Privacy Policy |
Please read our Terms
of Service | Signup and
RGM
Reged: 09/15/03
Loc: Burks Falls, Ontario, Canada
I would like to mount my C8 with binoviewer and Tak FS78 side by side on my ASGT mount. I will likely buy a ADM and Ken Dauzat system. I think the mount will handle the weight. Will it? Thanks
-------------------- Bob
Tak FS78
C8 SCT XLT ASGT
10" LightBridge
Denk Standards and Power Switch diagonal
mclewis1
Thread Killer
Reged: 02/25/06
Loc: New Brunswick, Canada
Bob,
For visual the mount is fine, for imaging you're going to be pushing the mount's limits. With the side by side setup you will have to pay more attention to the balance of the whole package. Since the C8 will be substantially heavier than the refractor you'll need to balance everything side to side. Then you can go ahead and balance the setup with the main counterweight. By the way you do have a second 11lb counterweight?
If it matters I vote for the ADM over Ken's side by side product. Better saddles and overall fit and finish for a higher price.
My avatar shows a C6 and an 80mm refractor with the ADM side by side mounting on a CG-5A. The only substantial change that I've made to the setup is that I now have 3 point rings for the refractor.
-------------------- Mark
C11, C6, APM/TMB115, and AT80ED - Tandem mount CGE and CG-5A, WO EZ-Touch and AT Voyager
25x100s and 8x56s, T-Mount Light, Mark 1 eyeballs - Modded 350D, DSI-P, SPC900, Mallincam
Just because you can doesn't necessarily mean that you should
Eddy
Reged: 09/30/04
Loc: Aix-en-Provence, France
Hi Bob,
Although I switched to an EM-200, it worked fine on my "old" ASGT mount. Just balance carefully.
The only thing you need to watch out for are the plastic covers of the mount. When slewing close to Polaris and vicinity, they may hit the mount and break. I had this problem and one of the electric circuits boards inside the cover got damaged.
-------------------- Cheers,
Eddy
C8 XLT, W.O. ZS80-FD 10th anniv. ed. with MoonLite D/S focuser, Tak TSA102N with FeatherTouch
Tak EM-200 Temma II, Vixen PortaMount
SXV-H9, SXV guider
SBIG CFW-10 SA filter wheel, Astromik Type2 LRGB and Astronomik 6nm H-α, 13nm SII, 13nm OIII
Taurus Mini Tracker OAG
http://www.astrophotogallery.org/showgallery.php?cat=580
RGM
Reged: 09/15/03
Mark and Eddy, I thought it would work, but just wanted to check before buying the saddle. I was planning on getting the ADM. I have purchased from Ken before and wanted to try out ADM.
I will balance very carefully. We normally only balance in 2 dimensions, now I have to learn in 3 dimensions.
Tak FS78
C8 SCT XLT ASGT
10" LightBridge
9 registered and 10 anonymous users are browsing this forum.
Moderator: Charlie Hein, lineman_16735
