is the shuttle cost effective? Not really, as there are less expensive somewhat simpler (and potentially a little less dangerous) ways of getting things into space. Thus, as a "cost saving" item, it definitely did not live up to its advance billing at all (which is why its days are numbered). The expendable series of rockets both active and planned will probably be better on the pocketbook, but the space shuttle does deserve a high regard as a remarkable technical achievement in the history of space travel. Clear skies to you.
David, I don't think that the Space Shuttle program is a disaster, I simply said that it is disaster prone. To lose two crews out of 115 missions means that there were 2 disasters, which is enough to justify labelling a process disaster prone. If it were in any other line of business the local health and safety agencies would close NASA manned operations down for good. Having said that, the program is less disaster prone than most because the average failure rate for space missions is about 1 in 20.
As for elegance, well, it is purely a matter of opinion. I don't consider systems that have to expend a significant proportion of their fuel/energy payload just to get off the ground elegant. Rocketry is brute force and there is nothing elegant about it. It's the 20th century way of doing things and it's about time that we came up with something better, not to mention safer.
-------------------- John
Watery Glebe
Puddlestown
Co. Kildare
Chaos is the rule of nature
Order is the dream of man
Henry Brooks Adams
IFAS
John Hoare
seantoir
Reged: 04/25/04
I think that one of the toughest challenges is in the field of space medicine: how to sustain a healthy human in a low gravity or gravityless environment for such a long time that would require the round trip plus wait time in Mars for the return window. I don't think that the current record of time in space nearly approaches such demands.
I agree. It's the principle reason that I believe our biggest effort should go into finding a new means of propulsion capable of providing a sustained 10m/s^2 at a reasonable payload cost. If we could get around the system by constant acceleration/decelleration maintaining human health in low gravity would only be a problem for missions that land on low gravity bodies or spend significant amounts of time in orbit. The massively reduced journey times would also produce benefits by reducing the amount of time for which travellers would be exposed to harmful radiation.
Watery Glebe
Puddlestown
Co. Kildare
Henry Brooks Adams
IFAS
Arkalius
Reged: 08/03/06
Loc: Orange County, CA, USA
Planning a mission that involves the use of constant acceleration is very challenging, as your trajectory is constantly changing. It's a lot easier when a vast majority of the trip is coasting and letting gravity do the work as it's fairly easy to predict trajectories this way.
Constant acceleration would definitely be the way to go for providing a simulated gravity environment... though rotating sections are far more likely to be employed on a first manned mission to mars.
-------------------- -Arkalius
11" Celestron SCT on Orion Atlas EQ-G
8" Zhumell Dobsonian Reflector
Proud member of the Orange County Astronomers
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
Not only health problems of weightlessness. Unless you use the constant accelleration/decelleration setup, you're going to have a significant supply problem to solve. (Mars mission I'm referring to here) So you send supply "pods" up ahead of time. Uh oh, missed the rondevous by just "that much". Uh, how much oxy/water did you say we have????? And a 2,3, or 4 manpower mission ain't gonna cut it. There will be a lot of simple physical work to do, just to keep things going. I figure a minimum of 6 to 10 bodies... That's lotsa groceries over a couple of years.... Hubert
-------------------- www.smoggybottom.org
LivingNDixie
Lord of Ferrets
Reged: 04/23/03
Loc: Hoover, AL
John Hoare posted:
I disagree… Challenger was a failure of leadership and management NASA had never tested the shuttle hardware at the temperatures that the launch took place at.
Challenger should have never left the pad.
Columbia was just bad luck. They knew about the foam but had never realized the danger of it. It is easy to point out the errors after the tragedy has happened.
Lastly, people forget the failure rates that NASA purposed back when the Shuttle first started flying. We have gotten use to "no serious failures" and we have forgotten how dangerous spaceflight is.
-------------------- Preston
Celestron 11" Nexstar GPS XLT
Lunt LS60T/Ha 60mm f/8.33 (on order)
It’s not finishing something when your tank is empty that makes you a stronger person. It’s brushing yourself off and refacing the foe that defeated you with the same determination and willingness to fight that you had when you began your journey.
LV_Valdis
Reged: 12/29/05
Loc: Latvia
About antimatter, I'm not a physicist, but I've read some stuff on this and it seems that even if we could produce some serious amounts of the stuff, there are more problems rising then it solves. Most of the energy produced in matter-anitmatter reactions is x-rays and gamma rays, requring some fancy materials to reflect the stuff so it propels something (a ship preferably). If nucleons and antinucleons collide 50% of energy produced in this reactionis carried away by neutrinos (small things that are hard to detect and isolate, no protection exists from intensive neutrino radiation) and as far as I know they are totaly useless for almost anything. Maybe someone knows better
-------------------- 8" SkyWatcher dob.
ZRT-457M The "Tank".
A pair of 8x30 binocs from 1952 (insane FOV).
