LateViewer
Reged: 11/17/05
Loc: Westchester NY
Off the Shelf L Bracket new
      #1453497 - 02/28/07 06:16 PM
I recently purchased a Celestron C130 to mount on a DSV-1 mount without thinking about the whole thing being rotated 90 degrees when mounted sideways on the DSV-1.
Does anyone make an off the shelf L bracket that would mount to the DSV-1 and support the C130?
Al
12.5" Discovery String Truss Dob
DSV-1 Alt-Az Mount
WO 66mm Petzval
Orion 127mm Mak with WO 2" Dielectric Diagonal
Celestron CG-5 GoTo
8.8, 14, 18, and 24mm Meade UWA Series 5000 EP
32, 40mm Orion Optiluxe EP
Erik D
Reged: 04/28/03
Loc: Central New Jersey, USA
Re: Off the Shelf L Bracket new [Re: LateViewer]
      #1453674 - 02/28/07 08:05 PM
I am not familiar with the C130 or the DSV mount but here is a source for lots of mounting accessories:
http://www.kendauzat.net/other.htm
I use a Giro 2 DX mount like this one:
http://www.cloudynights.com/item.php?item_id=846
If you can post a photo of what you are trying to achieve some of us may be able to make better recommendations.
ERik D
Erik D
Reged: 04/28/03
Re: Off the Shelf L Bracket [Re: Erik D]
      #1453709 - 02/28/07 08:19 PM
OK, DSV-1 = Desert Sky Astro. I have seen this mount discussed here last year:
http://www.desertskyastro.com/Mounts.html
What you need is the mount adapter designed for this mount and select the correct size rings for your OTA and attach it the the dovetail adapter:
http://www.desertskyastro.com/Dovetails.html
You can rotate the OTA inside the rings any way you wish. Does that work for you?
More possibilities here:
http://universalastronomics.com/
ERik D
9 registered and 26 anonymous users are browsing this forum.
Moderator:  Charlie Hein, FAB
Home
