fetoma
Reged: 09/26/06
Loc: NW Ohio
Meade SN-8 mirror
      #2088535 - 01/01/08 08:22 PM
Hi group,
I have a Meade SN-8 f4 mirror and cell. Can I make a regular newt out of it or does it need the corrector plate to be worth doing anything with it?
Frank
Frank in NW Ohio
Vixen CF VC200L and R200SS
Meade SN-10
Celestron 9.25" SCT
Meade 8" f/6.3 SCT
Intes-Micro M73
Stellarvue 80/480 LOMO Triplet
Takahashi FS-60C
Celestron CGE
QHY8 and SXV-H16
www.jerseydevilastronomy.com
Don WModerator
Reged: 05/19/03
Loc: Wisconsin, USA
Re: Meade SN-8 mirror new [Re: fetoma]
      #2088545 - 01/01/08 08:28 PM
The mirror is spherical. You need the corrector plate.
Don Wyman
Obsession 18" f/4.5 #1166
W/Argo Navis DSC and Torus Primary
teast
Reged: 11/10/07
Loc: Kentucky
Re: Meade SN-8 mirror new [Re: Don W]
      #2088582 - 01/01/08 08:50 PM
If it's spherical, I believe you could have it parabolized by someone who is experienced in working with fast f ratio mirrors. You could then make a nice RFT with it. Just my 2 cents.
fetoma
Reged: 09/26/06
Loc: NW Ohio
Re: Meade SN-8 mirror new [Re: teast]
      #2088601 - 01/01/08 08:58 PM
What's the difference between spherical and parabolic?
Would it be expensive to have that done?
Or, should I get a corrector plate from Meade?
Frank in NW Ohio
Meade SN-10
Celestron 9.25" SCT
Meade 8" f/6.3 SCT
Intes-Micro M73
Takahashi FS-60C
Celestron CGE
QHY8 and SXV-H16
teast
Reged: 11/10/07
Loc: Kentucky
      #2088646 - 01/01/08 09:16 PM
I don't know what the cost for either option would be - maybe someone here could shed some light on that.
As for spherical vs. parabola, a parabola brings all the light to a focus at the same point/plane (take your pick of terminology), whereas a spherical surface does not. At high f ratios (slow scopes) there is very little difference between the two, but with low f ratios (fast scopes) the difference is significant and the parabola is what you want.
Most, if not all, modern, well-made Newtonians have parabolic mirrors. It's possible that some of the smaller diameter Newtonians are spherical but they also probably have high f ratios - 10+.
teast
Reged: 11/10/07
Loc: Kentucky
      #2088661 - 01/01/08 09:22 PM
Post a new message in this forum asking about having the mirror parabolized and see what turns up.
teast
Reged: 11/10/07
Loc: Kentucky
      #2088674 - 01/01/08 09:28 PM
By the way, having the mirror parabolized would give you something pretty similar to the 8" f/4 Orion Skyview Deluxe listed in your signature line.
ClownFish
Reged: 04/26/05
Loc: Singapore
      #2089048 - 01/02/08 01:06 AM
Having the mirror "parabolized" would mean re-grinding it. This would destroy the surface, and coatings. You might as well buy a new mirror from scratch. Also, Meade will not sell just a corrector plate.
The reason Meade uses a spherical vs a parabolic mirror on the SN, is the cost of an f/4 parabolic mirror is higher, and since Meade can make a custom corrector plate cheaply, it is the most economical way to get a fast (f/4) mirror with less coma than an f/4 parabolic mirror.
CF
Learn all about Polar Alignment and Manual Guiding on my website at www.PetesAstrophotography.com! Or visit my Foreign Service Blog!
teast
Reged: 11/10/07
Loc: Kentucky
Re: Meade SN-8 mirror new [Re: ClownFish]
      #2089129 - 01/02/08 03:00 AM
Is it really necessary to re-grind the mirror when it's already (supposedly) spherical? Everything I've ever read about creating a parabola states that obtaining a polished spherical surface is the last step before creating the parabola. (I've started on a mirror but not completed it, so if I'm mistaken I need to know )
Yes, the coatings (protective and reflective) would have to be removed (and then re-coated afterwards), but that can be done using non-abrasive techniques. Mirrors are routinely re-coated and this doesn't involve re-grinding the existing surface, whether sphere or parabola.
You may be correct that it is less costly to buy a new mirror but I would not do so before at least checking out the feasibility and cost of turning the sphere into a parabola.
5 registered and 7 anonymous users are browsing this forum.
