Jaxdialation
Reged: 04/01/07
Loc: St. Augustine, FL
Many of us buy Zhumell scopes as our first scope and live happily ever after. There are bunch of us who don't find the stock scope quite good enough. There have been a few problems with support following the acquisition of Zhumell by Netshops.
You can make your factory scope and accessories much better with incredible ease. All as a result of reading this post (and the corrections which others will post).
None of these ideas are my original thoughts. I picked them all up at various places here on Cloudy Nights and put them here in one place. Yes, I have done them all - except the spider vanes and tube carry.
Thanks to Tom in FLA, a fellow Floridian, gentleman and Z10 hot rodder.
Here are the common upgrades a new Zhumell owner will want to consider. The ones that are high priority NOT optional are marked with ****.
Improving quality of view:
Collimation Tools****
Why? The Zhumell tools and instructions generally are regarded as at least inadequate.
Many think they are a horrible source of nothing but frustration.
At the very least make sure your laser collimator is collimated!!!
Better solutions abound - Glatter, Catseye, etc.
Don Pensack's Pulitzer Prize winning article http://www.cloudynights.com/item.php?item_id=1648
Flocking
Why? To stop stray light from reflecting around the tube and enhance contrast
http://www.cloudynights.com/item.php?item_id=85
http://www.cloudynights.com/item.php?item_id=805
Flocking material source http://www.scopestuff.com/
Another source http://www.fpi-protostar.com/flock.htm
Eyepieces - nearly a religion - Don't rush to buy them
Why? Because its the only way to quadruple your scope investment in a way
your CFO may not notice - $2,000 worth of eyepieces could fit in a lunch bag,
if you didn't have to have that gilt-covered, walnut eyepiece case
http://www.cloudynights.com/ubbthreads/postlist.php/Cat/0/Board/Eyepieces
Edge-blackening primary and secondary
Why? To reduce stray light reflections from the mirrors' edges.
Simple - use a black Sharpie on the mirror edge bevels - Do it while you are flocking!
Replace Collimation Knobs
Why? So you can collimate without the screwdriver you forgot anyway.
Best known source http://www.bobsknobs.com/
Another source http://www.astronomy-shoppe.com/
Another source http://www.scopestuff.com/
Upgrade Primary Springs
Why? Better suport for the primary, reduce potential for torsion on the primary
Or a nearby Ace Hadware/Home Depot/Lowes for less money
Change out your secondary holder to a curved spider
Why? They look cool! And reduce defraction spikes at the 90 degree angles
One source http://www.fpi-protostar.com
Add a light shield to the top of your scope
Why? Shield your tube from the entry of stray light
http://www.trust1.com/commerce/index.asp?merchant=Razz&department=Light+Shields
Mead makes them too
Transport and set up:
Fix/avoid loose Alt hub screws (there are 4 of them) ****
Why? They will come loose - your hubs will wobble or worse the nuts will hit your primary!
Use loctite or lock washers -- do this before/while flocking!
Replace the spring loops with larger rings so they go over the knob ****
Why? Make it mucho easier to mate your tube to the mount
http://www.cloudynights.com/ubbthreads/showflat.php?Cat=&Board=reflectors&Number=1576506
Carrying the Tube - It isn't that bad really
Why? Because we haven't been to the gym in years
These guys sell a solution http://www.astronomy-shoppe.com/
There are several rolling or cart solutions
Balancing the tube
Why? Because all the glass and accessories listed here will change the balance of your scope
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/1585249/page/0/view/collapsed/sb/5/o/all/fpart/1#Post1694081
Solutions vary from metal magnets to old fanny packs with led to balance.
This guy sells a grip/friction solution called Scope Gripps http://www.astronomy-shoppe.com/
Pointing and Finding:
Telrad or other pointers ****
Why? Trust us on this one...Really
Telrad is the leader - just run a google search, or go where you got your Zuhmell!
http://www.cloudynights.com/item.php?item_id=49
Risers are available from Scope Stuff - especially helpful when pointing near zenith
Improve Az movement ****
Why? If you get it silky smooth, finding and tracking things is easier
Make sure the staples on the teflon pads aren't exposed
If that isn't good enough, get some EZ Sliders at your hardware store
Movement/scope handles
Why? I don't know, but it will keep your fingers off the eyepiece
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/1664947/page/1/view/collapsed/sb/5/o/all/fpart/1
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/1591041/page/0/view/collapsed/sb/5/o/all/fpart/1
Degree circles - Carol is a Godess for getting this thread started !
