Astrophotography and Sketching >> Beginning Imaging
NightVisions
Reged: 10/20/06
Loc: Sandy, OR
Getting Magnification with DSI Pro?
      #1563646 - 04/24/07 10:42 AM
I was looking at my DSI Pro, and my eyepieces, and wondering how I'm going to put the two together to get higher magnification shots. I don't see how I'd tie the two together. Additionally, most of my eyepieces are 2". I'll continue to search in the forum, but not finding anything yet.
Also, is it typical practice to use Barlows to get the closer in shots, say like for Saturn? How does the quality of such barlow affect the images? I've seen APO barlows, and barlows of all sorts. What's a good rule for selecting a barlow for this use? Thanks.
_____________________________________
LXD75 SN-8AT (F/4) w/ UHTC
Deep Sky Imager Pro
Canon EOS Elan 7e
Eye Pieces:
Orion 8mm Stratus
GS0 2" 42mm Superview
Meade Super Plossl 26mm
Chris_H
Reged: 11/24/03
Loc: Norway
Re: Getting Magnification with DSI Pro? new [Re: NightVisions]
      #1563732 - 04/24/07 11:33 AM
Get a good quality barlow instead, like a 2x or 3x Televue. cheap low quality barlows are better doorstoppers
Yes 97% of all imagers use barlows or powermates to get a bigger image scale. I have an Meade APO barlow and my Televue barlow hammers it. Just because it says APO doesnt mean its better
Chris
"Big Papa Smurf" (254mm f/4.7 Sky-Watcher Newt)
Custom Orion Optics 150mm f/8 reflektor "Planet Killer" (On its way!!!)
SPC900
Canon Powershot A610 (CHDK modded)
Canon 10D (modded)
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4 USM L
My Website
NightVisions
Reged: 10/20/06
Loc: Sandy, OR
Re: Getting Magnification with DSI Pro? new [Re: Chris_H]
      #1563761 - 04/24/07 11:48 AM
Oh, so the Barlow is ALL that's really used in many shots then. I knew eyepiece projection was one method, but there are many things my wife and I have to learn. That clears up a good deal on the Barlows. (I'll have to start reading reviews on Barlows I guess, unless I go with the method of the more money it costs, the better it must be).
Deep Sky Imager Pro
Canon EOS Elan 7e
Eye Pieces:
Orion 8mm Stratus
Chris_H
Reged: 11/24/03
Loc: Norway
      #1563873 - 04/24/07 12:48 PM
Well there are a lot of nice Barlows out there. A good guide would be Excelsis. Now, I say guide because there are some weird reviews in here but it should help you sort out the lemons anyway
Chris
SPC900
Canon 10D (modded)
My Website
nik hodges
Reged: 04/20/07
Loc: UK
      #1564142 - 04/24/07 03:12 PM
telextenders would also work both meade and televue make them but they are more expensive
Flurostar 110 [TMB] with TAK TOA/FS 0.75 reducer
Megrez 80mm triplet apo & mkIII FF
"LX200R" (8") with AP CCDT67 reducer & moonlight focuser
StarlightXpress SXVF-H16 camera/trutek filter wheel
DSI Pro II
Maxim DL/Maxpoint + adobe PS3extended
On AP900 notification list
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
Re: Getting Magnification with DSI Pro? new [Re: nik hodges]
      #1564177 - 04/24/07 03:30 PM
What you're looking for is called an eyepiece projection adapter. They were common when film was in wide spread use, but not so much anymore. I have one, but I much prefer to use a Barlow or a Powermate. You might be able to make an eyepiece projection adapter from PVC plumbing parts. What you need is a 1-1/4" drain pipe adapter to mout onto the DSI Pro converted to something that will grab onto your projection eyepiece. The magnification factor will be approximately the projection distance divided by the focal length of the eyepiece.
-John
-John
Homebuilt scopes from 4.25-16.5"
Meade LXD75-N6/SN6/SC8, DSX-90, ETX-60BB, ETX-125PE, DS-2130
Orion StarBlast, BinoViewers, Coronado PST
Rebel XT/XTi, DSI Pro (I & II), DSI, LPI, Electronic Eyepiece, Phillips SPC900NC
Tasco 60mm Refractors
Dr Nick
Reged: 01/27/06
Loc: Glen Innes, NSW, Australia
Re: Getting Magnification with DSI Pro? new [Re: jgraham]
      #1565348 - 04/25/07 01:02 AM
I only ever add a barlow for more magnification...
Clear Skies, Nick
http://www.NicksAstronomy.com
Sky Watcher 8" f/5 Newtonian(which I got when I was 10yrs old and 5yrs later I'm still adding to) w/JMI motofocus/standard, axis guider.
ToUcam Pro w/Phillips vlounge/registax/and Virtual Dub,
DSI Pro II w/envisage/photoshop cs2/,
NightVisions
Reged: 10/20/06
Loc: Sandy, OR
Re: Getting Magnification with DSI Pro? new [Re: Dr Nick]
      #1565411 - 04/25/07 02:05 AM
I get what a Barlow is, but not a "Powermate". I looked at the Excelsis site and the powermate does the same thing, but cost twice as much between the Televue Barlow and Powermate?
[edit] Just looked up more info on the Tele Vue site. That makes more sense now. Another question came to mind regarding the DSI though. What's the focal length of the DSI pro?
Deep Sky Imager Pro
Canon EOS Elan 7e
Eye Pieces:
Orion 8mm Stratus
Edited by NightVisions (04/25/07 02:20 AM)
russ_watters
Reged: 11/24/04
Loc: Trappe, PA
      #1565507 - 04/25/07 05:47 AM
A camera with no lenses doesn't have a focal length. If you are asking how to calculate magnification, it depends on how you display the image, so I usually scale my images based on print size or viewing size on a monitor and use a little trig to calculate it.
Equipment: Orion Atlas 11, ED80, DSI-C, DSI II Pro, Dell Inspiron Laptop.
www.russsscope.net
NightVisions
Reged: 10/20/06
Loc: Sandy, OR
Re: Getting Magnification with DSI Pro? new [Re: russ_watters]
      #1565843 - 04/25/07 10:39 AM
Yes, I was trying to figure out magnification. Trying to get as close to 200 magnificication as possible with the DSI Pro, and wasn't sure if I'd need a 2x, 2.5x, or 3x et cetera to get there. Such a great hobby.
Deep Sky Imager Pro
Canon EOS Elan 7e
Eye Pieces:
Orion 8mm Stratus
jgraham
Reged: 12/02/04
Loc: Dayton, Ohio
      #1565863 - 04/25/07 10:45 AM
From what I can gather a Powermate is really just a self-contained eyepiece projection system; a very good projection 'eyepiece' built into an extension tube. I had a chance to compare a 5x Powermate with my adjustable eyepiece projection unit and I really liked the Powermate. My old eyepiece projection unit is versatile (I can use several different projection eyepiece), but in comparison the Powermate is much lighter, compact, and does a very nice job.
-John
-John
9 registered and 7 anonymous users are browsing this forum.
Home
