stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
Tutorial 1: The Interface
First off, let me say that this is the first tutorial that I have done, and it will be a work in progress. The aim of these tutorials will be to get the user to a familiar working understanding of the program.
The Blender program is a powerful 3d application, and best of all it is free. You can download the program at Blender.org, and while you are there you can find galleries of work done in Blender.
The most common complaint heard about Blender is the interface. It is true that the interface is not something that you will normally find for a graphics program, but do not let that turn you away. The interface is designed to allow a fast, economical workflow. Once you are used to it, you will wonder why more programs are not designed like it.
Without further ado, lets get down to business.
This is what you see when you start blender up for the first time. I have numbered the items for an easy way to see what I'm describing.
- This is a cube, which is a primitve, seen from the front view.
- This is a lamp. You need at least one of these to light your scene.
- This is a camera. When you render your scene, what you see in the camera
is what you will render - The 3D workspace. Where you work your models.
- The file menu.
- The panel area. This is where most of your tweak work is done.
Ok, now that we have the general layout, we can start to figure this beast out .
The primitive is the building blocks of your models. There are a few different flavors that you can use. They are:
- plane - just an ordinary flat plane
- cube - a box
- circle - a hollow circle
- uvsphere - a ball
- icosphere - a ball made of triangles
- cylinder - a tube with the ends closed
- tube - just a hollow tube
- cone - a cylinder with one end reduced to a point
- grid - a plane that is divided up.
- monkey - who knows, but if you want to use it, its there
The lamp is what lights your models. Lighting is probably the most overlooked aspect of 3D modeling. There are a few different types of lamps
- lamp - just a plain old lamp.
- area - directional light source
- spot - same as above, but like a spotlight. in other words, a cone
- sun - the light source has parralell rays, instead of coming from a point
source - hemi - hemispherical light source. you can place this lamp anywhere, and
it will still shine on objects.
The camera is pretty straight forward. what you see in the camera is what you get. you can set the properties of the camera i.e. the focal length
The 3d workspace is where you will manipulate your models.
With the file menu you can set up your file paths, user preferences and so on.
The panel area is where you set the properties of the objects that you are working on.
Next Tutorial - Your First Model
-------------------- The man on the street does not know a star in the sky -Ralph Waldo Emerson
"Midnight Express" Orion XT10 w/ Telrad
2" crayford, and walmart special flocking
SA 8mm 60deg afov
GSO 32mm SuperPlossl
GSO 2X 1.25 Barlow
Orion SkyGlow Broadband filter
Olympus Evolt E-500
A Very Understanding Wife
Sheridan
Reged: 10/12/05
Loc: Splendora Tx
Thanks for the Tutorial!!!
If I remember correctly there are versions for Windows(?) as well as Linux, FreeBSD, Mac, and Solaris.
-------------------- Eric
Lx-200 8" Classic
Meade 3.3 Focal Reducer.
Orion Star Shoot
10" Starfinder.
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
Tutorial 2: Your First Model
We are going to start with a simple model a flower pot thingy , . Open Blender. You will notice that you have a cube(primitive), lamp, and camera on stage(3d work area). The perspective that you start in is top-down. In other words, birds eye view. You can change your view by using the numpad keys. #1 will shift your view to front view, #3 will put you in side view, and #7 will put you in top view again. Most times you will want to be in front view, so lets go ahead and do that now. press the #1 on the numpad.
You will notice that the lines that intersect have changed from red and green, to red and blue. the lines are there to represent the coordinate axis. Red is the axis that goes from left to right. Green represents the depth(forward and back), and the blue represents the vertical axis.
Next thing that we need to do is go from object mode into edit mode. If you press tab it will switch you between object and edit. Go ahead and do that. You will see the object go from being outlined in pink to having the faces highlighted in pink and you vertices highlighted in yellow. You have to be in edit mode to well, edit the object.
If you press the A key, it will dehighlight everything. If you press it again, it will rehighlight everything. Press the a key once. Nothing should be highlighted. Now press the B key.This will call up a select tool. Click and drag to form a box around the top two vertices.
With the vertices selected, press the X key. That will erase the selected vertices.(helpful hint: if you want to completely start over, you can press ctrl+X. That will erase everything and start you back to your startup configuration)
Now hit A again and that will select everything. With that done, press the E key. The E key stands for extrude. You will use this ALOT. When you hit E, it will show a menu, and you can select Region, Only Edges, or Only Vertices. Region will extrude the vertices, edges, and faces. The other two are pretty much self explanatory. We want to only extrude the edges.
If you hold down the ctrl key at the same time, it will extrude out at regular intervals. You can count the "bumps" to keep track of the lenght. Go ahead and extrude just the edges, for three "bumps". The reason we did it that way was to have the top "face" empty.
Now we are going to resize the top a bit. With the same vertices still selected, press the S key. That is a hotkey for resizing something. go ahead and strectch it out to the width of 5 units.
Next we are going to do another extrude.Go into top veiw(numpad 7).Press the E key again and select the "edges" option, then press the S key again. Reduce the size a slight bit
OK, now we are going to extrude once again...Didn't i tell you that you would do this alot... This time we are going to constrain the extrude to one axis.Go into front view (numpad 1). Start to extrude as normal, and if you push the Z key it will pop up a highlighted blue line (that would be the Z axis). Extrude down to just shy of the bottom of the pot.
Now we need to resize again. Hit S and scale it down.
Last extrude for this one . Go into top view again. Start extruding and then resize( E then edges then S) aqnd while resizing, if you press 0(zero), it will reduce down to a singularity.
