eklf
Reged: 05/12/07
Loc: Carrboro, NC
my stupidity...put wd-40 on tripod ball head..HELP
      #2111529 - 01/10/08 10:12 PM
Well Friends, here is glowing example of a momentary lapse of reason.
I just bought a used Manfrotto action grip ball head 3265G for a monopod (for binoclars). Its an old piece and made a squeeky noise as i moved the head around the socket. On the way back, while at a traffic light...I thought...squeeky? a lil dab of Wd-40 should help...faster than lightning, i reach over to my glove compartment, get out the can of wd-40, squeeze of a few rounds...Voila..Squeekyness gone!,,and then my brain started again.and sure enough..the action is now so smooth that just a little pressure moves the head right downt to horizontal.
SSOO...is there anything I can do to solve the problem ie remove all of wd40? I tried to wipe it ..but no difference..
$55 down the drain, or perhaps some way to salvage? Thanks for your time!
Clear Skies/Kumar
Clear Skies/Kumar
stevecoe
"Astronomical Tourist"
Reged: 04/24/04
Loc: Arizona, USA
Re: my stupidity...put wd-40 on tripod ball head..HELP new [Re: eklf]
      #2111540 - 01/10/08 10:19 PM
Kumar;
I can tell you that Formula 409 cleaner will disolve the WD 40 with time. Soak it for a while and then wipe it clean. Two or three treatments ought to remove the WD 40.
I don't know what you use as a replacement once the WD 40 is gone. Maybe Vasoline?
Hope that helps;
Steve Coe
TeleVue 102 refractor on CGEM mount
9.25 inch Celestron SCT
Author "Deep Sky Observing" Springer-Verlag
Author "Nebulae and How to Observe Them" Springer
Canon Xt astrocamera with Hutech modification
mranum
Reged: 09/10/07
Loc: Wisconsin
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: stevecoe]
      #2111599 - 01/10/08 10:49 PM
Go to your local auto parts store and pick up a spray can of "Brake Cleaner" or it may be called "Brake and Electric Motor Cleaner". It will take the oil right away and is safe to use on plastic, but you better test it first to be on the safe side. Whatever you do, do not get "carb or throttle body cleaner", that will melt plastic and nylon.
Edited by mranum (01/10/08 10:51 PM)
eklf
Reged: 05/12/07
Loc: Carrboro, NC
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: mranum]
      #2111653 - 01/10/08 11:16 PM
Stevecoe and mranum,
Thanks , kind sirs, for your prompt responses. They are very encouraging and I will work on that right away.
Clear Skies/Kumar
Clear Skies/Kumar
Pasquale
Encrypted
Reged: 10/12/05
Loc: Olympia, Washington
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: eklf]
      #2111958 - 01/11/08 02:53 AM
If not, Simple Green should do it...
Pasquale
Go Seahawks!
NexStar 9.25 GPS / SkyAlign
Stellarvue SV102ED
WO ZS80FD Anniversary
WO ZS66ED Triplet
Vixen Sphinx SXW
Canon EOS XT/350D, Meade DSI, NexImager
KWB
Reged: 09/30/06
Loc: Westminster,Co Elev.1646Meters
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: Pasquale]
      #2111968 - 01/11/08 03:04 AM
With judisious application,the brake cleaner will render the WD-40 persona non grata,sound about right,Mr. Pasquale?
Kenny
"Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." - Albert Einstein
goldenboy
Reged: 07/18/07
Loc: SW PA
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: KWB]
      #2112257 - 01/11/08 08:48 AM
Be sure if you use brake cleaner, or even moreso, electrical cleaner, that you read the directions/cautions on the back of the can because a lot of that stuff will melt plastic quicker than...well...you know.
This comes from first hand experience with fixing trailer brake lights. The electrical cleaner melted the red plastic tail light lens. I ended up taking it to show my Dad (his trailer) in a styrofoam cup. Ah being young and stupid. Live and learn.
Orion XT8 Intelliscope
Pasquale
Encrypted
Reged: 10/12/05
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: goldenboy]
      #2113776 - 01/11/08 07:36 PM
That sounds about right, Kenny! That should do the trick, plus when he's done, it'll stop on a dime!
Pasquale
Go Seahawks!
Stellarvue SV102ED
WO ZS66ED Triplet
Vixen Sphinx SXW
Rusty
Reged: 08/06/03
Loc: Brooker, FL
      #2114041 - 01/11/08 09:48 PM
Mineral spirits will work just fine.
N11GPS Fastar
TOA-130S
MK66 Std
Vintage C5
Megrez II 80mm ED Triplet APO
SolarMax 40
NJP Temma II
Sirius EQ-G
ST8XE/CFW-8(LRGBHa)/AO-7/DF-2/STV Dlx/ST237a/350D (Unmodded)/Mallincam Color Hyper Plus/DSI III Color/DSI II Pro
Two not-spoiled Golden Retrievers - Maggie and Casey
Sometimes I think we're alone in the universe, and sometimes I think we're not. In either case the idea is quite staggering. - Arthur C. Clarke
eklf
Reged: 05/12/07
Loc: Carrboro, NC
Re: my stupidity...put wd-40 on tripod ball head.. new [Re: Rusty]
      #2118128 - 01/13/08 06:17 PM
Greetings all,
Thanks to all of your suggestions. I took some absolute ethanol, and gently rubbed it over the head. With time, its taken a lot of it out. Enough for me to be happy!
Thanks once again,
Clear Skies/Kumar
Clear Skies/Kumar
imjeffp
Aluminum Falcon
Reged: 09/30/03
Loc: Cedar Park, Texas
      #2124787 - 01/16/08 04:22 PM
I was going to suggest a little Dawn detergent.
5 registered and 7 anonymous users are browsing this forum.