Why? She had good parents I guess - no really, so you can find stuff with incredible ease.
http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/937949/page/0/view/collapsed/sb/5/o/all/fpart/1
Laser Pointers -
Why? Nice addition when you have friends who want to know where they are looking.
Several vendors Scope Stuff and Lucky Duck also sell pointer mounts that will use your Telrad base.
Upgrading the telescope's user
How? Don't ask me.....I'm a neewb-idiot who found a village
OK this is my shot at this. I'm sure others will add, subtract or clarify. Whatever it takes to help new owners of these great scopes.
Edited by erik (07/08/07 04:27 PM)
Tom in FLA
Reged: 04/08/07
Loc: SpaceCoast, FL.
Nice work John! I'm sure we will find other ways to spend our money on these scopes.
I wish I had taken your advice on the Eyepieces. I currently have roughly 2.5X the cost of the Z10 invested in EP glass then in the scope. Will come in handy when I get that 18" StarStructure or Obsession though
Thanks again for getting the ball rolling on this.
-------------------- SpaceCoast FL.
Zhumell 10" Dob
Celestron NexStar 5
Naglers: 7T6, 12T4, 17T4, 31T5.
Stratus 21mm. Half a dozen other EPs.
TheNebulai
Reged: 01/26/07
Loc: New Jersey
Great article!
I definitely have to replace the teflon pads on mine soon, and I plan to ask for a better collimator for my B-day.
-------------------- Equipment:
Z10, Meade 8" LX90GPS, Galileo 120mm
A bunch of EP's, Filters, and Barlows
10*50 Binocs
Sony Cybershot,Philips SPC900NC,DSI Pro,
DMK21AU04/ Astronomik LRGB
Messier Count: 48
Jaxdialation
Reged: 04/01/07
Thanks Guys! - I don't want to do the math on my eyepieces:Zuhmell ratio. I know its high
Here's a thread about a tool to collimate your laser collimator http://www.cloudynights.com/ubbthreads/showflat.php/Cat/0/Number/1694404/page/0/view/collapsed/sb/5/o/all/fpart/1#Post1695053
-------------------- John
Someone please make sure that when I die, my wife doesn't sell my astro gear for what I told her I paid for it:
14.5" f4.3 SST/Tak TSA-102/RCOS 10"RCA inbound
/ST-10XME/STL-11000M/Tak EM-400/HD Tripod/Scope Buggy/Everything CCDWare has published
New Zhumell Owner? Read this: New Zhumell Owner Upgrade Mega Thread
Jaxdialation
Reged: 04/01/07
Here's a nice thread about:
(1) Finder Scope Screws
(2) Upgrading your Zuhmell Mount
Finder Scope Screws and Mount
Jaxdialation
Reged: 04/01/07
In case you are wondering about primary spring and collimation knob upgrades, here is a picture showing stock Zuhmell parts next to a couple of alternatives.
My personal feeling is that anything that speeds up collimation and adds to the strength of primary support is worth looking at. Sorry, I don't have an example of Bob's springs. My primary collimation screws were 6mm.
MarkVA
Reged: 04/16/07
Loc: Northern VA
Great reference thread John! The Z's are great little scopes if you happen to get a good unit. And all these little projects are pretty fun to do... great for those cloudy nights.
-------------------- Zhumell 10" Dob
Orion ED80 SVP
40mm SWAN, 22 LVW, N17T4, 13 Hyperion, N7T6, 5 Planetary
kwalker
Reged: 08/22/06
Loc: Oklahoma City, OK
I went to ACE Hardware today and bought new springs exactly like the above post. $1.50 for all 3 with tax. I already have a set of bobs knobs with the secondary screws also. Cant tell you how much easier those are. A must investment.
Edited by kwalker (07/05/07 02:22 PM)
Jaxdialation
Reged: 04/01/07
Thanks guys. It seems like 3 weeks since we've had decent weather here in Florida. Don't know what to do to my Zuhmell next....just buy more Naglers I guess.
kwalker
Reged: 08/22/06
Oklahoma City has been just as bad with the weather. All this carp from the Gulf of Mexico is stalled out and not moving anywhere. So we have have record rain and never ending clouds.
