jack savard
Reged: 05/26/04
Loc: quebec canada
how to mesure Eye Relief
      #130903 - 06/21/04 02:24 PM
somebody know howto mesure the Eye Relief
or the real distance where we are when we try to see something whit binocular
may be I do not have the right word I tranlate from french
but we alway see in data of saler of bino 18mm or 15 mm Eye Relief
is it ok or not what is the minimum or the maximum also
may be tow much is not good
nobody made it I AM INTEREST
46,49 N 71,14 O Québec canada 2\L100 2\D100 0\S100
Edited by jack savard (06/21/04 04:09 PM)
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: how to mesure yes relive new [Re: jack savard]
      #130982 - 06/21/04 03:43 PM
Eye Relief
Just as too little is not good, I would agree too much is not good.
I wear thin glasses to correct astigmatism, so I generally need long eye relief. However I find that 20-22mm is TOO long. At 22mm, I need to use my fingers between my glasses and the eyepiece to space my glasses far enough away to hold the view. Otherwise I get a little too close and I experience a blackout of the view.
I find about 13-15mm useable eye relief is the best with my glasses on. Even 9-10mm of eye relief allows me to see 90-95% of the field of view in my Fujinons with my glasses on.
Useable eye relief is generally 2-4mm less than advertised, and can sometimes be even less than that. This is due to the lens recess. The manufacturers stated value is measured from the lens to the point of minimum circle of light, otherwise known as the exit pupil. If the lens is recessed 3-4mm, you don't get to use it all. You get a bit less.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
jack savard
Reged: 05/26/04
Loc: quebec canada
Re: how to mesure yes relive new [Re: EdZ]
      #131024 - 06/21/04 04:21 PM
I just try a crazy thing
I take my 2X barlow and my 40mm occular and place it iin piggy back ont my tasco 20X50 bino
the result is terrific X mag I do not know how much and
I AM ABLE TO JEEP MY GLASS
somebody whit clear sky can try it may be because here it is cloudly all the week
PS about this
only if he remenber that sombody teach to him what he know;sometime they do not remenber
jack savard
Reged: 05/26/04
Loc: quebec canada
      #133634 - 06/24/04 09:17 PM
whit all that I still do not know how to mesure yes relif
I r
try whit my webcam whit lesn remove but it is very difficult to see exactly the distance
lighttrap
Reged: 02/06/04
Loc: cloudy, foggy, humid NC, US
      #133927 - 06/25/04 07:01 AM
Jack,
Are you trying to measure eye relief on a web cam? I'm not sure what the reference to a web cam with lens removed is.
But, if you want to measure eyerelief on a set of binoculars, here's one (of several) ways to do it.
First, you need to know the specifications of your binoculars to find the exit pupil. The exit pupil is the objective size in mm divided by the power. So using 10x50s as an example, you would have a 5mm exit pupil. If your binoculars are 7x50s the exit pupil would be 7mm. If 8x40s it would be 5mm and so on.
Now, take a white piece of paper and draw a 5mm circle on it, (or whatever size you came up with above). Then hold the binoculars under a bright light with the objective end (big lens end) facing the light. Now move the paper close to the eyepiece until the illuminated circle of light projecting out of the eyepiece just exactly fills the circle on the piece of paper. Measure the distance from the paper at that point, to the recessed eye lens. That is your eye relief distance. You may have to have somebody help you with this, as it takes 3 hands.
A faster, easier, less accurate way to do it, is simply to measure the distance from the surface of the eye lens to the top of the eyecups fully extended, and then add or subtract any distance that you have to hold your eye sockets off the eyecups or press into them.
Hope some of this makes sense.
18" Starsplitter II f/4.5
8" Hardin Dob f/6
C5 workhorse mini SCT f/10 or f/6.3
70mm TV Ranger dual purpose birding/astro
77mm Leica Televid APO
16x70 Fujinons on UA Deluxe Mt.
