Carl Kolchak
Reged: 08/02/06
Loc: Northeast, Florida
Big Eyes and the Orion Paragon-Plus Bino Mount
      #2112818 - 01/11/08 12:43 PM
Hi everyone,
After a somewhat successful first light report, no fault of the binoculars, I realized quickly the Z20x80s would need a different mount other than the heavy duty tripod I was using during the first light. So back to the Cloudy Nights binocular forum to research bino mounts and to determine which one would suit me and my viewing needs.
After much reading and following many links on different mounting options for my 20x80s I decided I would purchase a parallelogram style mount over any others mentioned. There are a few do it yourself options available, on the CN forum and elsewhere on the web, but I have absolutely no woodworking skills to speak of, so I ruled out a DIY project rather quickly. Luckily, Orion had their Paragon-Plus binocular mount (no tripod) on sale and the savings would cover the shipping charges, so in effect free shipping! The Orion mount comes with the proper attachment for binoculars having a front mounting type option but you will need to purchase a separate binocular mount adapter to mount the larger binoculars with a center post mount, as is the case for the Z20x80s. Ok, now with the additional purchase of the adapter ($30.00) I ended up losing the free shipping savings mentioned above.
Fed-Ex delivered the two boxes about 6 days later with no shipping damages. The assembly was very easy but I did need to remove the brass insert in the mount for it to fit my tripod. Also the mounting block for the binoculars was mounted backwards, not sure if it is for shipping purposes or a mistake, but was easy enough to correct with a glance at the accompanying instruction sheet. After a few adjustments to the legs to get to a comfortable tripod height and a few adjustments to the included 8 lb. counterweight I knew I had a very stable combination. With some trial and error I adjusted the tension knobs on the parallelogram to smooth out the movement and my new binocular mount was ready to explore the night sky.
After dark I checked out several of my favorite binocular sights ranging from the Double Cluster (NGC 884 & 869) to Comet Holmes. For me the Double Cluster always looks best in a binocular field. The Hyades and the Pleiades, very high in the sky, turned out to be the test of my new mount. In my first light post on the Z20x80s I had to hand hold them to see either of them since they were almost overhead and my tripod would not allow me to point them that high in the sky. But with the new mount I was able to stand under the binoculars and view them easily. Again the 3.2° field of view is the only way to do justice to both of these objects. Now it was a different story when I tried to view Comet Holmes, I was able to detect it with my Scenix 10x50s but when I tried to locate it with the Z20x80s I couldn't. I tried several times to locate it but could not and eventually gave up. I am not sure if the field of view prevented me from seeing it or my lack of aiming and pinpointing the object was off.
The addition of the Paragon-Plus binocular mount with my heavy duty tripod is a perfect fix for the shortcomings I experienced with my standard tripod head in the first light report. Is it what you need? Each person observes differently and has certain limits, viewable directions, etc., and something that you will need to answer on your own. However, if like me, you lack woodworking skills or woodworking tools then I recommend you take a hard look at a parallelogram type mount to enhance your binocular observing experience. With this setup I was able to view objects from horizon to zenith in any direction. Once you have the binoculars aimed and focused at the object at zenith there is no arm strain but still some neck strain but more manageable for me than before. It has come to my attention after posting my first light report here that to obtain an increase in the altitude adjustment using my standard tripod head is to mount the binos backwards, towards the tilt/lock arm of the tripod head. I have not tried the suggestion since I am very happy with my purchase of the Orion Paragon-Plus mount.
One other difficulty has arisen when using my new setup and that is aiming at objects in the night sky. I am not sure if it's the narrower field of view between the Scenix 10x50s and the Z20x80s or the size of the objectives, meaning the 20x80s are so large it's hard to tell what I am pointing them at. I had become very proficient at pointing the 10x50s at bright stars and if needed star hopping to my desired target. But the Z20x80s are an entirely different matter when it comes to aiming them at anything. It seems that I have a very difficult time pointing them at and recognizing the visible star field.
So what's next? A finder is what's next. I have ordered the Bino-Brac II with the Orion EZ finder from Astronomy-Shoppe and will report back my experience with it here. Tony at the Astronomy-Shoppe indicated I should have the items in a few days. According to the local weather I won't have clear skies until Monday or later.