Edited by kwalker (07/05/07 05:16 PM)
jfosc
Reged: 05/29/07
Loc: Quakertown, PA
Forgive me - no irreverence intended - but the price for the knobs and the springs from Bobs Knobs seems steep.
$5.33 for each spring $6.66 for each secondary knobs $4.83 for each primary knob
Kwalker bought the replacement springs at ACE for 50 cents each. What makes the springs from Bob Knobs so much more $$$?
Does anyone have the thread sizes handy for someone to buy the knobs cheaper anywhere else?
-------------------- -Jim
"The Universe is expanding. That should help ease the traffic" - Stephen Wright
Zhumell f/4.9 10" Dob w/ Upgrades
Telrad
Howie Glatter 2"/1.25" Single Beam Laser
Catseye Triple Pack Pro XL
Scope Gripps
Olympus 10x50 DPS R binocs
kwalker
Reged: 08/22/06
Hi Jim,
I have no idea where you would get the knobs. Seems like if they can get them we can too. Although I did order them from Bob Knobs. I know they are a little pricey, but what a huge difference they make in collimating.
It could also be the luxury of not having to leave your house to go and look for these items
-------------------- Keith
Zhumell 10" dobsonian with $12 "Push-To"
4mm & 9mm BO/TMB Planetary, 13mm Stratus, 17mm Stratus, 32mm Widefield
Orion shorty plus 2x barlow
Catseye Xl Triple Pro Pack
Glatter Laser
Celestron 15x70
Edited by kwalker (07/05/07 05:19 PM)
Jaxdialation
Reged: 04/01/07
None taken
This nobody will quibble about - it is very easy to improve on Zhumell's screws and springs
The primary screws on my scope were 6mm. I don't know what the secondary screws are. They are probably metric as well.
Knobs have their advantages though. Means you don't need a screwdriver - which for me means one less thing to drop on my mirror !
Springs are available at Ace, I know, I bought some there, and elsewhere I'm sure. Those springs my be equal or better than these specialized astronomy sources.
Let us know your experiences !
nitroexpress
Reged: 12/16/06
Loc: Hemet, calif
Try this site..................
http://www.mcmaster.com/ and look-up KNOBS.....they have a lot of them in metric and S A E..............i have bought a lot of them for projects and use on other equipment.................. Clear, dark skies and large mirrors..................gary
-------------------- "Life is not measured by the number of breaths we take but by the moments that take our breath away."
10in Zhumell-$15/ push to circles-flocked tube
8in-c8-on a Meade GoTo EQ mount with a cg-5 Tripod
5in Meade with goto...
2in Gilbert reflector (1955 or so)
7x35 binos
Orion 100mm X 600mm Achromatic Refractor
Sac8-2 ccd camera
Jaxdialation
Reged: 04/01/07
Great link. And it looks like they have the 6mm primary collimation screw size.
yonkrz
Reged: 11/16/06
Loc: SW Minnesota
Very Cool!!,Thanks for all the info.
-------------------- 10x50 Vintage US Navy Binocs
Two sets of 7x35 Binocs
Still in the works
Jeff
Jaycin
Reged: 07/09/06
Loc: SW FLorida, USA
Nice work Jax!
-------------------- Jason
Zhumell 8" Dobsonian
60mm Meade Telestar
Sketching the Cosmos
Messier countdown: 102 down, 8 to go!
Yalta Observatory- North Port, FL
Jaxdialation
Reged: 04/01/07
Nice instructional flocking link http://www.dabsonastronomy.com/index_files/Page928.htm
kwalker
Reged: 08/22/06
For you zhumell owners. I just happen to notice today that my focuser is missing a couple of screws. Is this just mine or do they leave these on everyone? They are at the very bottom under the two small silver lock knobs. Do they play a part in anything to worry about?
Glatter Laser
Celestron 15x70
Edited by kwalker (07/19/07 04:05 PM)
Jaxdialation
Reged: 04/01/07
I had one that was about to fll out. I caught it just in time. It was a bugger to screw back in due to the focuser knob. I thought it held the focuser to the tube, but maybe if you post a picture ??
