Astrophotography and Sketching >> Film Astrophotography
FLNightSky
Reged: 03/13/06
Understanding vignetting new
      #1301034 - 12/13/06 12:51 PM
I came across a meade 90mm Mak from the 1980s which takes .965" EPs. It also comes with a rather long T-adapter as well. I got a bit of history about this particular scope from the Cats&Casses forum but in terms of photography, the .965" tube would cause a lot of vignetting on film, right? One person who responded to my post said that a long T-adapter (moving the focal plane back farther) would reduce vignetting, but what I want to know is will there always be vignetting using this setup for taking pictures?
wilash
Fairy Godmother
Reged: 09/30/03
Re: Understanding vignetting new [Re: FLNightSky]
      #1301116 - 12/13/06 01:41 PM
That depends on the image circle at the focal plane. If the t-adapter is a 2" tube, then the image circle may be large enough. Why don't you contact Meade and ask them.
JackProton
Reged: 03/01/06
Re: Understanding vignetting [Re: FLNightSky]
      #1301399 - 12/13/06 04:11 PM
Interesting little Mak there. If it uses standard threads you may actually be able to replace the eyepiece holder with a 1.25" EP holder. There are lots of adapters made for using Cat accessories with ETX Maks like the
Meade Back Cell Adapter, ETX to SCT Accessory Adapter.
Anyways, I have a new C90. The standard Celestron T-adapter is short and narrow and causes lots of vignetting on a standard 35mm camera. I ended up replacing the Celestron T-adapter with a wider and 2X longer Orion tele-extender which fixed that nicely. If this Mak you're looking at uses standard backcell threads, you may be able to use a variable tele-extender to adjust the distance to your liking instead of using the fixed-length T-adapter.
2 registered and 3 anonymous users are browsing this forum.
Moderator:  Suk Lee, Charlie Hein, knuklhdastnmr, ClownFish