Why "Big Eyes" in the title? It's really simple. I love to read and when I purchased the 20x80s I was in the middle of reading a book from the library titled The Last Ship a post apocalyptic novel written by William Brinkley. The book is written from the viewpoint of the ship's captain, Thomas, his last name is never given, as he and his crew aboard the Nathan James, a US destroyer, search for a habitable area after a nuclear exchange. During this search the crew mans a large pair of binoculars, the captian calls "Big Eyes", to search the shores looking for a safe place to start the human race anew. When I looked at the front objectives of the Z20x80s I could easily imagine that the crew had some type of large binoculars aboard the Nathan James just like my new Z20x80s.
Richard H.
Antares 105mm f/9.5 Elite Series Refractor
AstroTelescopes 102mm f/7 Refractor
Orion ShortTube 90mm f/5.6 Refractor
Meade Model 300 80mm f/15 Refractor
Tasco Cosmic 6TE-5 50mm f/12 Refractor
Orion SkyView Pro 8" Intelliscope
Orion Scenix 10x50 Binoculars
Zhumell SuperGiant 20x80 binoculars
NightSky Journal
EdZModerator
Professor EdZ
Reged: 02/15/02
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: Carl Kolchak]
      #2112875 - 01/11/08 01:05 PM
nice report!
edz
Teach a kid something today. The feeling you'll get is one of life's greatest rewards.
member#21
Friendly Giant
Reged: 12/11/07
      #2114123 - 01/11/08 10:27 PM
Thanks for the post. To address the neck strain issue, have you considered viewing high objects while laying horizontally on a reclining lawnchair? I've tried this a few times now and I find it makes my observing experience MUCH more comfortable (and also more stable, if you're handholding). I find that when I'm sitting or laying out on a lawnchair I enjoy my viewing much more because I am comfortable and can simply look up at the sky.
BTW, I don't have a parallelogram mount, but have been considering it. Sometimes I wonder how stable the binoculars are at the end of that arm after you position them. Do you find that they stay put and don't jiggle around? I'd be interested in your experience.
Thanks.
Carl Kolchak
Reged: 08/02/06
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: Friendly Giant]
      #2114245 - 01/11/08 11:19 PM
Thanks edz.
Yes I have, Friendly Giant. But I haven't taken the time to see if I can adjust the mounting block to allow me to move the binos in the altitude movement. I commonly use the 10x50s in a chaise lounger at the pool and find it quite comfortable and stable (handheld).
My setup is really stable. The tripod I use is heavy and has a wide footprint when the legs are fully extended. I was worried about that too but with the 20x80s mounted I have tried to rock them to see where the tipping point would be. So far, I would need to tip it over on purpose to spill them.
thanks,
Richard H.
NightSky Journal
Wes James
Reged: 04/12/06
      #2114838 - 01/12/08 09:43 AM
Hi again, Richard! Nice report on your new setup. It sounds like you are well on your way to becoming a bino addict! Trust me... it's contageous. I caught it from the 2 Mikes in NEFAS my first meeting!
Every Navy ship has a large set of mounted bino's on the bridge... and they've always been called "Big Eyes". It wasn't just artistic license!
Wes
Wes
Atlantic Beach, FL
Some bino’s from Miyauchi 5x32 Binon's up through Garrett 20x110 Signature's,
Some telescopes from a Stellarvue 80mm NHNG up through a couple of 8” reflectors…
And a wonderful 4.25" Delmarva Shiefspiegler!
Some good friends, made here on C/N.
Oh- several cats and a wonderful wife!
Anyone want a cat???? :-O
"When your work speaks for itself- Don't Interrupt" -Gamble Rogers
DJB
Reged: 02/23/05
Loc: Lisle NY
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: Wes James]
      #2114951 - 01/12/08 10:55 AM
Hi Friendly Giant,
I use one of the original UniMount devices. To answer one of your questions.
Although the devices may look a bit unstable, the tip is to get the binocular very well balanced. On a well-made //-ogram, the friction bearing washers and spacers will give you a firm and secure movement.
Usually, you will find materials such as mylar and teflon, etc., used on the moving moments. Sometimes these friction points are adjustable by the user.
