Anonymous
Unregistered
Red Dot Finder on 25/40x100 Binos - Military
      #207182 - 09/27/04 05:06 PM
I'm wanting to mount a red dot finder on my set of Oberwerk 25/40x100 Binoculars (Military Model with simulated leather). I bought a Stellarvue Red Dot finder that came with a Dovetail mount. It is to be installed using double sided foam tape. I installed it and it is simply too unstable for my preference. Has anyone installed a finder like this on there 25/40 binos? I'm thinking about getting a metal strip that I can wrap around the entire external dimensions but need to find a good way to secure it. Ultimately, I want a finder that is set and will be in the same spot each time I install it. Any ideas or suggestions are certainly appreciated!
Erik
btschumy
Think Astronomy
Reged: 04/13/04
Loc: Austin, TX, USA
Re: Red Dot Finder on 25/40x100 Binos - Military new [Re: ]
      #207233 - 09/27/04 06:20 PM
I installed a red dot finder on my 20x90s using double sided foam tape and it seems perfectly stable. I don't recall if I used the tape that came with the finder or not (I may have used this finder on other scopes previously). You can get the double sided foam tape at places like Home Depot. Maybe you just need a different (possibly thinner) brand.
Using the tape is certainly a more aesthetic solution (IMO) than wrapping a metal band around the tube.
Bill Tschumy
Where is M13? Freeware -- Add a new dimension to your observing.
Anonymous
Unregistered
Re: Red Dot Finder on 25/40x100 Binos - Military new [Re: btschumy]
      #207313 - 09/27/04 08:10 PM
I absolutely agree that it would look better that way. Maybe there is a better alternative in the tape. I'll see what I can find. Thanks for the suggestion.
Anonymous
Unregistered
      #207564 - 09/27/04 11:24 PM
Velcro!.... Just kidding. Seems like you want it removable. ever try a magnet? I saw the leather. How bout
using the double sided tape (3M )in between the surface leather
and a thin precut steel plate for a magnet. of course
you might have to do a little dremeling and a magnet
of the right size and power. just beware that of some of these called mounting tapes have very strong acrylic adhesives which you might regret using. just my 2cents
Anonymous
Unregistered
      #207616 - 09/28/04 01:51 AM
Gee i forgot about the dovetail.These red dot finders remind me of after market pelletgun sights. I can imagine a hardened bracket that extends from the tripod mounting bolt then around and between the eyepieces or objectives then
terminates with a riveted or screwed on rimfire scope base
which will accept the dovetail. can also be applied to a
around the width partial body tension clamp. just my sleepy mumblings i guess.
Anonymous
Unregistered
      #207807 - 09/28/04 10:39 AM
So you realize what I'm working with, the link below is to a picture of what I have. There is no tripod mounting bolt in the traditional sense. I currently have the finder sitting on top in the center near the back of the main casing.
http://www.bigbinoculars.com/images/sideview.jpg
Anonymous
Unregistered
      #207939 - 09/28/04 01:31 PM
Ok short of drilling and tapping an area of dead space, i give up.
Anonymous
Unregistered
      #208193 - 09/28/04 05:33 PM
What about using rubber bands around the binocular casing near the objectives? That would be less potentially damaging than a "metel band" and cheaper. The bands rot after a while, but again they're cheap and plentiful.
AJTony
Reged: 04/17/04
Loc: Hamilton Square, NJ
      #208391 - 09/28/04 10:27 PM Attachment (40 downloads)
Here is where I put the dovetail mount for my Red Dot finder on my 25 X 100 bino. It's like a rock!
AJ
Oberwerk BT100-45 Binos
Apogee 25 X 100 Binos
Canon 15 X 50 IS Binos
Anonymous
Unregistered
Re: Red Dot Finder on 25/40x100 Binos - Military new [Re: AJTony]
      #208708 - 09/29/04 10:39 AM
AJ, What type of tape did you use? What I've used has a layer of foam between the adhesives and I believe that is the main cause of the instability.
ArizonaScott
Reged: 04/29/04
Loc: Phoenix, AZ
      #208823 - 09/29/04 01:20 PM
Hey now! Is that an attack on us velcro fans? I use a velcro strap between my Rigel base & Quickfinder to secure it to my 20x80's. I mount it the same way on my ST80. This probably wouldn't work too well on the military binos, but for those with standard giant binos it's an easy solution.
Scott
10" LX200 Classic, Konus 200, Orion ST80, ETX90 OTA, 60mm Celestron alt-az, Obie 20x80's, Meade 10x50's
Anonymous
Unregistered
Re: Red Dot Finder on 25/40x100 Binos - Military new [Re: ArizonaScott]
      #208952 - 09/29/04 04:47 PM
No, coz i didnt know velcro had any fans.
AJTony
Reged: 04/17/04
      #209116 - 09/29/04 09:55 PM
I used the double sided tape that came with the Orion Red Dot EZ II pointer. It is a thin foam tape.
P.S. No matter what the naysayers think, IMHO the red dot finder is one of the best gadgets there is for bino-astronomy.
AJ
Edited by AJTony (09/29/04 10:01 PM)
Anonymous
Unregistered
      #209121 - 09/29/04 10:07 PM
AJ,
I'll have to look into finding some other tape. The tape that came with mine has very think foam and the base moves quite a bit each time I touch it. The movement bothers me as it's supposed to be calibrated to the bino.
Edited by BigEasy (09/29/04 10:07 PM)
15 registered and 28 anonymous users are browsing this forum.
Moderator:  EdZ
Home
