Charlie Hein
Reged: 11/02/03
Loc: 26.06.08N, +80.23.08W
Welcome to the November 2007 Cloudy Nights Imaging/Sketching Contest poll!
Each month the best images selected from the individual Cloudy Nights Imaging and Sketching forums will be presented for the userbase to vote on. The monthly winner receives the coveted Cloudy Nights t-shirt! At the conclusion of the poll, the entry with the highest total will be the winner of the contest..
Please choose your favorite out of all the images. This poll will remain open through November 15th at midnight EST.
Here are the entries for November!
Beginning Imaging's Finalist - Glassthrower:
It was captured on October 20th, 2007 - 10:20pm CST, from Houma Louisiana. Other information regarding the equipment used is captioned in the photo.
Film Imaging's Finalist - AstroBobo:
Cygnus, three exposures, 2x25 min on Fuji Provia 400 + 1x50 min on Kodak E200. Medium format camera Pentax 6x7, Pentax Takumar 150mm lens @ f/5.6. Taken from Petrova Gora, Croatia.
Higher resolution and quality version is here
DSLR & Digital Camera Astro Imaging & Processing's Finalist - soreneck:
NGC2244 / The Rosette Nebula Capture date: November 3 Scope: Equinox 80mm Apo @ f5 (0.8X WO flattener) Mount: HEQ5 unguided Camera: Modified Canon 350, ISO800, IDAS LPS P2 filter Exposure: 60 minutes, 30x120sec lights, 12 darks, 10 flats Conditions: average seeing, good transparency Processing: stacked in DeepSkyStacker, processed in PS CS2
Larger version can be found here .
CCD Imaging & Processing's Finalist - Jared:
M42--The Orion Nebula Jared Willson November 23, 2007, Oakland, CA Losmandy GM-8 Mount; FLT-110 APO @ f/6.5 (TEC); SBIG STL-11000; FLT field flattener; Astrodon LRG&B TrueBalance "I" filters
x3 three minute exposures luminance; x3 thirty second exposures luminance; x1 three minute exposure for each of RG&B
Internally guided and captured in Equinox Image; Calibration, error rejection, DDP, and color combine in MaximDL; Post processing in Photoshop CS2
Solar System Imaging's Finalist - Bart Declercq:
Mosaic of Moretus/Clavius region - October 31st 2007 3h00 UT Each of the 6 frames is a stack of 256/2500 frames at 1/30s exposure per frame. Camera: DMK31AF Telescope: Celestron C9.25 2x barlow extended to an effective x2.7 (so FL approx. 6.4m)
Sketching Forum's Finalist - Jeremy Perez:
Subject: Comet 17P / Holmes Date/Time: November 7, 2007, 9:00 - 11:30 PM MST (November 8, 2007, 04:00 - 06:00 UT) Observing Loc: Flagstaff, AZ - Home Instrument: Orion XT8 (203 mm dia./1200 mm F/L) Eyepieces: 32 mm Sirius Plössl (38X / 66 arc minute TFOV) Conditions: Calm, intermittent high cirrus Seeing: 4/10 Pickering Transparency: Mag 6.0 NELM
As the comet has gotten larger, the outer envelope has become much less distinct. It shows up as a faint brightening near the inner envelope that fades imperceptibly into the background. The inner envelope has almost outgrown my 24 arc-minute wide 120X view. To the naked eye, it is a large, soft spot in Perseus. The binocular view is getting better as it moves closer to the Alpha Persei association and they fit in the field more comfortably.
Through both binoculars and low power telescopic views, the comet is a bluish green color. The pseudo nucleus is much less distinct, but still visible even at 38X. The inner envelope is now soft enough on the southeast side that this half displays a sort of blinking effect between direct and averted vision. The jellyfish appearance is still there, but now I can also see an ancient trilobite in the shape of the comet. The lumpy irregularities in the central condensation seem more spread out now, and had what looked like a cartoon saguaro cactus arrangement. At 38X, I noticed a bright extension flowing away from the axis of the central condensation, well outside of the soft inner envelope. Some softer fan-like extensions also seemed to peel away from the southeast and northwest sides of the inner envelope.