But believe me, once properly set up, there is no movement of the binocular--very forgiving (except for the settle rate). And least not to forget the size of the aluminum bars used--that's the reason these guys weigh so much. Hope this helps you a bit.
Best regards,
Dave.
edwardmatt83
Reged: 11/13/06
Loc: Salt Lake City
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: DJB]
      #2115078 - 01/12/08 11:41 AM
Congrats on getting the paragon-plus- I just got mine in the mail yesterday. I got it set up, just waiting for the clouds to clear. Orion accidently sent me a large binocular bracket mount- isn't this the same thing that comes on the paragon plus- just making sure before I send it back. Thanks.
Orion XT8i dob w/o COL (search in progress)
Garret Optical 11x56 binoculars
Orion Paragon Plus Bino Mount
Rexburg, Idaho
Happy Birthday Special Ed
Reged: 05/18/03
Loc: Greenbrier Co., WV 38N, 80W
      #2116938 - 01/13/08 08:45 AM
Richard,
Good report. I got the Paragon p-mount last spring (along with the Paragon Plus heavy duty tripod) and have used it many times since then. My 15x70's are the Kunming Series 8 type and heavy (5.5 lb.) but the mount is steady and stays on target. The parallellogram design is very convenient because the object stays centered in the FOV whether you pull it down for a child to look through or push it up to give your local basketball team a turn at the view.
One thing--the knurled allen head cap screws on my mount rusted almost immediately after getting dew on them--you might want to protect yours.
Btw, when you said you couldn't locate Comet Holmes with the 20x80's after seeing it with the 10x50's--you were probably looking right through it. Holmes has evolved into such a huge extended object that it is best seen with low magnification.
Good luck with your future observations and clear skies!
Michael Rosolina
8" f/10 Orange Tube SCT
4.25" f/4.2 Astroscan Reflector
SVP 3.6" f/13.6 CA Reflector
40mm PST f/10
APM Germany HD 15x70 binoculars
Canon 12x36 IS II binoculars
Mark I Eyeball
My CN Gallery
Carl Kolchak
Reged: 08/02/06
      #2117636 - 01/13/08 02:35 PM
Wes
Hi Wes,
As addicting as buying telescopes!
From reading the book I got a sense that either the author served in the Navy or did very good research for it.
Richard H.
NightSky Journal
Carl Kolchak
Reged: 08/02/06
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: edwardmatt83]
      #2117652 - 01/13/08 02:42 PM
edwardmatt83,
They, whoever they are, say a picture is worth a thousand words so here are a couple of images:
This is the standard bracket for all binos that mount with a front screw, like my Scenix 10x50s:
The image below is the additional bracket I had to buy for my Z20x80s to work with the p-gram.
And this last image is of the above mentioned bracket #07589 mounted on the p-gram:
Hope this helps,
Richard H.
NightSky Journal
Carl Kolchak
Reged: 08/02/06
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: Special Ed]
      #2117663 - 01/13/08 02:48 PM
Good report.
Thank you, Special Ed.
OK, thanks for the heads up. Any suggestions on what to use?
I thought about that after I posted and I think you're right. Holmes looked fairly faint through the 10x50s, much different than it did in November or so.
Richard H.
NightSky Journal
Randy Cordell
Reged: 09/16/07
Loc: Cedar Rapids IA
      #2118512 - 01/13/08 09:26 PM
I was interested to hear this too, having just bought one a month ago myself. I'll be heading to my local hardware store for some stainless cap screws....actually, pan heads might be better for me anyway, as the caps interfere with the tripod head I mounted there.
Randy Cordell
Meade StarFinder 10" F/4.7 Dob, Telrad, Craford, Fans
Bogen 3040 and 3050 Tripods with Orion Paragon-Plus Parallelogram or 3047 head
Oberwerk Mariner 7x50
Pentax PCF WP 8x40
Garrett Optical Gemini 15x70 WP-IF
Laptop running Kubuntu and Stellarium 0.9.1
Reged: 05/18/03
      #2119563 - 01/14/08 12:06 PM
Not really sure--maybe you could try spraying the cap screws with sillicone.
