Privacy Policy |
Please read our Terms
of Service | Signup and
dgs©
Reged: 03/29/04
Loc: West Monroe, Louisiana
I believe it was the fat one... the body is around the same diameter as the old flashlight bulb. I've thought about changing the resistor, but I don't want to break off any of the electrodes. Also thought of adding some sort of rheostat too.
Found the idea on the internet somewhere with a Radio Shack part number for the LED and a suggested resistor. It's been so long now that I don't recall exactly where. Here is a link to something similar. Not the site I went by, but the same idea.
NOTE: click on the pictures for a larger look and description/part numbers, etc.
-------------------- - david
8"Ø Newtonian on SVP, Moonlite CR2, Telrad
PST Oberwerk Ultra 15x70 Orion Ultraview 10×50
Hand-me-down Sears Refractor (Discoverer) 60mm×900mm
"What we have done for ourselves alone dies with us; what we have done for others and the world, remains and is immortal." --Albert Pike
o1d_dude
o1der than dirt
Reged: 10/03/07
Loc: The Big Tomato, California
As others have noted, Maglite sells an accessory pack for their AA models that includes at least one red replacement lens among other things. The pack also includes a lanyard as well as an anti-roll cap that slips over the head of the instrument and doubles as a quick lens change device. You simply place the desired replacement lens inside the ring and slip over your regular white light and you've now got a red light. I recently bought another of these accessory packs at REI locally for under $5.
I also purchased the NightIze triple LED conversion kit at Wal-Mart for under $5 so I now have a red Maglite with a red lens and a black Maglite with the white LED conversion. To prevent night vision surprises, I hang the red one from the scope mount and carry the white one in my pocket. In a pinch, I slip a red lens inside the anti-roll cover of the white LED flashlight which gives me a second red light.
Note: The white LED is a bit bright as a night vision light even with two red lenses.
-------------------- Kit
"There's only two things that excite a man, expensive toys and real expensive toys." - Red Green
* A bunch of old ATM stuff that cost me next to nothing
* A bunch of new commercial stuff that cost me an arm and a leg
Jarad
Reged: 04/28/03
Loc: Atlanta, GA
I saw some of these kits at Lowes. They had 2 versions - the 3 LED one for the AA maglights, and a brighter 1 LED version for the D-cell ones. The AA version was just under $8.
Jarad
kortylmt
Reged: 09/20/07
Loc: Monrovia, CA
Thanks, great idea. I have purchased Pezlz headlamp with additional red glass cover but it does not dim the LED light enough.
-------------------- Orion SkyQuest XT10 (w/Intelliscope) 10"/f4.7
Lanthanum 22mm, 8mm
TV4 12mm, TV6 7mm, TV3-6mm
Orion Highlight Ploessl 7-10-17-26 mm
Celestron Ultima 2x Barlow
b1g bleu
Reged: 11/14/07
Loc: Lawn Gisland, NY, USA
to dim a light quickly, cut a small hole in a piece of electrical tape and put it over the lens. stick it to side of the flashlight when not in use.
-------------------- Paul
Nexstar 8 SE
OMNI 40mm 93325 - X-CEL 25mm 93302
GO SWA 15mm FOV 72Deg
Burgess 6MM TMB
University Or 9MM
GO ND96-0.6 Filter
Celestron stuff
94112A 45Deg Erecting Prism
94119-30 4PC Filter Set 96-0.3, 23A, 38A, 58A
94162 Solar Filter (real tight fit)
93626 2" Univ Camera Camera Adapter
Homemade 17AH portable power supply
Swift Ranger Model No. 706 - (6-18x30mm)
Dick Rose
Reged: 09/25/07
Loc: Orange Beach,AL
I got a Allen-Bradley red pushbutton lense and put it on the end of my 2 battAA mag lite. fits with a slight friction and turns white again when you pull it off.
-------------------- Orion ST120/Vixen P,10" Meade SCT/lxd55gt wi lxd75 Tripod, WO binos
Binocks: Barska 15x70,2 7x50s & 2 10x50s
spaceghost
Reged: 01/04/07
Loc: Olathe, KS
The mini-maglite LED conversion kit is too bright for charts, but it is great for setup and teardown of the telescope. It's also great for when you drop something on the ground, like your eyeglasses, and have to hunt for it.
The white D-cell led bulb Nite Ize sells is enormously bright, even with tired batteries. It's a great improvement over the standard bulb, brighter light and much longer battery life.
-------------------- Justin
lynntx
Reged: 03/25/04
Loc: North Texas, USA
I bought the 3W single LED bulb conversion for my D-cell Maglight (white light) just to get the extended battery life. I am pleased with the result so far. I was a little skeptical, but it turned out to be very bright. Sometimes you just need a bright white light.
I have some smaller LED flashlights with red lenses I use outside most of the time when observing.
Lynn
-------------------- Texas, USA
Orion ST80
127mm F8 Burgess Refractor
8" F6 Dob
8X21, 8X30, 8X42, 7X50, 15X70 Binoculars
(Psalm 19:1)
3 registered and 9 anonymous users are browsing this forum.
Moderator: asaint, spaceydee
