Privacy Policy |
Please read our Terms
of Service | Signup and
Rick
Reged: 04/12/05
Loc: Tokyo, Japan
So I just got my first DSLR for Xmas, a Nikon D40, and was playing around with this software to see which of my current scopes would be best for imaging with this camera. I currently have a Pentax 75SDHF (fl=500mm), a Tak FC100 (fl-800mm/590mm) and a CN212 (fl=820mm).
I notice the software makes a pixel rez calculation, expressed as ArcSec/pixel. Is there an optimum number or range for this? If so, what are affects of not reaching or exceeding this range?
tia,
Rick
-------------------- www.japanastro.com
Strgazr27
Vendor - Deep Space Mods and Composites
Reged: 10/04/04
Loc: StonyHill Observatory
Rick,
Ideally, you'd like the AS/P number to be right around what your seeing conditions will permit as far as resolution goes. If your seeing usually limits you to around 2.5 AS/Pixel than anything lower than that will really be wasted to the seeing. I'm sure Dean or Matt can get real detailed with this but this is a good generalization.
CS's
-------------------- Bobby
Skywatcher EQ6 Pro (On it's way)
AT 130 F/6 Prototype
Royce 10" f/4 Astrograph (Under Construction)
Self Modded 40D
70-200 F2.8 L IS
SSAG
YAHOO TMB 130SS Group
Astronomy Technologies Yahoo Group
lawrie
Reged: 01/31/06
Loc: Okanagan Valley
How do you determine the limits of seeing to know your AS/pixel?
-------------------- Clear Skies
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
Strgazr27
Reged: 10/04/04
Lawrie,
If using a CCD, This is one way of doing it.
This is a very good article even though it talks of using a CCD. You can use a program such as DSLRFocus to determine FWHM values using a DSLR.
Experience also helps. Even though I have pretty decent skies a large part of the time, my seeing is rarely better than roughly 2.5 AS/P.
CS's
Self Modded 40D
70-200 F2.8 L IS
SSAG
Arkalius
Reged: 08/03/06
Loc: Orange County, CA, USA
Actually, you want your pixel resolution to be at least 3 times more than what seeing will allow. 0.8 to 1 arcsecond per pixel is the sweet spot. Oversampling has benefits. Just because seeing is 2.5"/pixel doesn't mean everything comes in precise 2.5" square chunks, it's a continuous image that is being digitized. It helps to oversample it some to prevent loss of detail.
-------------------- -Arkalius
11" Celestron SCT on Orion Atlas EQ-G
Celestron 100ED Refractor
8" Zhumell Dobsonian Reflector
Rick
Reged: 04/12/05
Loc: Tokyo, Japan
Thanks for those links Bobby. Helped me alot!
clear skies, Rick
Strgazr27
Reged: 10/04/04
Although I agree your always better oversampling, experience has taught me that in my situation it really doesn't make that big an improvement.
CS's
Self Modded 40D
70-200 F2.8 L IS
SSAG
tjensen
Reged: 02/16/05
Loc: Chapel Hill, NC
Ideally, you want to meat the Nyquist sampling criteria... two resolution elements (i.e. pixels) for the resolution of your instrument. Say your scope's theoretical resolving power is 0.45 arcsec/pixel, then you would need a set up that provides .25 arcsec/pixel. Now that is the theoretically perfect system... since seeing gets in the way, we generally never get to use our scopes at their full resolving potential.
lawrie
Reged: 01/31/06
How do you figure out your scope's resolving power?
Lawrie
Ultima 8
Atlas EQ-G
ZenithStar 80 FD
DSI Pro - Pro II
Canon 350D
9 registered and 3 anonymous users are browsing this forum.
Moderator: Charlie Hein, knuklhdastnmr
