Privacy Policy |
Please read our Terms
of Service | Signup and
Anonymous
Unregistered
I tried to look at Saturn this weekend and it just looked like a blob. The moon and m42 and star images all look good with them, but I can't get a defined image of Saturn with them. Shouldn't I be able to see Saturn's rings as being defined with them?
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
I've just responded to this same question on Astromart bino forum . In summary 20x is too low power really .
clear skies -Kenny.
-------------------- Two eyes and a preference to use both
Zeiss 7 x 42 BGAT
Captain's Helmsman 7 x 50
Nikon 10 x 42 Superior E
Swift Audubon Kestrel 10 x 50
Helios 15 x 70 Observation
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Helios 102 f5 refractor
Anonymous
Unregistered
Can anyone answer a very basic question - What is the minimum MAG x APPRERTURE binocular required to view the Saturns rings ?
EdZ
Professor EdZ
Reged: 02/15/02
I can "see" Saturn's rings with 15x70s, but not with 12x50s, although at 12x50 I can easily make out an elongated shape. I can see distinct black space between the rings and the disk with 16x70 Fujinons. With 20x80s, the rings are clearly separated from the disk and have a distinct curvature all the way around. But at these magnifications you could not even hope to see any detail in the rings. Nor could you hope to see distinct separation of the disk from the rings at any location other than the ansae.
The separation between the rings and the disk is about 7 arcseconds. People with excellent visual acuity can see things when they are magnified to an "apparent" size of about 160 to 180 arcseconds. Few can see better. That would mean you need 160/7 = 22x magnification to see this 7" separation. But Linear features are easier to see than point sources, so the needed magnification can be somewhat less.
The Cassini division is only 0.7 arcseconds wide, but is a very high contrast linear feature. Simple calculations would lead you to believe it might take 160/0.7 = 228x magnification to see the Cassini division. However these are some real results obtained with small scopes.
500mm/90m ref - 5mmU.O.ortho=100x – good contrast view, Cassini 30%-40% around,
500mm/90m ref - 6mmU.O.ortho=80x – Cassini only suspected
480mm/78m ref - 7mmU.O in 2xUltima=140x – difficult view but seen
480mm/78m ref - 4mmU.O.ortho=120x – barely seen maybe 30%,
480mm/78m ref - 5mmU.O.ortho=100x – only momentarily suspected on following ansae
600mm/76m newt cas - 5mmCel.ortho=120x – rings very distinct, but No Cassini.
The 78mm AT1010 ref is a better scope than the 76mm Swift newt cas. The 90mm is an orion ST90.
These results help illustrate that linear features can be seen easier than might be expected. That helps explain why I can see the space between the rings and the disk at only 16x rather than the predicted 22x. But all of this should give you a pretty clear indication that about all you could hope to accomplish viewing Saturn with binoculars is just barely seeing the separation of the rings at the ansae.
Because of the tilt of the rings, even when they are open to us at maximum as they were last year, the visual separation between the rings and the disk in front of the disk is only 3.5 arcseconds, only half of what we see at the ansae. (Maximum tilt 30°. Sine 30° = 0.5. 7 arcseconds x sine 30° = 3.5 arcseconds.) If I can see the separation at the ansae at 16x and in front of the disk the separation appears only half as wide then I would need twice as much magnification, a minimum of 32x magnification to see the separation of the rings in front of the disk. Now that the tilt of the rings is getting more edge on, it would take even a little more magnification.
I can see 3 of the 4 stars in the Trapezium with my 16x70s. On rare occasion, I have split all 4 components of the Trapezium with my Obie Dlx 20x80s. The closest two are about 8" apart. I have also seen all four with the 20x80s masked down to 20x50.
You have plenty of aperture to see 8" doubles or see the 7" separation of the rings from the disk. Even a 60mm aperture would suffice. It's magnification you need to see it.
edz
-------------------- Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Anonymous
Unregistered
I can see Saturn's rings in my 22x60 Takahashi binos, but like Ed so eloquently stated above, no real details can be seen. The view is very sharp with no false colors, but it's always a delight to see when one considers all the pollution in this area.
However, back to the original comment about only seeing a blob. The Oberwerk 20x80s should do better than just a blob for Saturn. Is this a collimation problem?
Nick
Anonymous
Unregistered
I think the collimation is good because I only see one image of Saturn, it's just an ill defined image.
Anonymous
Unregistered
I re-read your first post and you state that you can see the Moon, M-42 and stars with no problem, but Saturn is ill defined. Are you viewing Saturn low on the horizon and getting atmospheric image instability? Have you tried Mars or Jupiter? Are they sharper or the same?
Perhaps some other Oberwerk 20x80 owners can join in and make some comments. Guess as a last resort you can send an e-mail to Kevin at Big Binoculars and ask him. Kevin knows everything about Oberwerks.
Nick
EdZ
Professor EdZ
Reged: 02/15/02
Could be atmospheric turbulence. But could also be chromatic abberation. because Saturn is so bright, you are surely seeing effects of chromatic abberation. This results in different wavelengths of light appearing to hit focus at a different point. If chromatic abberation is poor, you will never be able to focus on bright objects, while you would be able to do just fine on less bright objects and star fields.
edz
member#21
KennyJ
Reged: 04/27/03
Loc: Lancashire UK
Just out of interest may I suggest trying masking the objective lenses down to 60mm or even 50mm and see if there is any improvement .
Saturn seems to me to be a bit of an "oddball" for viewing.
A good example is that I still prefer the views I get of Saturn in my "home -adapted Heath -Robinson" f8 50mm "plastic toy refractor fitted with a standard 10x binocular lens that just happens to squeeze into the 0.96 eyepiece socket that yields something akin to 40x image than I ever have in my 102mm f5 refractor with 25mm Plossl and 2x barlow lens.
Strangely , even when I mask the 102mm down to 65mm the image of Saturn is still no better than in the 40 x 50.
This seems not so much the case with for example Jupiter.
I've tried masking down my 15 x70 binos to as small as 15 x 30 for experimental purposes but clearly 15x is below the magnification required to split the rings from the main globe of Saturn.
Interestingly there are times when even through my Zeiss 7 x 42 binoculars I can DEFINITELY tell it is Saturn I'm looking at , and I think that with experience , even if you didn't know where to expect to see it in the sky , even with naked eye , on good clear nights it becomes apparant that this is Saturn and no other planet.
Clear skies and many of them --Kenny
Zeiss 7 x 42 BGAT
Strathspey 20 x 90
Televue 76 APO
Zeiss 85 Diascope
Anonymous
Unregistered
They don't seem to display a lot of chromatic abberation. While looking at the moon there is just a very thin line of purple around the edge of the moon, and sometimes none at all depending, I think, on how I position my eyes, but maybe the affects are different with Saturn. I will try to make some masks out of cardboard or something this weekend and see what that does just for the heck of it.,
Anonymous
Unregistered
Ed and Kenny, I agree with you both.
Kenny, I was very interested in your comments about modifying a humble "plastic toy refractor" and getting satisfactory views of Saturn. Your comment brought back memories of the very good views I was able to get with my "department store" 60mm refractor. All this talk of Saturn just about motivated me to dig that scope out when I recalled the hassle of setting up the equitorial mount and that I am presently operating with just my left arm. "Ah crumbs", I thought to myself. "Best leave it for now".
I was also thinking of getting a 1.25" adapter or whole new focuser so that I can get some better quality eyepieces for that old scope.
Kileak, it will be interesting to hear if the mask work. Good luck. Nick
10 registered and 38 anonymous users are browsing this forum.
Moderator: EdZ
