Privacy Policy |
Please read our Terms
of Service | Signup and
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
I decided to kick off 2008 with an evening of observing at Fremont Peak on New Year's night. I had a few hours of splendid skies with rock-solid seeing interspersed with some gusts of wind. I didn't try to make a limiting mag estimate from this coastal mountain top near the Monterey Bay but I was able to repeatably glimpse Comet Tuttle (total magnitude ~5.8) naked-eye and along with Holmes this made a rare treat -- two naked-eye comets in the same sky!
Before the breeze kicked in consistently, I was able to use up to 800x in my 18-inch Starmaster in this observation of the planetary NGC 1535 in Eridanus. At 565x the complex double shell structure of this gorgeous planetary was remarkable. The bright mag 12.5 central star is surrounded by a well-defined dark central hole with subtle mottling. This is surrounded by a striking bright inner ring that is relatively narrow and sharply defined. The ring has a slightly clumpy appearance, particuarly on the north side and dims slightly on the SE end. This bright ring is encased within an outer shell of fainter nebulosity which doubles the diameter. Although the inner ring is round, this outer envelope is slightly elongated SSW-NNE. At 807x the view was stunning and brighter clumps or knots within the bright inner ring appearing to sparkle at times.
Another fascinating planetary is NGC 1360 in Fornax which was faintly visible in my 80mm finder at 25x as a dim oval glow surrounding a faint star. Adding a OIII filter significantly incrased the contrast and the outline appeared better defined in the little refractor. At 115x in the 18", this unusual planetary is a huge oval or irregular egg-shape, ~6'x4', oriented SSW-NNE (PA ~30°) surrounding a very bright mag 10.4 central star. Excellent contrast with an OIII filter which really brings out its asymmetric structure. The planetary is noticeably brighter in a fan-shaped wedge spreading out from the central star to the north. At times the NE rim appeared a bit clumpy. The fainter south side has a dimmer lane extending to the southeast.
Abell 10 in Orion is a compact but relatively bright Abell that was immediately swept up at 115x and OIII filter as a 30" disc. I was surprised this planetary was still readily visible unfiltered at 115x to 220x as a faint, round disc (could have been discovered visually). The best view, though, was at 225x using a UHC filter and it appeared as a moderately bright, crisp circular disc with a slightly irregular surface brightness. Occasionally I picked up an interior sparkle - possibly a stellar knot or faint superimposed star.
Another interesting target was the bright reflection nebula, NGC 1788, in Orion. At 175x (unfiltered), two brighter stars were involved in the brightest portion of the nebula with a mag 10 star (very unequal double) at the NW end. An oval glow extends ~4'x2.5' to the SE and contains a bright "knot" that surrounds a mag 11.5 star on the SE side. Two fainter stars are also embedded within the glow forming a rhombus with the brighter stars at opposite ends. The SW edge of the main body has a sharper edge (due to dust). Surrounding this region are faint extensions that significantly increase the total size to ~8x6'. Towards the SE, dim haze could be seen as far as a 2' pair of mag 12.5 stars. Broad, wispy extensions appeared to feather off to the NE for ~6' with additional faint haze to the south. The entire complex is bounded by several mag 8-9 stars forming a striking star field.
Well, 2008 is off to a good start for me and here's hoping for many great observing nights in the coming year.
-------------------- Steve Gottlieb
18" f/4.3 Starmaster
Adventures In Deep Space
7500+ NGC/IC Visual Descriptions
NGC/IC Project
Mr. Bill
Reged: 02/09/05
Loc: Just passing through.....
Hi Steve....
would have been there but my wife made me go to a catered five course dinner with an amazing wine flight....
Oh well, next year.
-------------------- 10x50 Fujinon binos + 16x70 Fujinon binos + UA UniMount
Oberwerk BT100 45 degree +24mm Pans + Hercules fork mount
120mm f/5 Orion achromat + Moonlite focuser
130mm TMB 130SS f/7 APO refractor
140mm f/5.7 Vixen NeoAchro Petzvel refractor
150mm f/8 homemade achromat
8 inch newt with f/5 Swayze mirror
10 inch f/4.7 Orion newt + Paracorr
15 inch f/5 Discovery "Galactic Cannon"
Member IDA
sgottlieb
Reged: 07/22/07
Loc: SF Bay area
Well, New Year's eve was also a little different scenario for me...
Hope to see you again this summer in your neck of the woods (Lassen or Adin).
NGC/IC Project
novbabies
Reged: 06/05/05
Loc: Northern Georgia!
Thanks Steve, been avoiding higher mags thus far and just scanning the southern skies for differences in perception as compared to views from 8° farther north.
Gotta pull out the Barlow and short FL EPs now, though ... !
-------------------- Good Seeing!
Mark
Orion 12" XTi f/4.9
VERY old Edmund 6" f/8 reflector
Assorted binoculars
Jeff Young
Reged: 08/04/05
Loc: Ireland
Funny enough, NGC1535 was on my list last night too. Sadly, I got clouded out after sketching NGC1160/61 and so never made it there.
Sounds like I missed quite a treat (although at Pickering 5 I wasn't going to get a lot of mags on it anyway).
I may get another clear night tonight, and the seeing is predicted to improve -- I think I'll hoist NGC1535 (and NGC1514) to the top of the list....
-- Jeff.
-------------------- Nikon 18x70s / UA Millennium Colorado:
Solarscope SF70 / TV Pronto / AP400QMD Coronado SolarMax40 DS / Bogen 055+3130
APM MC1610 / Tak FC-100 / AP1200GTO Tak Mewlon 250 / AP600EGTO
walt r
Reged: 02/13/07
Loc: Doylestown, PA
I saw NGC1535 on new years eve. My log notes: At 260x with a UHC- sharp bright inner disk, dimmer fuzzy outer disk.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
olivier
Reged: 01/05/05
Loc: Belgium - Leuven
Hi Steve
Great report - thanks to share.
New years eve was completly clouded here in Belgium, so no conflicing goals
I saw NGC 1535 on Jan 29, 2006 with an 8". I described it as bright round nebula. Centre looks brighter.
Abell 10 is from now on on my target list
Best regards,
-------------------- Olivier
http://deepsky-astronomy.blogspot.com/
http://www.deepskylog.be/
Obsession 18" Classic with ServoCat and ArgoNavis
Celestron Advanced C8N-GT (8" Newton)
Canon EOS 300D
Messier: 110/110
Herschel: 400/400
Herschel II: 195/400
Jeff Young
Reged: 08/04/05
Loc: Ireland
Well, it was clear, but the seeing was abysmal (Pickering 3):
NGC1535 1/5/2008 20:40 UTC; Pickering 3; NELM 5.5; SQM 20.6 16" LX200GPS OTA, 17T4, UHC
Moderate-sized snowball at 175x with an inner, brighter disk of perhaps 4/5 total size surrounded by a considerably dimmer halo. 260x accentuates dual shells and also gives up a central star. 375x alters proportions, showing outer shell as more like 1/2 of total.
UHC improves the crispness of the edge of the inner shell.
Sadly, I was unable to see the inner mottled dark area (probably due to the remarkably bad seeing). I did do a sketch, but I haven't scanned it yet....
Cheers, -- Jeff.
5 registered and 2 anonymous users are browsing this forum.
Moderator: Olivier Biot
