Privacy Policy |
Please read our Terms
of Service | Signup and
Thunderhead
Reged: 08/27/05
Loc: Melbourne, Australia
Woke up at 1.45am to find clear skies and only light wind, in contrast to last nights gale force bedlam.
After only around 3 hours sleep, I was positively stoned. So yer I lugged the 10" Dob outside, discovered that the collimation had literally not budged from the previous session (which is great ) but it looked a little bit off so I played around with it for a while.
While waiting for the scope to cool, I got my torch and found I am infested with many species of spiders! I've found several orb weavers and almost walked straight into a web of a big one which was suspended between my deck and an overhanging tree brach Also found a huntsman, a couple of white tails, several black house spiders and perhaps most disturbingly, a large number of Redbacks scattered around my pool. I counted perhaps 10.
Well I began observing at around 3am.
Scope: 10" GSO Dob Temp: 17ºC Seeing: 2-3/10 Transparency: 3/5
It became evident that the seeing was extremely poor, as focusing stars above 200x became impossible. So instead of having a cry, I settled on a low power tour of the Eta Carina region
IC 2948 - Running Chicken Nebula Now this object has eluded all my attempts to see it when observing with a 4.5" reflector. So now, armed with a flocked 10 incher and a narrowband plugged into the 22mm LVW, I gave it crack. Also by now the crescent moon was up, so the sky was not as dark as it could've been. The 22mm LVW gives me 56x and a field of 1.14º. I tracked it down by centering on Lamba Cantauri. From there, I centered the small group of stars around V871 and around it I could see the nebula! It was rather obvious actually, and appeared as a large haze over the area. Checking a photo conforms that I had indeed seen the brightest portion of the nebula.
Gum 39 Another emmission nebula located about 45' WNW of Lambda Centauri. Tried it at 56x and 96x with the filter, but couldn't confirm a positive sighting. Perhaps when the moon is absent I'll give it another shot.
Eta Carina Nebula I observed it at 56x with and without filter. The difference is incredible. With the filter I have not a 10" telescope, but a 20"! The filtered view was just mindblowing, I could see a wealth of detail in the brightest portion, mottling, shading and the dark keyhole nebula stood out like a sore thumb. I could trace the entire cloud to its full dimensions, like what one sees on the photographs. Just amazing. Even though the moon was well above the horizon!
NGC 3324 Used 56x with the filter on this nebula. It appeared as a rectangular haze, orientated N-S with a well defined curved edge making up the northern side. Also in the same FOV is the nice tight open cluster NGC 3293. At this time I also did an unfiltered sweep of the region at 56x - just astounding!
Ced 122 Certainly wasn't expecting to see anything of this huge ghost of a nebula. I hunted down the star M centauri and using 56x with the filter, I slowly swept the area. Interestingly, in the field between the dim open clusters Cr271 and Ru166, I could detect a very slight brightening of the background sky. Moving the scope a bit helped identify its presence. A dark nebula lies within the cloud, and indeed this was visible as a slighter darker region. However this Nebula is very faint and needs patience. I could just barely see it. It really was only a very slight brightening of the sky. I spent about 30 minutes on this object just studying the field making sure i could actually see it.
NGC 5189 - Spiral Planetary Stumbled upon this Musca planetery inadvertantly while studying the area around Ced 122. Actually bright at 56x with the filter and it resembled a barred spiral galaxy. It had a central bar with what looked like stubby 'arms' angled at 90º to the bar and streaming away in opposing directions. This bright area was surrounded by a fainter haze. Didn't try higher mags as the seeing was genuinly poor this time round.
Took a short break here. Was annoyed to discover a spider has woven a strand of silk across the inside of the dewshield! My god, even when I'm observing, these little critters are a risk. Not only that, but a moth and a mosquito also found their way inside the tube. Man, observing is becoming hazardous!
Saturn Seeing was so poor that focusing was basically impossible even at 156x. However, the 5 moons that were visible were arranged in a neat line. One was so close to the rings, perhaps only a ring-width away.
I'd say I had a great morning's stargaze, there's nothing like a low power tour of our fabulous southern skies when the seeing doesn't deliver
-------------------- SAB - Melbourne, Australia
GSO 10" F5 Dob with flocking & dewshield
12" (304mm) F4.6 truss dob with premium optics
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
Apparently some Chileans refer to this object as the "Gabriela Mistral Nebula". If you're curious why check out http://www.astrosurf.com/antilhue/NGC%203324.htm
I was very impressed with this object from Costa Rica and of course it lies in the one of the most amazing sections of the entire sky near Eta Carinae!
Here are my notes using a 13-inch -- NGC 3324: Striking HII region and cluster 30' SE of N3293 and 90' NW of the center of the Eta Carina nebula! (outlying section of the complex) At 105x and UHC filter this huge, elongated, irregular nebula is quite bright, perhaps 15'x6' in size and tapers towards the south end where mag 5.5 HD 92207 is embedded. The nebula widens to a well-defined bulbous mass on the north end. Faint nebulosity hooks off the north end and spreads to the east and northeast. This HII region is ionized by mag 8 HD 92206 = h4338 (an 8.2/9.2 pair at 5") situated near the center of the nebula. Unfiltered, a scattered group of stars is superimposed but these just appear to be a random star grouping in the Carina section of the Milky Way.
NGC 3293: stunningly rich and bright open cluster NW of the Eta Carina nebula. At 105x, 60-70 stars are packed into 7'-8' with many of the stars seemingly arranged in concentric circles! Compact and well-detached even in a rich Carina star field. A striking linear trio of mag 6.5-7.5 stars (total length 1.5') runs SW-NE to the center including an orange (V361 Car), blue and white star (at the center). This young cluster is one of the top southern clusters and a worthy rival in beauty to the Jewel Box. Visible naked-eye and resolved in my 9x50 finder. The large HII region N3324 lies 30' SSE.
-------------------- Steve Gottlieb
18" f/4.3 Starmaster
Adventures In Deep Space
7500+ NGC/IC Visual Descriptions
NGC/IC Project
novbabies
Reged: 06/05/05
Loc: Northern Georgia!
TH, !!!
-------------------- Good Seeing!
Mark
Orion 12" XTi f/4.9
VERY old Edmund 6" f/8 reflector
Assorted binoculars
3 registered and 0 anonymous users are browsing this forum.
Moderator: Olivier Biot
