Privacy Policy |
Please read our Terms
of Service | Signup and
DougP
Reged: 06/11/06
Loc: New Brockton, Al
I have a 127 Orion Apex set up for astronomical use and I have a problem with star collimation. The scope was jarred and knocked it out of collimation. No other damage. With a star test using the 90 degree prism finder, the diffraction rings are squeezed toward the 11 o'clock position. I am familiar with collimating a Newtonion, but don't know which way to go with the Mak. I am aware that the prism turns the image right side up and it is reversed left to right. Any instructions to get me started? Thanks.
Doug.
BillBwithley
Reged: 10/18/06
Loc: Essex, UK
Hello Doug, I am not familar with your Mak, but I can tell you how I collimate my MK67 primary. With the star diagonal in place, center the star in eye piece at about x150 magnification( or less to start with) and move inside focus. If the rings are bunched to one side, adjust the mirror slowly while looking to see the defocused image moving to the edge of the eyepiece. You need to move the defocused image to the side of eyepiece where the rings are bunched together and away from the side where the rings are spread out. Then re-center the star image and continue the process, making small adjustments each time until you have concentric rings. It helps if you number the adjustment screws, so you can keep track of what you are doing. Hope this makes sense.
Bill
-------------------- Tak FS102NSV
Intes MK67DL
Tak CN212
filcall
Reged: 03/18/05
Loc: Great Falls, Montana
Go to the Orion web site and download the instruction sheet titled: Collimating Orion StarMax and Apex Maksutov-Cassegrain Telescopes.
-------------------- Phil
CPC 800
SLT 102
ETX 125PE
StarMax 127
ETX 80
Coronado PST
Barska 25X100 Cosmos
Apogee RA-88-SA
DougP
Reged: 06/11/06
Thanks, Bill and Phil. Got it collimated and thr star test looks great. Very nice diffration rings. I did it outside with a Christmas ornament about 100 yards away.
Doug.
Gendo
Reged: 12/12/05
Loc: Rexburg, ID
Good to hear you fixed it. Maks aren't very easy to collimate, but the Apex is easier than a lot of others.
UWastronomer
Reged: 06/28/05
Loc: Sammamish, WA
I have the Orion Starmax 127, glad to find the document.
-------------------- StarMax 127 + clock drive
12x45 binocs
Edited by UWastronomer (12/19/06 01:27 AM)
Bart
Reged: 05/28/06
Loc: Inside the (DC) Beltway
Here's the link:
http://www.company7.com/library/orion/Inst_makcasscollim.pdf
-------------------- Mead 12" LightBridge
Orion 127mm Mak
Orion 80ED
Orion Short Tube 80
Baader Hyperion 3.5,5,8,13,17,24mm
Baader Hyperion Aspheric 31mm
Orion Sirius 25mm
Celestron Plossl 4,6,9,15,32mm
Orion UltraView 10x50
Canon XTi
My two eyes
sang33ta
Reged: 07/08/08
Loc: UK
It's imporant to remember, your test star must be in the CENTRE of your eyepiece otherwise you will get something that looks like bad collimation.
With Maks you can also look down the front of the tube and lign up the shadow of the secondary, but I might try that from the back method next time it might be easier.
-------------------- Hioptic 152mm f12.5 Maksutov
Celestron Advanced CG5-GT Mount (Mr Noisy!)
Meade 4000 Super Plossl Set
Casio QV-2900UX
Got fed up of waiting for Meade ETX-150 so put this together for £500/$1000
Edited by sang33ta (08/03/08 08:27 AM)
7 registered and 7 anonymous users are browsing this forum.
Moderator: Jason B
