pollux
Reged: 04/01/04
Loc: Vancouver Canada
"Hyper-tuning" your GSO crayford
      #1144083 - 09/12/06 02:39 AM
Okay, a few CNers told me they are having trouble with their GSO-made crayford. They worked at the beginning but then all of the sudden getting stuck, stiff, slipping, or whatever. Adding more tension by the thumbscrew makes matter worse, etc etc.
I think, instead of just telling them. I am posting my trick here so that everyone can benefit.
Before you start, you need a few things. The focuser of course. A few pieces of tissue. And.....drum roll.......grease. Yeap, you heard it right.....GREASE! Repeat after me! G-R-E-A-S-E.
GREASE!
You may think "Are you crazy? Grease for crayford? Reason I get the crayford is because I HATE grease!"
Well, I am one of the odd balls (I think those who call themselves "artist" do qualify for that) so don't argue with me
In fact, ALL my GSO focusers (I have FOUR, three refractor type and one reflector type) have gone through the treatment (which I am going to tell you) with grease (again G-R-E-A-S-E......GREASE!) and they all have been working great. If you don't believe me, turn off your computer and head to bed or do something else
Okay, lets start.
Picture below. A product photo of the GSO crayford
Next, a photo of the grease (repeat after me, GREASE. Sorry I can't resist ). The type of grease should be light/thin one *NOT* the thick type otherwise it will make the end result really bad. I pick a light white lithium grease (GREASE! )
Now, time to break the focuser apart, YAY!
If you have a dual speed type. Take off the simpler knob (not the dual speed one) from the shaft.
You see there's a little plastic tube like thingy (the one sitting on the shaft). Take it out too but keep it in a safe place as you will need it later.
Pull the shaft out so that the drawtube can be taken out from the focuser's body
Before I move on, let me explain why I am using grease (GREASE!!!!!! )
I have been looking at moonlite, WO focuser for a long time and I always wonder why these focusers are pretty smooth. WO and GSO focuser share the similar type of mechanic and why WO is smooth than GSO's all the time. I first thought it was the focus shaft and knobs. Then I realize this is not the answer. The real answer is the DRAWTUBE.
WO and Moonlite have smoothly anodized draw tube and the suface is so smooth and reflective while GSOs has rough texture. That really causes friction and resistance. For smooth focus action the drawtube has to be smooth.
The grease I am using here is not just for lubrication but also for "polishing" the surface of the drawtube.
Let's move on....
Now, apply a small amount of grease (GREASE! ) on the drawtube's flat area. Spread it out.....think of applying wax on your car. Wait for a few minutes. Then wipe the grease out COMPLETELY.
This is pretty much a work of polishing the surface.
You may have to do a few times. The flat surface should few a lot smoother after that.
I first thought about using car wax instead for the polish but then realize grease (GREASE!) and car wax may not play well to each other. So I decide to use grease (hurray! GREASE. Long live the grease! ) all the way.
Do the same on the "bearing mark" area (the black line, all crayford tube have these due to the contact of the ball bearing/wheel in the focuser). But leave a bit of grease there.
......and the shaft (remember to WIPE OFF the grease completely!)
Now, look at the focuser body. Now apply a bit more grease on the four wheels (circled in the photo). Leave the grease there
Here's the tricky part - to put the focus shaft back to the focuser. You will have to loosen up ALL the bolts or screws at the bottom of the focuser so that the draw tube has more wiggle room to let the shaft back in.
Remember the little black plastic tube thing? Put some grease on both end and put it back to the shaft
Put everything back in and start to rack in and out the focuser a few times. And pull and push the focuser drawtube back and forth (by hand) at least 10-20 times (have to wear out the shaft and the drawtube's contact surface to improve the contact a bit)
After that, the grease is all over the draw tube (as seen on photo)
You may do the clean up but leave some of them on the area where the four wheels' contact (the lines, remeber?)
