Astrophotography and Sketching >> Film Astrophotography
jrw11
Reged: 06/09/07
Loc: U.S.A.
First shot at Pleaides
      #2041854 - 12/10/07 04:51 PM Attachment (108 downloads)
Here's my first shot at the Pleaides. Canon Rebel Ti prime focused to a Celestron C6n reflector on a CG5 mount. Fujia 400 Sensia film for several minutes.
Celestron C6n -HD Reflector
dual axis drive motors added
Orion 80mm Short tube refractor
Skyscout
Early 70's Pentax 7x50
Garrett Optical 12x60
Garrett Optical 15x70
Oberwerk 20x80 Standards
Canon Rebel Ti (film)
4 Minolta Srt cameras
Mamiya RB67 Pro-s with 180 lens
127mm KL lens for RB, Bellows hood for RB67
120 and 220 film backs
Cambo SCII 4x5 view camera
over 50 other film cameras
several eyepieces
Nebhunter
Reged: 10/04/03
Loc: Frostbite Falls
Re: First shot at Pleaides new [Re: jrw11]
      #2042423 - 12/10/07 08:20 PM
Well done for your first attempt. M45 is always a great target. Did you focus thru the view finder? Keep it up and post those images. The Sensia appears to be a good film at reasonable cost.
Handle me with Care - The Traveling Wilburys.
TEC 140 "Katyusha" - Tec field flattener. Equinox 80 -
Atlas EQ6 SynScan GPS ADM conversion. ST-4 guider.
PENTAX 67 - 400 EDif - 300 - 200 - 135 - 90 lenses.
OM-1 300 Tamron - Konica 35-100 Varifocal STI Pro Stiletto.
http://nightfly.zoomshare.com/
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: Nebhunter]
      #2042611 - 12/10/07 09:35 PM
Thanks! I have dual axis guiding motors attached. I have a Orion ST80 for a guide scope. I focused through the viewfinder. I will buy a Meade 12mm reticle eyepiece. It's because the eye relief is longer. I do know that I will probably have to use a barlow with it. I wonder how long would I have to expose to show the blue clouds.
Skyscout
several eyepieces
novbabies
Reged: 06/05/05
Loc: Northern Georgia!
      #2042628 - 12/10/07 09:39 PM
Nice shot!
Good Seeing!
Mark
Orion 12" XTi f/4.9
VERY old Edmund 6" f/8 reflector
Assorted binoculars
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: novbabies]
      #2042658 - 12/10/07 09:52 PM
Mark, about your old Edmund reflector. I remember building a 6" f/10 back in the late 60's. I bought the mirrors finished, but, had to drill the holes in the tube, etc. I think it had a grey pedestal mount. And, thanks! My shot of the double clusters came out lousy.That's why I'm getting the reticle eyepiece.
Skyscout
several eyepieces
s58y
Reged: 12/12/04
Loc: Eastern NY
      #2042773 - 12/10/07 10:31 PM
Nice -- your shot is a whole lot better than my first shot of M45.
Capturing the blue nebulosity in M45 is surprisingly difficult. With a DSLR it usually takes hours of exposure to get a good result, but I have no idea how long it takes with film.
Hutech 30D, SBIG ST-402 autoguider
SV80S, SV66 guidescope
AP900, G-11, Barndoor tracker
http://www.pbase.com/s58y
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: s58y]
      #2042911 - 12/10/07 11:40 PM Attachment (37 downloads)
s58y. Graet photos! Here's my attempt at the double cluster. And, why I'm getting the reticle eyepiece for guiding. In the eyepiece of my guidescope, the image didn't look like it was moving. But, when the slide was enlarged, it showed up clearly.To comment about my attempt:
Skyscout
several eyepieces
ClownFishModerator
Reged: 04/26/05
Loc: Islamabad, Pakistan
      #2043002 - 12/11/07 01:09 AM
Good start!
The blue nebulosity in m45 takes a long time to capture. I find about 30 minutes at f4 about minimum for a decent capture. That's a long exposure, and highly accurate tracking is required.
