Telescope Specific Forums >> Meade ACF/RCX / LX / GPS
Wallrat
Reged: 08/29/06
Loc: Huntington Beach, Ca
Post your imaging adapter setup
      #1184177 - 10/06/06 01:30 PM Attachment (41 downloads)
Been debating whether to put this here or in the DSLR forum...
I'm trying to figure out what people are using out there to connect their cameras to these scopes. Seems like my rig isn't ideal since it sticks out about 10" from the visual back and shows significant vignetting. The off-axis guider is pretty much useless since the focus point of the EP is different than the camera. I know there's a better way!
Here's the rig (in order): stock visual back, meade micro-focuser, adapter, Meade f/6.3 reducer/flattener, off-axis guider, T-ring, Canon 300D.
Matt
Welder For Hire
10" LX200GPS
W.O. ZS66SD
Canon 300D
QC Pro 3000
Homemade portable pier & wedge
PowerMac G5 Dual & Powerbook G4
faltered
Reged: 04/01/05
Re: Post your imaging adapter setup new [Re: Wallrat]
      #1184315 - 10/06/06 02:57 PM
I love the idea of this thread. I think this is just great.
Joseph Gillman
Reged: 12/06/05
Loc: Boothwyn, PA
Re: Post your imaging adapter setup new [Re: faltered]
      #1184387 - 10/06/06 03:53 PM
It shouldn't be THAT far off that you cannot use a parfocal ring. Like what comes with the Meade LPI and DSI cameras.Or just tighten the setscrew without having the eyepiece fully inserted. If the eyepiece needs to be further "in"" not out, then maybe you can take off the 1.25 holder in the off axis guider and replace it with a shorter one?
Wallrat
Reged: 08/29/06
Re: Post your imaging adapter setup new [Re: Joseph Gillman]
      #1184520 - 10/06/06 04:56 PM
It's 95% focused if I slide the EP WAY out. I've got a guidescope now so I really don't need the O.A. guider anymore except that its adapting the T-ring threads to those of the focal reducer. I'm trying to get an idea of what folks are using so I can replace it with a flip mirror, adapter, or something else.
Faltered - Thanks, I'm glad you like it. Hopefully this thread turns into something that everyone getting into imaging can benefit from. I know that web shopping all the numerous adapters out there has been anything but easy.
Matt
Welder For Hire
10" LX200GPS
W.O. ZS66SD
Canon 300D
QC Pro 3000
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
      #1184553 - 10/06/06 05:21 PM
Check your focal reducer. If it's made in Japan, the focal length is 250mm (?). If this is the case, you need a short extension tube after the reducer, before the off-axix guider.
Actually, a quick test would be to put the reducer on the other side of the micro-focus...
If your reducer is made in China, the focal length is a lot less. (140mm I think?)... and you'd actualy need to get the EP close, not farther away.
Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
Wallrat
Reged: 08/29/06
Re: Post your imaging adapter setup new [Re: NeoDinian]
      #1184601 - 10/06/06 05:53 PM
Its made in China. I'll have to try the OA again - been quite awhile since I even put an EP into it. Maybe I was backwards on my memory of the focus problems. Regardless, I wasn't really planning on keeping it anyway.
Matt
Welder For Hire
10" LX200GPS
W.O. ZS66SD
Canon 300D
QC Pro 3000
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
      #1184697 - 10/06/06 06:59 PM
I have my 6.3 FR on the forward side of the focuser as seen in the image below. For my 3.3 FR it has to be on the backside or I can't focus. This image is from my old fork mount but the setup is still the same on my new mount.
-Marcus
The problem with free speech is even the stupid have a voice.
http://jatobservatory.org
12" LX200R on a Paramount ME
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Re: Post your imaging adapter setup new [Re: JAT Observatory]
      #1184741 - 10/06/06 07:23 PM
Here is one of my experimental imaging setups. It is a DSI-C with a 180 degree 8mm f3.5 fisheye lens attached. The camera was a test of my homemade All Sky Cam. As you can see from the picture the cover was a borrowed bell jar from my wife’s anniversary clock (she wasn’t overly impressed with my ingenuity).