Congradulations, you are done with the model!!! Now we just need to fix the lights up real quick, and then render.To do that, hit Tab to go back into object mode, and then right click the lamp. Once it is selected, press F5, which will open your shading panel. select HEMI. Now, if you press F12, the scen will render. If it looks OK there,m press F3 and it will ask you to name the file. It will be saved as a JPEG.
Here is what mine turned out like
OK folks, I guess that wraps this one up. Untill next time........
Derrek
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
Thanks for the Tutorial!!! If I remember correctly there are versions for Windows(?) as well as Linux, FreeBSD, Mac, and Solaris.
yes, they have diferent flavors for different platforms
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
orionthehunters
Reged: 05/29/05
Loc: england
Excellent Tutorial many thanks for this look forward to more in the future from you
James
-------------------- Cloudy Nights Astro Art Moderator.
Astro Chat - Co Admin
LX90 mounted on HEQ5 goto Mount.
C8 Orange Tube 1970's
WO 90mm Apo+Heq5 Skyscan Mount
Meade DSI 2 C
Canon 350D+Toucam 3
ST4-Autoguider
http://www.freewebs.com/astroartuk/
Ptarmigan
Reged: 09/23/04
Loc: Arctic
I have Blender on my computer. I will check out those tutorials. Thanks!
-------------------- Ptarmigans=Cute and Cuddly
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
no prob. it will be after the holidays till the next one, though. happy hollidays!!!
Derrek
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
Materials Part One
This tutorial is for the materials in the Blender 3d application. The reason for the breaking this tutorial into multiple parts is because there is a lot of stuff to go over. With that said, lets get started...
The first thing to do is to have an object to apply a material to. you can use a cube or whatever you choose for this tutorial, but i am going to use the flower pot thingy from the previous lesson
Once you have your object modeled, press F5(shading), or just click the button I have labeled "1". When you do that, it automatically pulls up the materials button(which I have labeled #2) and you will see below a button that says "add new"(button #3)
Once you press the "add new" button, you will see the panel block change. Iit will look like this :
If you click the gray box where the red arrow is pointing, it will give you a pop-up that looks like this :
If you click the sample button in the upper righthand corner, it gives you an eyedropper tool that is really handy when you are wanting to match something thats allready there. You can grab the color from anywhere inside the Blender interface. You can also put in a hex code, rgb value, or just use the slider dot at the bottom and then the dot in the gradiant box. Once you move your cursor out of the color pop-up panel, it will apply it to your model.(if you feel froggy, you can add a material to more than one abject at a time by copying and pasting the material to more than one data block, but thats for a more in depth tutorial in the near future )
All I did in this one was to pick a reddish color by the sliders that I talked about above.
and this is the render of it.
You can also change the background and lighting from the materiels panel. if you want to chang the lights, first you have to get into object mode(tab) and then right click the lamp that you wish to configure.
To change the background color, you first need to click on the world button(#1) and then you need color bar(#2)
Here is the render from making the background white :
Well folks, there is a lot more to materials, hence why I am breaking this up into multiple parts. At least now you shold be able to get around in the materials panel, and the best way to learn it really well is to just get in there and play....remember that Blender has a pretty lenient undo(ctrl-z) so you can go back if you need to.
The next part will be about the textures, which is part of the material panel.
Untill then, clear skies all,
Derrek
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
Dipole
Reged: 12/21/06
Loc: Right behind you
Derek,
As a complete noob who's interested in learning Blender your first tutorial really helped me! It's always helped me to have someone show me the way as opposed to just reading about it. I have a problem with the Materials section though, it doesn't show any images (using Firefox 2.0.0.6).
I have one question unrelated to your tutorials that maybe you can help me with. I have a plugin made for 3DsMax v8 that is a .dle file. It's used to make 3D terrains. Is there a way to import this into Blender?
Thanks, and keep up the great tutorials.
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
to the first part, are you running NoScript for firefox?if if you are, then make sure that you have cloudynights.com as an allowed site. i posted all of the tutorials at this site for just in case
as to your other question, i don't think that there is. blender pretty much runs python for the scripting language. one thing that you can do is go and download python at python.org. there are a lot of scripts out there that can do some groovy stuff. also you can render your own landscape fairly easily. i will go over that in the next few tuts that i put up, since right now im trying to cover the basics lol.
well, i hope that that helped out somewhat
peace, Derrek
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
orionthehunters
Reged: 05/29/05
Loc: england
Nice one Derrek, I will be having a play at your Tuts this evening.
James
Meade DSI 2 C
Canon 350D+Toucam 3
ST4-Autoguider
Siderea
Astronomess
Reged: 11/21/05
Loc: Novato
http://www.willitblend.com/
-------------------- Clear skies and pumpkin pies!
lc Carol
60mm Telescope Club
stillalearnin
Reged: 06/06/06
Loc: Clayton, NC
sorry folks, i have had a heck of a time trying to get my back and heart condition taken care of. i am gonna start on the next one. it will be on basic textures in the materials.
Siderea, i saw him on the discovery channel, it was the show where the use slow motion cameras. they put a load of lighters in there and it singed a few eyebrows, but that blender he is selling are seriously good. not much left of any of the things he threw in there.
anywyas hopefully i can get the tut up in the next day or two.
Derrek
SA 8mm 60deg afov
GSO 2X 1.25 Barlow
Olympus Evolt E-500
0 registered and 0 anonymous users are browsing this forum.
Moderator: orionthehunters