FirstSight
Reged: 12/26/05
Loc: Raleigh, NC
True, nothing that had happened during any *previous* Shuttle launches had made the potential degree of danger from pieces of foam breaking off sufficiently apparent to warrant concern about permitting Columbia to launch that day. Neither was the potential existence of a serious problem apparent nearly soon enough after launch to have reasonably warranted consideration of a mid-flight abort before it reached orbit. Nevertheless, very quickly that first day it was well-known within NASA that launch videos confirmed that an unusually large ("suitcase sized") chunk of foam insulation had broken off at high velocity, very possibly striking the wing area of the shuttle.
The error that was unforgivably arrogant was the intervention by someone up the chain of command *against* permitting ground-crew engineers to request US Intelligence agencies (particularly within DOD) to use their advanced surveillance capabilities to try to capture images of the shuttle to check for possible signs of damage. Also, didn't some large-aperture amateur astronomer who tracked the shuttle with his scope one night during orbit (and had done so with previous flights) notice an anomoly about the leading edge of the left wing? [I seem to remember there being a grainy CCD image he took, could be wrong about that] - didn't he try to contact authorities about that? OK, I can understand the "pros" in NASA being disinclined to give much attention to warnings raised by outside amateurs - probably inclined to think very few know what they're talking about and that many of them are cranks besides. I can also understand it being forgivable error if NASA had taken advantage of our intelligence imaging capabilities to investigate, and had it turned up inconclusive to have hopefully assumed nothing was wrong. But the stupid arrogance of the superiors who overruled even attempting to use such is unforgivable.
...and does cause the public to justifiably lose confidence in the people running NASA, even if the majority of folks there are precisely the ones you'd want to be working there.
-------------------- Chris M., aka "First Sight"
Orion XT12i Dob with Moonlite CR-2 focuser
WO Megrez 90 refractor on UniStar Light mount
Nikon 10x50 Binoculars
Qkslvr
Reged: 06/23/06
Loc: NE Ohio, US
I lived close to the Cape for the first shuttle launch, and a few days after the launch, a local paper ran a story about another local DOD facility using their big scope to look at the bottom of the shuttle while it was in orbit to check for missing tiles.
I'd heard a while after that, that the DOD was not pleased that the story ended up in the papers.
-------------------- Mike
N8/CG-5/40D
Coming sometime/Maybe FrankenRebel
Edited by LivingNDixie (08/15/06 06:04 PM)
Anonymous
Unregistered
I caught some of that. I had to stop just after they said the power wasn't solely due to the CO2. What was the other accelerant? Wish I'd known that as a kid, would've really sent my Alpha 1 way up there.
David Knisely
Reged: 04/19/04
Loc: Beatrice, Nebraska
FirstSight posted:
Hindsight is indeed 20/20, but I wouldn't put too much criticism on those who didn't exactly authorize a look with the DOD assets. There wasn't really any clear indication from the ascent videos and stills that damage had occurred, although in hindsight, it would have been better to have had some images taken to make certain that things were OK for entry. Indeed, it is possible that the damage was slight enough in areal extent that even if an on-orbit image had been taken, the RCC panel damage may or may not have shown up conclusively. Several ground-based images were done with tracking cameras, but only the payload bay side of the shuttle was clearly seen without a clear shot of the wing section which was hit. On entry, the panels were then subjected to the mechanical and thermal stress of reentry and would have then failed completely with the results we have seen. No amateur video was taken that shows the damaged wing clearly, but a Starfire (Air Force) infrared tracking camera *does* show indications of wing leading edge damage as the shuttle flew over during reentry. All we know for certain is that a large chunk of foam damaged the RCC panel enough that it was unable to protect the wing from heating damage during reentry, leading to the loss of the vehicle and crew. It would have been best to have a more robust thermal protection system (or a shuttle version which was smaller and launchable on top of a large expendable booster), but that is not what the "compromise" that lead to the final shuttle design arrived at. Clear skies to you.
-------------------- David W. Knisely
Hyde Memorial Observatory
http://www.hydeobservatory.info
llanitedave
Humble Megalomaniac
Reged: 09/26/05
The mysterious "object" that was detected slowly moving away from the shuttle after it reached orbit might have been thought insignificant by itself, but, again with 20/20 hindsight, one would think that combined with the foam strike, there would have been a reason to want to find out. Maybe DOD photos wouldn't have shown anything. But there were real reasons to want to look.
Anonymous
Unregistered
Regarding the Shuttle and the inherent dangers, makes me think back to the launches of Alan Sheppard and John Glenn and how truly brave those men were. Sheppard was sitting atop a Redstone which had never been used in manned flight and which was unpredictable. Likewise, Glenn atop the newer Atlas which had a rough test period. I'm sure many at NASA had their fingers crossed as those ignitions began. Later Mercury flights on those rockets at least had a small comfort level, but the first had to be a mighty ordeal, indeed.
1 registered and 0 anonymous users are browsing this forum.
Moderator: llanitedave