The sketch was created on Strathmore sketch paper, in a 3.5" sketch circle, using charcoal and graphite (2H & HB) with a chamois, blending stump and kneaded eraser. The sketch was scanned, inverted, adjusted for contrast, dust and scratches cleaned up with the clone tool, and uneven portions adjusted with dodge and burn tools. Color was added last.
Good Luck to all our finalists!
-------------------- "He's dead, Jim - I'll get his wallet, you get his tricorder." - Leonard "Bones" McCoy
Weston CSC:
AstroBobo
Reged: 07/04/07
Loc: Zagreb, Croatia
I am not worthy! The Clavius region and Holmes sketch are AMAZING! I had a hard time choosing, but my vote goes to the sketch master!
-------------------- Boris Stromar : AD Infinitum member : Zagreb, Croatia, Europe
P75SDHF : P105SDP : MN71 : CGE : STL-11000
http://www.astrobobo.net
CreationAstroGuy
Reged: 05/18/07
Loc: NW WA
Mine went to Bart. Amazing!
-------------------- Ryan Nelson
8" LX90 GPS UHTC
DSI with a 3.3 reducer
Eyepieces; 22mm Nagler, 16mm Meade Seires 5000, 26mm Meade Seires 4000, and a 9mm Burgess/TMB planitary!
Dick Lipke
Reged: 02/20/07
Loc: Marine City,Mich.
That view of the moon made me feel as if I was about to full fill my dreams,I was about to finaly land and walk on the moon. Thank you Bart Declercq.
-------------------- LX90 8",Cornado Max 40,Miyauchi 20x100 Bino's,and way to many eyepieces and filters,
Thousand Oaks 8" Ha filter
poweruser
Reged: 06/27/07
Loc: The Final Frontier
Although I'm not terribly experienced, I can say with total confidence that the Bart's shot is the sharpest I've seen by an amateur, of the moon.
-------------------- Orion 127mm Mak
EQ-3
Astro-Tech 1.25" Dielectric Diagonal
7mm, 9mm, 12.5mm UO Abbe
25mm Sirius Plössl
Roy M.
Reged: 01/31/06
Loc: Northern Virginia
Well, this is the first time the decision has been easy, OMG! Bart Declercq's moon is the sharpest moon I have ever seen from earth, HANDS DOWN!!! It looks like a snapshot from an orbiting Command Module, even sharper
WTFG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Televue NP-101is
Celestron C10-N GT + GPS
CG-5 (not for long)
Nikon D200 DSLR
Televue EPs: 3.5mm Nagler, 2x, 3x Barlows
Meade DSI Pro, ToUCam Pro II
Roy M.
Reged: 01/31/06
PS - I'm sold!!! Man, been hearing rave reviews about the C9.25 for years, but this pic has left me in awe. Of course is 90% the astrophotographer, but at least it shows the potential
Truly Amazing.
Televue NP-101is
CG-5 (not for long)
Nikon D200 DSLR
Glassthrower
Vendor - Galactic Stone & Ironworks
Reged: 04/07/05
Loc: Kuiper Belt
I took a look at my competition in the contest, and it's very humbling!
All of the photos are professional quality and Jeremy's sketches are always top-notch. I don't feel worthy of being in the poll to be honest.
Great work folks. It's very inspiring and makes me want to try my hand at more imaging.
Regards and clear skies,
MikeG
-------------------- Michael Gilmer - Member of the Meteoritical Society & Collector of Falling Stars.
Galactic Stone & Ironworks - Meteorites, Moon Rocks, Mars Rocks, & Trinitite.
Roy M.
Reged: 01/31/06
Mike, I love the target area and phase you chose, I just think none of us stood a chance against Bart's offering this month CYgnus, Rossetta, Orion and sketch (love the sketch!) are awesome pics in their own right... IMHO Bart just pushed the amateur envelope
Televue NP-101is
CG-5 (not for long)
Nikon D200 DSLR
Glassthrower
Reged: 04/07/05
Loc: Kuiper Belt
Roy, I look back through old Sky and Telescope magazines from the 1950's when astrophotography was done with plate cameras and darkrooms, and I am amazed at how far amateur imaging has come since then. We regularly see results here on CN, taken from suburban backyards, that clearly beat the "professional" and observatory photos from the old days. Bart's shot looks like it was taken on Mt. Wilson - on a good night. And Jeremy's sketches often look photographic - him and Kraterkid are in an elite league of sketching.
