tboss70
Reged: 11/25/05
Loc: Missouri
Which manual filter wheel? new
      #1176963 - 10/02/06 12:04 PM
Getting ready to purchase the DMK and Astronomik filter set.
Which manual filter wheel are you using and how do you like it? Im in the market for one. Thanks!
Todd
Gendo
Reged: 12/12/05
Loc: Rexburg, ID
Re: Which manual filter wheel? new [Re: tboss70]
      #1177492 - 10/02/06 04:25 PM
Are you looking for a wheel that holds 4, 5 or 6, filters?
I bought the Apogee 4 place manual filter wheel a few months ago off Ebay. It does alright, and its all metal. The included filters aren't very good for RGB imaging (the blue transmits far more light than the red and green), but since you're getting the Astronomiks filter set it doesn't matter. It is the cheapest 4 filter wheel I've seen out there so far.
gazerjim
Reged: 02/12/04
Loc: About where I thought I was......
Re: Which manual filter wheel? new [Re: Gendo]
      #1177892 - 10/02/06 07:10 PM
The only wheel I've used is the Astro Engineering "Imager's 1.25 Wheel" so I can't make comparisons.
This wheel holds 4 filters and I would rate quality as 'good'. My only criticism is a slight amount of mechanical play or slop at each setting; but not bad.
Jim Fisher
If you're not part of the solution, you're part of the precipitate.
Henry J. Tillman
tboss70
Reged: 11/25/05
Loc: Missouri
Re: Which manual filter wheel? new [Re: gazerjim]
      #1177990 - 10/02/06 08:02 PM
Thanks Justin, thanks Jim. I want a wheel that holds 4 filters. I dont want to spend a lot of money but I do want something descent.
Thanks again!
Todd
Gendo
Reged: 12/12/05
Loc: Rexburg, ID
Re: Which manual filter wheel? [Re: tboss70]
      #1186258 - 10/07/06 08:09 PM
Update,
As I discovered today, the Apogee filter wheel does not have a standard filter thread, so I don't recommend it now that I know this. Most filters WILL NOT screw onto it properly.
I guess that's the lesson when it comes to astonomical equipment. You get what you pay for.
9 registered and 6 anonymous users are browsing this forum.
