bkushner
Reged: 11/26/06
Loc: Audubon New Jersey
Foam in Eyepiece Case
      #1394632 - 01/31/07 07:35 AM
What can be used to keep foam together when you cut and shape your case?
Celestron C80ED/SLT Mount/CG-5GT/SkyScout
Starmaster 18" DOB
Orion XT12i
Lightbridge 16"
Meade SN8"
Coronado PST
Stellarvue BV3 Bino's
Mallincam Hyper Color Plus
Rick Woods
Reged: 01/27/05
Loc: Inner Solar System
Re: Foam in Eyepiece Case new [Re: bkushner]
      #1394652 - 01/31/07 07:52 AM
Double-stick tape.
- Rick
14" LX200GPS
8" Meade 826C
AstroTay
Reged: 11/10/06
Loc: Toronto, Canada
      #1394803 - 01/31/07 09:59 AM
Foam friendly epoxy or CA (would say so on the container). Read the label carefully as some epoxy when curing generate heat and would melt the foam.
If you want to keep a particular shape....use very thin fibre glass cloth, lay it over the foam and use spray epoxy to keep it in shape over the foam. Trim the excess with a hobby knife when hard and you have a sturdy eyepiece case.
Hope this helps.
*Disclaimer*:- I'm a newbie and should not be held responsible for my advise "
Cheers.
Meade 10"LX200R w UHTC "Ocean Liner Anne" + wireless Autostar II
DSI Pro w CCD Color Filter Set
Celestron NexStar 102 SLT "SteamShip Anne"
Celestron SkyMaster 15X70 Binoculars "Can-U Anne"
*New* Canon EOS Rebel XSi/450D DSLR Camera Now Moded
mattyfatz
Reged: 12/27/06
Loc: R E N O
Re: Foam in Eyepiece Case new [Re: AstroTay]
      #1394807 - 01/31/07 10:03 AM
These guys have some spray adhesive that they claim works
www.foambymail.com
I've been thinking about buying some and making a case from scratch.
*****MATTY******
All sorts of stuff
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
Re: Foam in Eyepiece Case new [Re: mattyfatz]
      #1394926 - 01/31/07 11:25 AM
Just be carefull with any spray adhesives... You may have a foam that does not outgas (or very little), but the adhesive may have an outgasing effect...
Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
grbrown
Reged: 07/09/05
Loc: Ampthill, UK, 52:02N 0:30W
Re: Foam in Eyepiece Case new [Re: NeoDinian]
      #1408386 - 02/06/07 06:24 PM
I don't know how widely available it is, but I use 'Copydex' for any job that has to be flexible, including foam.
Graham
"one eye good, two eyes better...the more I look, the more I see"
BT100-45 degrees, plus 35,24,17,13,9mm Sieberts
15x80, 7x50 Steiners
12x50, 10x42, 8x20 Leica Trinovids
7x35 Minolta
Rusty
Reged: 08/06/03
Loc: Brooker, FL
      #1408994 - 02/06/07 11:03 PM
www.foambymail.com
I've used their spray adhesive (trouble-free) and their foam. No problems.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
tadpole
Reged: 10/16/06
Re: Foam in Eyepiece Case new [Re: Rusty]
      #1409059 - 02/06/07 11:38 PM
I've had good results using elmer's rubber cement when I rearrange the pluck foam in my case. It makes a pretty strong bond between the foam pieces and remains flexible.
Chopin
Canis Insanus
Reged: 02/03/05
Loc: In the doghouse.
      #1409119 - 02/07/07 12:21 AM
www.foambymail.com
Same here. The walls of my music studio are scattered with it, and the "Camie" spray adhesive. Good stuff. as for out-gassing, I'm not sure.
JasonŽ
Phlog
9 registered and 6 anonymous users are browsing this forum.
Moderator:  Greg K., Jason B, csa/montana
Home