Now, since the focuser has smooth drawtube that means it will slip easier. But don't worry, this is what the tension knob is for. Yes, a bit more tension is needed (The focuser is able to handle a 2" focuser, with a 2" EP, and no slip). Crayford focuser need to have a balance between smooth (or slip if you prefer) and gripe (or friction) in order to operate well.
In terms of smoothness, base on my experience, is really very close to moonlite after the modification. But that's depending on what kind of lubricant you use. If you use very thick grease you will get a very sticky focuser.
Any questions? Feel free to ask
Pentax 105SDP Apo Refractor
Vixen VMC260L Modified Mak-Cassegrain
Entire Pentax XW & XF eyepiece series
Personal Web Site
Telescope Comics
Jim7728
Reged: 04/10/05
Re: "Hyper-tuning" your GSO crayford new [Re: pollux]
      #1144177 - 09/12/06 06:51 AM
Thanks for the tune up guide, Pollux.
I have the GSO single speed focuser on my Orion 80ED and had problems with it holding a 2" diagonal and eyepieces. I sanded the flat part of the drawer tube for better grip. It does not slip now, but it's not as buttery smooth as I'd like it to be.
I'll try your grease job.
TV-60/40mm Ha-5mm BF
TV-85 and other tubes...
pollux
Reged: 04/01/04
Re: "Hyper-tuning" your GSO crayford new [Re: Jim7728]
      #1144594 - 09/12/06 11:57 AM
Oops, on the second last paragraph I mean to say "the focuser can handle 2" DIAGONAL 2" EP"
I have linked too many photos and I am not allowed to do any change
Personal Web Site
Telescope Comics
Kris.
Reged: 09/16/04
Loc: Belgium
      #1144699 - 09/12/06 01:04 PM
Wow thanks for the info Pollux! I too have a single speed gso crayford, it's allright now, but now I know what to do when it starts working less well!
Kris
To be old & wise, you first gotta be young & stupid
8" dob
AstroTech 66ED/APO
TAL 120 newt.
my CN sketch & picture gallery
dominico4
Reged: 10/06/05
Loc: Winston Salem Area, NC
Re: "Hyper-tuning" your GSO crayford new [Re: Kris.]
      #1145261 - 09/12/06 05:52 PM
When I get back from drumline practice tonight, I'm DEFINATELY doing that on my Lightbridge focuser! Can't wait to see the results! Do you basically put it on and take it off so that it fills any little pits and makes a tiny film but doesnt actually clump, and what's the best way without leaving junk from the tissue? Then again, white lithium grease has a tendancy to not be sticky so a tissue sounds fine!
Josh
Vixen ED80Sf w/ Vixen Portamount
Meade 12" Lightbride Deluxe
My Clear Sky Clock = Winston Salem Area, NC
The current estimate for the number of stars in our galaxy is 100 billion, while the U.S. National Debt is 8 trillion dollars. They used to be called astronomical numbers, but now they should be called economical numbers!
Sky Captain
Metal Whisperer
Reged: 11/07/04
Loc: Issaquah, WA.
      #1145341 - 09/12/06 06:44 PM
Nice "little" run down on souping up the GSO Pollux, thanks.
Equipment Overload!
Kerry
pollux
Reged: 04/01/04
Re: "Hyper-tuning" your GSO crayford new [Re: dominico4]
      #1145401 - 09/12/06 07:20 PM
That's pretty much a yes.
The tissue I use are those that doesn't make those nasty fall offs.
Personal Web Site
Telescope Comics
dominico4
Reged: 10/06/05
      #1145618 - 09/12/06 09:53 PM
WOW it's like water on water! Thanks a million for the guide!
Josh
pollux
Reged: 04/01/04
      #1146260 - 09/13/06 10:20 AM
Glad to see it works for you
Personal Web Site
Telescope Comics
csa/montanaModerator
Den Mother
Reged: 05/14/05
Loc: montana
      #1146606 - 09/13/06 02:09 PM
Thanks for the article, & especially for taking the time to post such excellent step-by-step pictures. When taking something apart, a picture is indeed worth a 1,000 words!
