Rick
Reged: 04/12/05
Loc: Tokyo, Japan
CCDCalc Pixel Rez?
      #2105827 - 01/08/08 04:56 PM
So I just got my first DSLR for Xmas, a Nikon D40, and was playing around with this software to see which of my current scopes would be best for imaging with this camera. I currently have a Pentax 75SDHF (fl=500mm), a Tak FC100 (fl-800mm/590mm) and a CN212 (fl=820mm).
I notice the software makes a pixel rez calculation, expressed as ArcSec/pixel. Is there an optimum number or range for this? If so, what are affects of not reaching or exceeding this range?
tia,
Rick
www.japanastro.com
Strgazr27
Vendor - Deep Space Mods and Composites
Reged: 10/04/04
Loc: StonyHill Observatory
Re: CCDCalc Pixel Rez? new [Re: Rick]
      #2105971 - 01/08/08 06:11 PM
Rick,
Ideally, you'd like the AS/P number to be right around what your seeing conditions will permit as far as resolution goes. If your seeing usually limits you to around 2.5 AS/Pixel than anything lower than that will really be wasted to the seeing. I'm sure Dean or Matt can get real detailed with this but this is a good generalization.
CS's
Bobby
Skywatcher EQ6 Pro (On it's way)
AT 130 F/6 Prototype
Royce 10" f/4 Astrograph (Under Construction)
Self Modded 40D
70-200 F2.8 L IS
SSAG
YAHOO TMB 130SS Group
Astronomy Technologies Yahoo Group
lawrie
Reged: 01/31/06
Loc: Okanagan Valley
Re: CCDCalc Pixel Rez? new [Re: Strgazr27]
      #2106075 - 01/08/08 07:01 PM
How do you determine the limits of seeing to know your AS/pixel?
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
Strgazr27
Reged: 10/04/04
Re: CCDCalc Pixel Rez? new [Re: lawrie]
      #2106441 - 01/08/08 09:41 PM
Lawrie,
If using a CCD, This is one way of doing it.
This is a very good article even though it talks of using a CCD. You can use a program such as DSLRFocus to determine FWHM values using a DSLR.
Experience also helps. Even though I have pretty decent skies a large part of the time, my seeing is rarely better than roughly 2.5 AS/P.
CS's
Bobby
Self Modded 40D
70-200 F2.8 L IS
SSAG
Arkalius
Reged: 08/03/06
Loc: Orange County, CA, USA
      #2106895 - 01/09/08 03:19 AM
Actually, you want your pixel resolution to be at least 3 times more than what seeing will allow. 0.8 to 1 arcsecond per pixel is the sweet spot. Oversampling has benefits. Just because seeing is 2.5"/pixel doesn't mean everything comes in precise 2.5" square chunks, it's a continuous image that is being digitized. It helps to oversample it some to prevent loss of detail.
-Arkalius
11" Celestron SCT on Orion Atlas EQ-G
Celestron 100ED Refractor
8" Zhumell Dobsonian Reflector
Rick
Reged: 04/12/05
Loc: Tokyo, Japan
      #2106977 - 01/09/08 05:41 AM
Thanks for those links Bobby. Helped me alot!
clear skies,
Rick
www.japanastro.com
Strgazr27
Reged: 10/04/04
Re: CCDCalc Pixel Rez? new [Re: Arkalius]
      #2107044 - 01/09/08 07:21 AM
Although I agree your always better oversampling, experience has taught me that in my situation it really doesn't make that big an improvement.
CS's
Bobby
Self Modded 40D
70-200 F2.8 L IS
SSAG
tjensen
Reged: 02/16/05
Loc: Chapel Hill, NC
      #2108075 - 01/09/08 04:38 PM
Ideally, you want to meat the Nyquist sampling criteria... two resolution elements (i.e. pixels) for the resolution of your instrument. Say your scope's theoretical resolving power is 0.45 arcsec/pixel, then you would need a set up that provides .25 arcsec/pixel. Now that is the theoretically perfect system... since seeing gets in the way, we generally never get to use our scopes at their full resolving potential.
lawrie
Reged: 01/31/06
Re: CCDCalc Pixel Rez? new [Re: tjensen]
      #2108093 - 01/09/08 04:50 PM
How do you figure out your scope's resolving power?
Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
8 registered and 11 anonymous users are browsing this forum.