I was surprise even though the curved top caused some distortion it wasn’t as bad as I thought it was going to be. To keep condensation from forming inside the bell jar part of the bottom was left open and the fan I had previously attached to the DSI was turned on. I may do some more testing with my DSI-Pro when my wife isn’t looking.
-Marcus
Wallrat
Reged: 08/29/06
      #1184935 - 10/06/06 09:06 PM
That's a pretty cool idea Marcus! Would a couple packs of desicant solve the moisture issue? Also maybe you could just make a glass or lexan box instead of raiding the wife's hutch. Just a thought...
Matt
Welder For Hire
10" LX200GPS
W.O. ZS66SD
Canon 300D
QC Pro 3000
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
      #1185018 - 10/06/06 10:25 PM
Desicant would work but that would require the cover be sealed. That would allow the heat to built up too much.
The thing I like about the bell jar is water runs right off.
-Marcus
CRSEREDA
Reged: 01/07/06
Loc: Davie Florida USA
      #1185079 - 10/06/06 11:05 PM
thats a real cool idea once you get some images can you post them?
----Calvin Sereda
JAT Observatory
Space Freak
Reged: 02/20/05
Loc: Eastern PA
Re: Post your imaging adapter setup new [Re: CRSEREDA]
      #1185166 - 10/07/06 12:04 AM
I'll assemble it again and post some images. I can't find the old ones. I don't have the DSI-C anymore as I gave it to a co-worker, but I swapped the front plate with my DSI-Pro before I did so I should still be able to bring it to focus.
-Marcus
southmike
Reged: 11/22/04
Loc: Fayetteville, NC
      #1185593 - 10/07/06 11:18 AM
your ingenuity always amazes me Marcus
group scope pic
my refractors
LX200 10"-St120
LX200 8" f6.3-Orion 80ed
LX200 8" f10-Orion 90 Mak setup pic
Meade 102ED LXD650
Sky Watcher 100 ED Triplet prototype
Nexstar 5
etx125
etx70's
Kim Miau
Reged: 07/17/06
Loc: Kluang, Johor, Malaysia
Re: Post your imaging adapter setup new [Re: southmike]
      #1188644 - 10/09/06 11:21 AM
He is the man!
-Robin
QHY CCD
My Astronomy Blog - http://www.astronomynotes.net
Meade 8" LX90 + LPI + QHY5 + Denk's Power x Switch S2 Diagonal
More equipments @ here
krackerjack9
Reged: 04/17/06
Loc: LSA Anaconda, Iraq
      #1188660 - 10/09/06 11:28 AM
More photos,more more, and list in order how you got it set up from telescope to the camera or what ever the last gizmo is, as the one post put it some of us just dont have a clue and guessing what this and that is. rolling the dice, im not into imiganing but it be nice to know what is being said and visualize it.. Thanks
LSA Anaconda, Iraq
WO 66ED,Sirus 32mm, Orion Diagonal,10mm Celestron,25mm Possl [ Blair S.] Greensboro,NC WO 66APO Patriot
8mm Televue,4mm Or [ Donald B.] Boise,Idaho
Meade 6.7 Ultra Wide [ Chuck ] USA
Meade 26mm Plossl [ Glenda ] Fort Bliss,Tx
WO 1.25 Diagonal , 6mm Radian,4mmTMB, 40mm Meade 5000, 26mm and 32mm QX Meade, and some other stuff my Credit Card has been buying against my will, haha
Kim Miau
Reged: 07/17/06
Re: Post your imaging adapter setup new [Re: krackerjack9]
      #1188672 - 10/09/06 11:32 AM
Yup, I agree with you. Sometimes, I just can't visualise the equipments they talk about.
-Robin
QHY CCD
Wallrat
Reged: 08/29/06
Re: Post your imaging adapter setup new [Re: Kim Miau]
      #1192379 - 10/11/06 12:47 PM
Bueller?
Matt
Welder For Hire
10" LX200GPS
W.O. ZS66SD
Canon 300D
QC Pro 3000
2 registered and 6 anonymous users are browsing this forum.
Moderator:  Joad