Michael Rosolina
40mm PST f/10
Mark I Eyeball
My CN Gallery
Wes James
Reged: 04/12/06
      #2119859 - 01/14/08 02:08 PM
Would suggest switching to Stainless Steel hardware.
Wes
Atlantic Beach, FL
edwardmatt83
Reged: 11/13/06
Loc: Salt Lake City
      #2121337 - 01/15/08 01:15 AM
Has anyone found a good way to store and transport the paragon-plus and tripod- thinking about a bag of some kind- but i dont want the mount to scratch up my tripod.
Rexburg, Idaho
Wes James
Reged: 04/12/06
      #2121493 - 01/15/08 05:18 AM
Bags such as Orion makes for their telescopes- and use a seperate one for the tripod and mount???
Wes
DJB
Reged: 02/23/05
Loc: Lisle NY
      #2121559 - 01/15/08 07:47 AM
FYI,
Besides spraying with silicone, the product can be purchased in a gel form. The gel form can be "pressed on" to cover the hardware. I would advise changing to stainless, and, then, maybe, some silicone for good measure.
Best regards,
Dave.
Randy Cordell
Reged: 09/16/07
      #2121651 - 01/15/08 08:59 AM
I had not thought about it much - probably due to relentless clouds keeping me from ever carrying it since I bought it before the holidays! But yeah, I used to have an Orion telescope bag for a large refractor that has a divider that separates it into two compartments. I think this is the one: Orion Case
I'm pretty sure they were offering the Paragon-Plus and XHD tripod with a case but I don't see that on their web site now. Maybe they are out of stock.
If you find a better solution could you post it here?
Randy Cordell
Pentax PCF WP 8x40
meteorite
Vendor (meteorites)
Reged: 01/28/06
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: Randy Cordell]
      #3355420 - 09/25/09 06:59 AM Attachment (12 downloads)
I know this is an old thread but I wanted to ask a question related to this thread.
I recently purchased an Orion Paragon Plus tripod with parallelogram mount for my 20 x 80 binocs. The Orion website and this thread say that an adapter is needed to mount these binocs to the mount. Attached is a picture of my binoculars attached to the mount. This is as I received it from Orion. I don't use the adapter. Is somethng wrong with the way mine are mounted? Where would such an adapter go? Why is it needed?
-Walter
Man in a Tub
Not Retired!, But a little cranky!!!
Reged: 10/28/08
Loc: San Francisco, CA
Re: Big Eyes and the Orion Paragon-Plus Bino Mount new [Re: meteorite]
      #3356082 - 09/25/09 01:29 PM
-Walter
THE FOLLOWING ITALICIZED PARAGRAPH IS WRONG. IN A RUSH, I PUT THE L ADAPTER ON BACKWARDS. Todd @ 6:56 PM
I read your post a little while ago and logged out. I put my Orion Paragon Plus L Adapter back onto my Paragon Plus Mount and attached my Celestron Skymaster 20x80. I don't see how this is at all useable. With all its weight upon the L Adapter, my Celestron Skymaster 20x80 was attached with the objective lenses toward the counterweight. With the L Adapter tilted all the way back, you're locked at one altitude. The only way to go is down.
You really need to get the Bottom-Mount Binocular Mount Adapter for the Paragon Plus. It simply replaces the L Adapter. You remove the two hexagonal bolts with a 5mm Allen wrench, remove the L Adapter and then attach the Bottom Mount Adapter and secure it with those two bolts. That's all there is to it.
The pictures of the L Adapter and Bottom Mount Adapter are about as clear as possible. The Bottom Mount Adapter attached to Paragon Plus Mount was a thoughtful touch for this review.
Here's a link to the Garrett Optical page for this adapter:
Bottom-Mount Binocular Mount Adapter for Paragon Plus
Clear Skies!
Todd
Brunton Eterna 15x51 ° Garrett Optical Signature Series 15x70
Nikon Action EX 12x50 ° Oberwerk 15x60 and 20x80 Standard
Orion Paragon Plus Mount and Paragon XHD Tripod
Garrett Optical Series 2000 Grip-Action Monopod
Edited by Man in a Tub (09/25/09 10:00 PM)
10 registered and 8 anonymous users are browsing this forum.
Moderator:  EdZ
