Telescope Specific Forums >> Meade ACF/RCX / LX / GPS
Anonymous
Unregistered
New Meade LX-90GPS 8" Owner - Question
      #1196099 - 10/13/06 02:00 PM
Hello everyone,
I just received my LX-90 yesterday and was eager to set it up. One problem I am having is when I extend the legs outward fully from their stowed configuration the base of the tripod was very slanted. I didn’t notice this and when I placed the telescope on top and attempted to screw it down the threads on the inside of the telescope base got slightly stripped.. It isn't so bad that it is unusable yet. Also, since the tripod isnt perfectly straight, the accesory tray which "catches" the legs only catches one or two of the legs before the bolt is tight.
Does anyone else have this problem? Do you just extend the tripod legs or do you level the tripod before attaching the scope so that the bolt engages straight and the accessory holder on the bolt touches all three legs simultaneously?
claggy
Reged: 05/08/06
Loc: uk
Re: New Meade LX-90GPS 8" Owner - Question new [Re: ]
      #1196112 - 10/13/06 02:12 PM
extend the legs til the scope is roughly level and at a usable height.i dont ever fully extend mine.be careful with the bolt (i put a bit of grease on mine) and dont over tighten it
PeterC2
Reged: 11/11/05
Loc: No. CA
Re: New Meade LX-90GPS 8" Owner - Question new [Re: claggy]
      #1196912 - 10/13/06 10:52 PM
The Meade tripod is very stable and a good one but I've found its major fault is getting the scope (8" LX90 LNT)centered so the bolt goes up into the base without figeting and tightened easily. I had a heck of a time with that until I got the plate from Peterson Engineering (I think its called the Mounting Assistant) that essentially makes the whole process foolproof and quick. I highly recommend it. When I set my scope up, I like the height with no extension to the legs. I check it for level and extend any of the legs needed to get it close, then I mount the scope. Hope this helps.
Peter
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
Re: New Meade LX-90GPS 8" Owner - Question new [Re: PeterC2]
      #1197023 - 10/14/06 12:20 AM
Another great addition to add (including the Mounting Assistant) is making a "Springy-Thingy" (I love that name!). This will save the bottom of your scope from the bolt crushing through the thin metal and destroying the innards...
Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
Rev2010
Reged: 09/25/06
Loc: NYC & Bayonne, NJ
      #1197601 - 10/14/06 12:38 PM
Thanks for posting that info. Everytime my wife and I set up my LX90 10" I can't for the life of me understand why they couldn't put bumped up notches on the mount base and recessed notches under the fork base. Then, you'd just need to set the scope into the notches and bingo, no aligning problems. Pretty silly to think such "smart" engineers didn't think to make the mounting easier.
Rev.
Meade 10" LX90 LNT
TeleVue Panoptic 22mm
Baader Hyperion 17mm
Televue Nagler 12T4 & 9T6
WO 40mm SWAN
WO 2" Dielectric Diagonal
DGM Optics NPB filter
Lumicon OIII filter
Baader Moon & Skyglow filter
Celestron 15x70 Binocs
cuzimthedad
Just Be Cuz
Reged: 04/09/06
Loc: Sonoma, Northern California
Re: New Meade LX-90GPS 8" Owner - Question new [Re: Rev2010]
      #1197627 - 10/14/06 01:00 PM
Another item that comes with the mounting assistant is a washer and wingnut which you use to center the bolt and tighten the tripod into position once you have it in place. This is a very important step each time you set up. After tightening the bolt, you remove the washer/wingnut and mount your scope just as you would normally. The bolt should thread straight into the telescope base.
Dan
20" Obsession (Freedom I...aka cuzimthescope)
TV102 (Star Dagger)
Megrez 80SD
Antares 1529 on LXD75 Mount (Phoenix II)
Bushnell 7X50 Binoc
Zhumell 20X80 Astro-binocs
EPs: TV 2.5, 5, 7, 9, T6s, 17 & 22 T4s, 31T5, 13E, 8E.
TV Plossls 8, 11, 15, 20, 25, 32, 40mm
The Off Fisher Lane Irregulars
2 registered and 5 anonymous users are browsing this forum.
Moderator:  Joad
