Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
I want to fool around somemore with Linux, but I can't seem to get my Dell laptop to boot from the CD. Any tips? Thanks, Hubert
-------------------- www.smoggybottom.org
WadeVC
Reged: 12/02/05
Loc: Lodi, California,
Hubert,
Can you provide just a little more info please? Will it not boot from the backup/boot CD, or is the computer not recognizing the CD drive, or....??
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
Orion UltraView 10x50 Wide-Angle Binoculars
My Sketch Gallery
My Astronomy Blog
A wise man can see more from the bottom of a well than a fool can from a mountain top.
Pedestal
Reged: 03/11/06
Oh, there are no mechanical problems with the 'puter. I just downloaded the Ubuntu and Kubuntu iso's and burned to CD. The drive reads the disks fine, but on startup, it won't boot from the CD, it boots from the HD as normal. I figured I needed to go to the bios setup, and tell it to look at the CD drive first for bootup. But I can't seem to even get into the bios setup! Thanks, Hubert
Rusty
Reged: 08/06/03
Loc: Brooker, FL
On normal bootup, hit f2 (or f12, I don't remember, but the screen should show you) to get intothe BIOS. Then change the boot order. You're on the right track, as the boot order will pick the first bootable drive, and if that's the HDD, that's where it boots from.
-------------------- N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
Pedestal
Reged: 03/11/06
Yeah, Rusty, I was going to go back to my post and add, I don't seem to get the normal bootup message. I was wondering if there was a new "trick" in XP I wasn't aware of... thanks, Hubert
NeoDinian
Experienced Postmaster
Reged: 10/05/05
Loc: Rockford Illinois
If I recall right, you can't just burn a CD and boot from it. You have to burn it correctly to BECOME a bootable CD.
Another thing to check is to boot into your Bios and see if the CD is set as a Bootable drive.
-------------------- Neo... (Jeff)
10" LX200-GPS/SMT UHTC "Draco"
Rockford, Il.
NeoDinian's Eye on the Sky!
Coming soon:
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Hubert, the early boot sequence doesn't depend on the OS - it's strictly BIOS-driven until one gets to the boot sequence, and the BIOS can be accessed with the f2-f12 key.
Jeff illuminates a very important point - a disc - any disc, HDD, floppy, CD, has to be made bootable to boot from it. On a CD-R, that has to be selected before burning, since you can't go in and change it once burned.
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
WadeVC
Reged: 12/02/05
Unfortunately this does sound like why the computer won't boot from the CD.
Orion XTi10 f/4.7
Orion XTi8 f/5.9
Meade NGC 70mm f/10
My Sketch Gallery
My Astronomy Blog
Pedestal
Reged: 03/11/06
I got it! It is F12, and you just have to be fast on the trigger. It does not display the normal "boot log" information, you just have to make sure you get F12 quick enough. And it does NOT let you into the bios, it brings up a menu choice of what media to boot from. In any case, I'm writing this from Kubuntu, as we speak! Hubert
Rusty
Reged: 08/06/03
Loc: Brooker, FL
Kewl! {"I love it when a plan comes together!" - The "A" Team)
TOA-130S
MK66 Std
Vintage C5
SolarMax 40
NJP Temma II
Sirius EQ-G
Skywatchr
Reged: 06/03/06
Loc: North-Central Pa.
If the ISO is a bootable image, you just burn it and the CD will be bootable. In this case, the ISO is a bootable image.
On most Dell computers, F2 is to get to CMOS setup, and F12 is for the boot menu. And when they are FAST computers, don't blink or you miss it.. ;-)
NeoDinian
Reged: 10/05/05
Same as I said before though... Even if it is a bootable ISO image, you need to tell your burning program (at least I do in Nero) the correct settings.. Otherwise all you end up with is a "Copy" of the ISO image on the CD (Single file), and not the data or bootable info...
Rockford, Il.
Coming soon:
Skywatchr
Reged: 06/03/06
I use Nero and just use the burn a disk from an image option. No "special" settings needed. Works every time! ;-)
NeoDinian
Reged: 10/05/05
Well that was basically my point.. If you just copy the file to the CD as a regular burn, it will NOT be a bootable...
You need to select (in mine anyways) that you want to make a bootable CD from an image.
Rockford, Il.
Coming soon:
Skywatchr
Reged: 06/03/06
Oh, yeah. The Drag -n- Drop method will not work for an Image burn.. But anyways I think all has been settled now.. ;-)
Jeff
0 registered and 3 anonymous users are browsing this forum.
Moderator: desertstars, Tom L
