Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | (show all)
greg
Reged: 01/25/05
Loc: Central Ca.
Re: First light with Mallincam Color Hyper Plus at new [Re: smokin oakum]
      #2048374 - 12/13/07 12:30 PM
Here's a shot of M42 from my light polluted driveway in the middle of a large city ( street light only 75' from my scope). I used my MallinCam Hyper Plus,15mm of spacers, and a MFR-3 Focal Reducer. Telescope was a 30'F/4.5 and the time was 2 seconds,any more and the trap was completly overexposed.
Where's the shot? I don't see it on my computer.
Sorry I had to go back and edit and add the image, should be there now.
Greg
30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
Celestron 102mm F/5 Finderscope
2" 26mm 70* Illuminated Reticle
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
MallinCam Color Hyper Plus
9" Speco HighRes. Color CRT Monitor
Light polluted Backyard
10' Home Dome
MallinCam Deep Space Observatory
Great Darksite 1.5 Hrs. Away
Douglas
Vendor - Night Vision Astronomy
Reged: 05/21/07
Loc: Pound Ridge, NY
      #2048421 - 12/13/07 12:53 PM
Nice image Greg. You were able to preserve much of the Trapezium which is hard to do. Great job!
If you use the MallinCam from a light polluted area, you nmight consider a Na Hg filter.
So far it is the only filter I have seen work well with the MallinCam and it works better from light polluted areas.
30" scope and a Marshall Monitor! Not fair!
- Doug
BIPH - Binocular Photon Machine
IDA Member
Obsession 12.5" Argo Navis/ServoCat #1528
Tak FSQ-106 EDX2 & EM-200 Temma II
Canon 450 Xsi No Modification
QSI 532ws CCD with AstroDon Filters
Home Built Gen III Image Intensifier
Denk II Binos D14s & D21s
MallinCam Hyper Plus Color
Bunch of Naglers & 13mm Ethos
Stellarvue 80mm F/7 NHNG #36
PST SolarMax 40 Double Stack
Canon 15 x 50 IS Binoculars
AstroTrac
greg
Reged: 01/25/05
Loc: Central Ca.
Re: First light with Mallincam Color Hyper Plus at new [Re: Douglas]
      #2048449 - 12/13/07 01:08 PM
Thanks Doug,
I'm not familiar with a Na Hg filter. Where can I find info on it?
Greg
30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
10' Home Dome
Douglas
Reged: 05/21/07
Re: First light with Mallincam Color Hyper Plus at new [Re: greg]
      #2048471 - 12/13/07 01:19 PM
A fellow Westchester Astronomer, John Paladini, wrote the specs for Omega Optical and they are only selling it on Ebay. It selectively rejects the Sodium (Na) 589.6nm prominance, as well as the Mercury 577 and 436 nm peaks, yet transmits 90% of the OIII and H beta as well as H alpha, and the continuium of visible light between these atomic emissions.
Here is the link: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=170092652296&ssPageName=M
- Doug
IDA Member
AstroTrac
Douglas
Reged: 05/21/07
      #2048476 - 12/13/07 01:22 PM
While it's not my best, I took this image of NGC 2403 last night and thought I would share it:
- Doug
IDA Member
AstroTrac
greg
Reged: 01/25/05
Loc: Central Ca.
      #2048599 - 12/13/07 02:22 PM
Doug,
Do you have any images taken with and without the filter, on the same night, with the same settings?
I'd really like to see how much of an improvement there is. In his images of M-16 on E-bay there is a HUGE improvement. What are your thoughts on the M-16 comparison, Is it realistic compaired to your experience with the filter?
Greg
30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
10' Home Dome
Douglas
Reged: 05/21/07
      #2048975 - 12/13/07 04:59 PM
I ordered the filter and will do a comparison test as soon as it arrives. I asked John the same question after I saw the M16 comparison. John sent me an image he took of the Little Dumbell using the filter with the MallinCam and it darkened the sky just right but I don't have an image from the same night without the filter to compare.
- Doug
IDA Member
AstroTrac
greg
Reged: 01/25/05
Loc: Central Ca.
      #2049013 - 12/13/07 05:13 PM
OK Doug,
I look forward to your comparison test, maybe a before and after shot. If you have positive results then I will pick one up also.
Greg
30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
10' Home Dome
Douglas
Reged: 05/21/07
      #2049044 - 12/13/07 05:25 PM
It shipped today. I'll do a before and after shot when it arrives
- Doug
IDA Member
AstroTrac
greg
Reged: 01/25/05
Loc: Central Ca.
      #2049130 - 12/13/07 05:53 PM
Great,
Doug in your image of NGC 2403 it looks like you where able to capture the spiral structure but at the expense of a dark background. Is the lighter background in your image caused by light pollution? Hence the filter. Your image looks a lot like the images of faint objects that I'm able to capture. If I play with the brightness and contrast to get a darker background then I start to loose detail in the object I'm trying to capture. I'm working on flocking and light shielding to try and help with the problem...even making a light shield for the street light that's about 25' from the ground and about 75' from my scope ... hope I don't get sued by the city , it will only be hung up when I'm observing.
Greg
30" F/4.5 Truss
12" LX200 GPS
Orion ST120mm F/5
26mm T5 Nagler
20mm T5 Nagler
13mm ETHOS
Pentax XW 10mm
10' Home Dome
Douglas
Reged: 05/21/07
Re: First light with Mallincam Color Hyper Plus at [Re: greg]
      #2049197 - 12/13/07 06:20 PM
Excellent! You should put the IDA (International Dark Sky Association) Logo on the shield!
You are completely correct about playing with the brightness and contrast, it will darken the backround but I will loose the spiral structure.
My SQM read 20.6 and my skies are fairly dark, but at the longer exposure settings which I need for the faint stuff, I get that type of lighter backround. I can darken it by playing with the histogram on most images, but here I would have lost the spiral structure since it is so faint.
I think a light shield opposite the focuser would help but what I needed last night was a shield for the WATEC which was mounted on the UTA, the camera picked it up and washed out some images that could have had more contrast.
I think I can benefit from the filter but the more light pollution, the better that filter will work.
- Doug
IDA Member
AstroTrac
2 registered and 1 anonymous users are browsing this forum.
Moderator:  Chris Schroeder
Home
