Anonymous
Unregistered
Has anybody modified their tripod for easier line up of scope? Im using a 10"LX200 GPS, as a new owner of this thing I have discovered the pain of putting the scope on the tripod, after a bit of jiggling around I got it on, I was thinking about it and say their has got to be a better way, I can only wonder how the 12" and 14" people do it without 2 people, I have a friend who is a tool maker and I am thinking about hitting him up for a modification.
stuart
Reged: 11/09/03
Loc: Australia
I got a peterson mounting assistant for my 10 Inch lx200, this has made such a difference mounting the scope .Its basically a metal plate that attachs to the tripod by 3 bolts {the tripod has the holes for the bolts so you dont have to drill or anything} it has 3 yellow rubber guide pegs that form a footprint for the base of the OTA.The plate is also oversized so its much more visible when your carrying the OTA , I found trying to attach the tube beforehand it was hard to judge where i was supposed to place it , even when i got it right i was too nervous to take both hands off so trying to reach under and tighten the bolt was a uncomfortable experiance.With the plate attached the Ota feels secure as your tightening the bolt, the first night i tried about ten times just practising and i had no problems at all , the instructions are clearly explained .
Grizz
Reged: 04/24/03
Loc: Waldwick,New Jersey USA
The mounting assistant is nice. There is also a cheaper way.
Its called "The Springy Thingy" You can buy it or make one yourself. Instead of trying to explain how it works I'll point you here-----> Springy Thingy
-------------------- Craig
LX200GPS 10" UHTC SMT
ETX90EC
Orion ED80 APO
Meade LPI Canon 10d Meade DSI
My Photo Gallery
melvy
Reged: 10/17/03
Loc: Shoreline WA
Oh man that is a pain (in the back) I was going to make something, but then I got a wedge. I leave the wedge on the tripod 100% of the time now. Mounting the scope to the wedge is very easy compared to the AltAz.
-------------------- WO Megrez 80 SAPO
WO 66 SD APO
TMB SS 130 APO
C8 XLT SCT
Losmandy GM-8 w/Gemini
Losmandy G-11 w/Gemini
Discmount DM6
SBIG ST-2000XM/AO7
Marc Elvy
Anonymous
Unregistered
Im going to go with 2 aluminum plates, 1 bolted to scope and the other on the tripod base held down by tripod bolt, holes in center of both plates, will be counter sank and have 4 holes on outside of plates to bolt both plates together, will post pic when done.
Astrodave
Reged: 05/28/04
Loc: Manassas Park, Va. USA
Have any of you that use either the scopesaver or mounting assistant needed to replace the stock tripod mounting bolt with a longer one from scopestuff due to the bolt not being long enough to thread into the lx200 with the MA or SS attached? I am leaning heavily towards the MA but would like to know if i will need to replace the stock bolt with a longer one from scopestuff. Thanks in advance.
Northern Virginia
David N
Reged: 11/11/03
Loc: Portland, OR
I've been real satisfied with this Locator Plate from DigitalAstronomy.com for my LX200 - 8" Factory bolt works fine.
............David
-------------------- 10" Orion Dob
8" LX200-C
8" String "Suitcase" Dob
20" String Dob
Astrodave
Reged: 05/28/04
David:
I assume this plate works with the lx200gps as well as the lx200? Thanks.
Northern Virginia
David N
Reged: 11/11/03
Loc: Portland, OR
I don't know for sure. Mine is an 8" classic.
According to their website, they work on ALL LX200 models. Locator Plate
They also make a deluxe model - a take-off on the pizza pan design.
............David
8" LX200-C
20" String Dob
Hawkeye
Reged: 06/10/04
Loc: Melbourne, Australia
I added the 'springy thingy' to the tripod for my 10" LX200GPS and the factory bolt fits without any problem.
-------------------- 10" LX200GPS UHTC
Oberwerk 15 x 70
Canon 40D