Now my critical review:
Your shots will benefit by post-processing. If you have access to Photoshop, we can give you some tips. First, there's too much blue. That's a fault of the film, and can be corrected easily.
Both of your shots are out of focus, which is normal when you try and focus with the viewfinder. Your eyes have the ability to focus too, and they re-focus an out-of focus star easily. This means you can never just use your eyes to focus in astrophotography. You will have blurred images 90% of the time. make a simple Hartman Mask, and then later on consider an STI Stelleto focus aid.
The second shot shows clear evidence of Polar Mis-alignment causing Field Rotation. No amount of guiding or accurate tracking will help. You can not "guide-out" Polar mis-alignment. It also shows some tracking error, caused by the mis-alignment as well.
Polar Alignment and focus are the two most frequent causes of astrophoto errors. Once you remove those two sources, your images will improve dramaticaly! Keep working on it!
CF
Learn all about POLAR ALIGNMENT with my Drift Method Tutorial and simulator!! Or visit my Foreign Service Blog!
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: ClownFish]
      #2043033 - 12/11/07 01:48 AM
Thanks Clownfish. I don't have photoshop. I let the camera store that developes the film, put the images on CD.So, a Hartman mask would be easy to make?I will get a STI stelleto when I can. I am in the process, as I mentioned earlier in getting a reticle eyepiece. Also, today I ordered a Oberwerk 20x80 standard binos.From what I've seen the sti stelleto needs to be bought for one specific camera make?. I use a Canon Rebel ti and the Mamiya SRT's.
Skyscout
several eyepieces
tommyhawk13
Reged: 09/28/07
Loc: Jacksonville, Fl
      #2043313 - 12/11/07 08:56 AM
A Hartmann mask is very simple to make, and very cheap!
Use this template generator to figure out what size holes to cut.
You can add pieces of wire, or tape to add defraction spikes, but triangle shaped holes will do the same thing.
The longer the spikes are, the better the focus.
Meade Starfinder 8,Meade SN-8 OTA, Orion Atlas, and a handfull of film cameras
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: tommyhawk13]
      #2043613 - 12/11/07 12:00 PM
Skyscout
several eyepieces
jrw11
Reged: 06/09/07
Loc: U.S.A.
      #2044050 - 12/11/07 03:08 PM
In looking at how a hartman mask is made. It occured to me that the ota cap looks almost like one. the cap on my c6n has 2 smaller protuding circles at opposite ends. one has a cap that comes off. if only scope companies would make them so that both had removable caps. it would be a hartman mask that came with the scope!
Skyscout
several eyepieces
tommyhawk13
Reged: 09/28/07
      #2044226 - 12/11/07 04:35 PM
I just used thick cardboard.
Mert
Reged: 08/31/05
Loc: Spain, Pamplona
      #2057393 - 12/17/07 05:21 PM
I also made one of cardboard ( a little bit thin )
and I asure you it works great.
Never new the difference between focussing by
eyes and hartman mask makes such a big difference!
Mert
42º49"N 1º38"W
3" Unitron refractor
6" F12 SW Maksutov,CS2-S
EQ6 + EQMOD
Webcam with 1.25" nosepiece
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: Mert]
      #2057525 - 12/17/07 06:29 PM
Thanks for all the suggestions! i was just wondering how easy it would have been if scope companies gave us the hartman mask with their newts. They just about give us most of one as it is.
Skyscout
several eyepieces
KenK
Reged: 09/26/05
Loc: MA, +41°, -71°
      #2059989 - 12/18/07 07:56 PM
I bought an extra end cap for my orion dob from orion for like $15 and cut a couple holes in it. =) Then I actually bought another one and cut holes in it and used it for a solar filter. Works great. =)
jrw11
Reged: 06/09/07
Loc: U.S.A.
Re: First shot at Pleaides new [Re: KenK]
      #2061178 - 12/19/07 10:58 AM
Great Ken! i called Celestron for my scope and they don't sell end caps.
Skyscout
several eyepieces
Moderator:  Suk Lee, Charlie Hein, knuklhdastnmr, ClownFish
Home