I never used to visit the imaging forums until I started lurking recently - to learn more about afocal imaging. Now I am getting hooked on all the great eye candy around here.
Jared
Reged: 10/11/05
Don't be so sure that Bart is going to win this one! It looks to me like he may have clipped the black point in the upper right and lower left corners...
Seriously, that is one detailed image!
-------------------- - Jared Willson
- TMB 152 f/8 Apochromat
- Fluorostar FLT-110 w/ TEC optics
- Stellarvue SV80S
- Astro-Physics Mach1 GTO
- Takahashi Teegul SP Mount
- STL-11000
hypernova
Reged: 03/31/07
Loc: PA
I am wowed by these entries. "Solar Systems Finest" Looks like an apollo Photo. Nice job guys
Edited by hypernova (12/13/07 08:15 PM)
w orchid
Reged: 04/23/07
Loc: Tampa, Fl
I am beginning to hate the contest. All of the entries are worthy to be crowned the winner.
-------------------- Celestron C8 orange tube circa 1982
Stellarvue SV102ED
george golitzin
Reged: 02/24/06
They're all great. I really like the balance and clarity of the orion image. But Bart's moon shot is flat out amazing, up there with alan friedman's best work. --george
Ironside
journeyman
Reged: 01/28/07
Loc: Ohio
cbwerner
Reged: 08/27/05
Loc: Richmond, VA
This feels so unfair to have to pick. They're all amazing, and it's a bit like apples and oranges. But pick I did.
Congratulations to all the finalists on their excellent shots!
-------------------- Chris Werner
CollinofAlabama
Reged: 11/24/03
Loc: Lubbock, Texas, USA
Jared,
I was wowed by Declerq's moon, too, but I still voted for your magnificent M42. There's something just magical about this ever so commonly imaged nebula, and your shot brings forth the magic in a poetic way. Jared, the vivid coloration wouldn't let me go.
That said, I have to concur with the others that this was truly a VERY difficult choice. All the contestants were quite close. The Cygnus is GREAT (another magical region of the skies). Of course, Declerq's Luna is in a league with Kaguya -- mesmerizing.
And no discussion is complete without mentioning soreneck's Rosette Nebula. It almost got my vote, too. That's one SHARP image, and I love the Jo-Anne McArthur photography website. Keep up the great work, Adam! Definitely good enough to be my Desktop's background in the large-frame mode. Fantastic work!
As usual, Jeremy always does great sketches with well-written narrative to flesh out the observing experience and impart an experiential sense to the brotherhood of astronomy. And Louisiana's own is throwing up some nice images, too.
Great job, everyone!
CDS
-------------------- Coelum Serendum
BAMBAM
Reged: 11/08/07
Loc: Barrie, ON
MikeG
Hi mike I would really like to see you take the same pic with your new 150mm Mak. I would really be interested in the results of that. Throw one on your thread when you get a chance.
Lawrence
Glassthrower
Reged: 04/07/05
Loc: Kuiper Belt
Here's the full-size version of my shot in the poll :
http://www.cloudynights.com/photopost/showphoto.php?photo=12154&size=big
If I'm going to do anything but casual afocal with this Mak, then I'll likely need a focal reducer.
I won't say who I voted for (us green folks shouldn't show any favoritism), but it was a tough tough choice. Regardless of whether I have an image in the contest, I am going to start following these monthly competitions on a regular basis now. I'm very impressed with the entries. Now I don't have to see the NASA Picture of the Day, I can just get my eye candy fix here on CN.
As soon as I get my mount back, I am going to start doing some imaging experiments with the Mak.
mandarpotdar
Reged: 11/28/07
Loc: Mumbai/Pune, India
Bart, I felt like flying a few kilometers above the moon surface.. excellent photo
-------------------- -Mandar Potdar
5" f/8.2 Newtonian
Orion Sirius EQ-G non-GOTO
Canon 400D
Canon 18-55mm f/3.5-5.6 (kit lens, non-IS)
Canon 50mm f/1.8
Sigma 70-300 f/4-5.6 APO DG
Various photos at http://picasaweb.google.com/mandarpotdar
