jack savard
Reged: 05/26/04
Loc: quebec canada
best mount for 25x100
      #167913 - 08/10/04 04:58 PM
suggestion please
I just buy a new bino 25x100 and like I suspect it is too heavy
what is the best mount
parallelogram type or other
nobody made it I AM INTEREST
46,49 N 71,14 O Québec canada 2\L100 2\D100 0\S100
ArizonaScott
Reged: 04/29/04
Loc: Phoenix, AZ
Re: best mount for 25x100 new [Re: jack savard]
      #168007 - 08/10/04 06:45 PM
What do your binos weigh, and how much do you want to spend? I have the Universal Astronomics Unimount Light Basic on an Oberwerk aluminum surveyors tripod. Package price was around $500 but the maximum load for it is around 8lbs. It's solid as a rock, the movements are smooth, and it makes viewing very comfortable. You can go cheaper or more expensive depending on equipment weight and axis variations.
Scott
10" LX200 Classic, Konus 200, Orion ST80, ETX90 OTA, 60mm Celestron alt-az, Obie 20x80's, Meade 10x50's
Anonymous
Unregistered
      #168021 - 08/10/04 07:01 PM
Jack,
I use a Bogen 3221 tripod with a Bogen 501 head for my 22x100s. More than adequate for your 25x100s. Its very smooth and very stable, and reaches high enough for me to stand directly under it and view the zenith (im 5'11") Though not as comfy as a parallelogram im sure, its not as expensive either. Check out the "best of" post....lots of info and opinions about this.
Best price ive seen on the combo I have is at Etronics.com
$314.99 u.s.
Good luck
btschumy
Think Astronomy
Reged: 04/13/04
Loc: Austin, TX, USA
Re: best mount for 25x100 new [Re: ArizonaScott]
      #168027 - 08/10/04 07:09 PM
Universal Astronomics is now quoting a 10 lb capacity for the Unimount Light Basic. I have my 20x90s on one and they are about 9 lbs. I am quite happy with the way the mount carries them.
Bill Tschumy
Where is M13? Freeware -- Add a new dimension to your observing.
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: best mount for 25x100 new [Re: ]
      #168033 - 08/10/04 07:15 PM
The above two suggestions are probably the best choices for a 25x100, depending on what you like.I use the same parallelogram mount mentioned above, a UA Basic on a surveyor tripod and I use a Bogen 501 head on top of a set of 3246 legs. If you choose tripod head and legs the Bogen 501 is a wise choice. It'll easily handle the load.
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
jack savard
Reged: 05/26/04
Loc: quebec canada
Re: best mount for 25x100 new [Re: btschumy]
      #168034 - 08/10/04 07:16 PM
may be some of you have photo
in this case it is good to see because the product is not all the time avalable here in quebec canada
please
EdZModerator
Professor EdZ
Reged: 02/15/02
      #168040 - 08/10/04 07:26 PM
From the Main Index, go all the way to the bottom of the list of forums. You will see the photo galleries. Look in the Binocular photo gallery. There are several user photos of the Universal Astronomics Unimount Basic mount.
edz
member#21
Anonymous
Unregistered
Re: best mount for 25x100 new [Re: EdZ]
      #168435 - 08/11/04 08:41 AM
Best mount? That's easy-- p-mount! BUT, if cost is a factor, which it nearly is, then I agree with what most people are saying here. And that is the bogen/manfrotto head-mount. You can't easily see zenith with that setup, but it's do-able.
asaintAdministrator
Reged: 04/25/03
      #168443 - 08/11/04 08:58 AM
Well, I own and have used the T&T 3-arm mount with the 25x100s I had for a while (they are currently loaned out at the moment). This costs $285 which includes the crutch tripod. I think this is the least expensive alternative out there.
One downside is you have to decide if you will observe standing up, sitting or lying on a lounge chair. The tripod is not adjustable so you have to decide at the time of order. I had mine fit for lying on a lounge chair.
Hope this helps,
Allister T&T site
Wayne Parrish
Reged: 02/23/04
Re: best mount for 25x100 new [Re: asaint]
      #168678 - 08/11/04 01:20 PM
Try the website for Tim Hagens new "HERCULES" alt-az mount. They are available up to 12" and are rock solid on a surveyors tripod.I have a set of Miyauchi Saturn 71mm on a 8" version and love it.They are set-up for encoders also...www.helix-mfg.com Wayne Parrish
Anonymous
Unregistered
      #175560 - 08/19/04 05:15 PM
This link is for a parallelogram mount built in Ontario, Canada. About $400.00 US.
http://www.geocities.com/keulco/
Hope it helps.
14 registered and 26 anonymous users are browsing this forum.
Moderator:  EdZ
Home