12x50 Nikon SE
8x30 Nikon E2s
and many others
jack savard
Reged: 05/26/04
Loc: quebec canada
Re: how to mesure yes relive new [Re: lighttrap]
      #134014 - 06/25/04 10:38 AM
ok I try this and give the result here
probaly when I use the webcam I mesure the image plan where the image form
my bino is 20X50 tasco and 20X60 carl sight
and my be some day some bigger X100 or X150 mirror type that I try to built
NB professor emerittous in what in optic or so
jack savard
Reged: 05/26/04
Loc: quebec canada
Re: how to mesure yes relief new [Re: jack savard]
      #141209 - 07/05/04 04:16 PM
I try THE METHOD
and it is ok
but the webcam method also work well
somebody can try it also and tel us what he find may be
I thing in fact we see the focal plan image and this is the same as yedrelief
AND PLUS you can used it on your telecope yespieces
I hope I receive results
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
      #141294 - 07/05/04 06:49 PM
Jack.
I read ALL your posts , but must admit that I do not always understand EXACTLY what it is you are trying to explain or ask.
As regards EYE RELIEF -- YES -- it IS important -- and it CAN be measured -- but at the end of the day -- once you have bought a binocular, or an eyepiece -- you own it , and are stuck with it --unless you sell it.
One of my binoculars -- a Japanese 15 x 70 has only 8mm eye relief -- far too short for perfection -- bit I STILL use that binocular -- and enjoy doing so too.
O.K -- we might lose a little field of view -- but in many cases THAT area of field of view is not very clear to look at anyway -- so I think that this whole issue can be made too much of in some cases.
As far as your previous posts go , I have an understanding ( correct me if I'm wrong ) that you have been experimenting with placing a lower - magnification "booster" directly in front of the "exit -pupil" in order to attain a GREAT magnification.
It is a thing I've tried many times -- and was in fact playing around with this earlier this evening.
It works better with a very low power binocular , or monocular , placing the objective lens EXACTLY in the prime position within "eye -relief" of the exit -pupil from the larger scope.
It helps if you stick to something VERY low power , such as a 3x monocular -- and much better if the objective of the monocular or " booster binocular" has an objective lens EXACTLY the same diameter as the OCULAR of the FRONT scope.
To achieve any kind of success with this , you need to have BOTH scopes / monocular / binocular MOUNTED STEADY and PEFECTLY ALIGNED -- and the higher the QUALITY of BOTH instruments , the more chance there is of a satisfactory result.
The end result is a magnification of the Original Scope MULTIPLIED by the magnification of the " booster".
It can be a great way of studying image quality and exit -pupil and of finding really fine -tuning FOCUS.
I tried this today , using my Zeiss 7 x 42 binoculars in front of my Zeiss 85mm Fluorite Scope ( set at 20x ) so the combined magnification is 7 x 20 = 140x !
By co -incidence -- the 42mm objective lens of the binocular is almost EXACTLY the same diameter as the eyepiece of the scope --and the eye -relief from the scope lens just happens to be "just short" of the "comfort zone" presented when the two surfaces are butted together.
In other words , if the "over -hang" of the 7 x 42 bino objective casing was about 3mm LESS -- so that the two glass surfaces came 3mm closer together , then I believe I would have as good a focus as possible for these "crazy" experiments.
It is interesting ( and surely perfectly explainable by someone with the technical knowledge ) that best focus is achieved when BOTH instruments are set EXACTLY as they would be optimum as if each were being used to look at the object independently.
I have never had what I would call GREAT success with these little experiments -- but some STAGGERING magnifications CAN be obtained by this crude method.
For example , using my 15 x 70s against the scope set at 60x , gives the theoretical magnification of 900x ( through a 85mm objective lens ) -- truly CRAZY for sure !
Regards -- and have fun -- Kenny.
If everyone is thinking the same thing , no-one is thinking - General George S.Patton
Zeiss 7 x 42 BGAT
Captain's Helmsman 7 x 50
Nikon 10 x 42 Superior E
Swift Audubon Kestrel 10 x 50
Helios 15 x 70 Observation
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Helios 102 f5 refractor
jack savard
Reged: 05/26/04
Loc: quebec canada
Re: how to mesure yes relief new [Re: KennyJ]
      #141435 - 07/05/04 10:09 PM
the gold of all this is
1.- be able to use glass because I have big astigmatism
2.- find a 100mm or 150mm bino beacause My yeas do not have a very good sensitivity
when you see for exemple magitude 5 or 6 star I see only 4 or 5 sometime
exemple on a casgrain 14 inch it is difficult for me to see the wirpull everybody see it
I need big objective and tow yesrs if possible glass also
13 registered and 26 anonymous users are browsing this forum.
Moderator:  EdZ