Carol
Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory, #2
F.Meiresonne
Reged: 12/22/03
Loc: Eeklo,Belgium
Re: "Hyper-tuning" your GSO crayford new [Re: csa/montana]
      #1146663 - 09/13/06 02:57 PM
Great explanation, Pollux. As a future owner of a GSO Crayford this will come to my advantage.
surface is so smooth and reflective while GSOs has rough texture. That really causes friction and resistance. For smooth focus action the drawtube has to be smooth
I wonder if one could use toothpaste!. This is really good pollish material
Freddy Meiresonne
Obsession 18 inch #1638
Orion Optics 8 inch F/4.5 -1/8 wave optics -Vixen GP-E
20x80 Helios Stellar Binos
10x60 Helios Quantum 4(= Obie Mariner)
10x50 Helios Nature sport plus
8x40 Helios Nature sport plus
Eyepieces in use :Pan 35,24,19, N13T6, Pentax 10 XW, N9T6, Ultrascopic 7.5, TV2, baader ortho 12.5 and 9 mm
pollux
Reged: 04/01/04
Re: "Hyper-tuning" your GSO crayford new [Re: F.Meiresonne]
      #1146673 - 09/13/06 03:02 PM
Ar, never thought of toothpaste. Freddy, mind being a white mice?
Personal Web Site
Telescope Comics
oldsalt
Astro Philosopher
Reged: 02/12/05
Loc: Pa - between starparties
      #1147635 - 09/14/06 09:48 AM
You can also use Nano-polish for mag wheels by "Eagle One" . It also works well for bright shiny part on the scope. A little goes a long way.
There are no winners in war, only bigger losers.
Kris.
Reged: 09/16/04
Loc: Belgium
      #1147899 - 09/14/06 12:52 PM
Any idea Freddy where we could get white lithium grease or something similar in belgium?
Kris
8" dob
AstroTech 66ED/APO
TAL 120 newt.
F.Meiresonne
Reged: 12/22/03
Loc: Eeklo,Belgium
      #1148009 - 09/14/06 02:09 PM
Good question Kris...i don't have a clue...in some hardware store perhaps kind 'legerstock' or something. I will ask my fellow clubmembers about it.Stefan Van de Rostyne a keen telescope maker and deepsky friend of mine could know something about it...I'll try to figure it out
Freddy Meiresonne
pollux
Reged: 04/01/04
      #1149660 - 09/15/06 01:21 PM
One person asked me if he can use graphite.
Honestly I have never touched that thing in my life
Personal Web Site
Telescope Comics
esquire
Reged: 10/24/05
      #1152832 - 09/17/06 08:16 PM
I would caution against using any petrol-based grease in conjunction with any elastomer or plastic-based parts. In time, the petrol base could melt the plastic or elastomer. A good synthetic grease would be safer.
pollux
Reged: 04/01/04
Re: "Hyper-tuning" your GSO crayford new [Re: esquire]
      #1153071 - 09/18/06 12:20 AM
Like what?
Personal Web Site
Telescope Comics
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
      #1153361 - 09/18/06 09:40 AM
Here is a link to a very good polish. I used to use in on motorcycles. A little goes a long way, you clean it all off after use. You'd still need to do Pollux's grease routine, this stuff would just be a "preliminary".
Semichrome Polish It's widely available, most motorcycle shops have it.
Hubert
www.smoggybottom.org
Starkler
Reged: 11/04/05
Loc: Australia, Melbourne
Re: "Hyper-tuning" your GSO crayford new [Re: Pedestal]
      #1154739 - 09/19/06 06:30 AM
Silicone grease
Geoff
15" SDM truss dob | Vixen r130sf | GSO 10" dob
9 registered and 14 anonymous users are browsing this forum.
Moderator:  spaceydee, csa/montana
