ThorBob
Reged: 11/22/06
Loc: 69.19°N, 16.7°E (Norway)
M45 through 300mm telephoto. new
      #2102056 - 01/06/08 10:07 PM
This weekend I took my first shot at imaging the Pleiades. For a semi wide-ish view I used my D300 with a Nikkor 300 f2.8 lens, all mounted on a HEQ5 mount.
After seeing some of the stunning results by others in this forum I know there is massive room for improvement, and I am open to all suggestions!
Shot January 5 2008. Nikon D300 / Nikkor 300 f2.8VR @ f2.8, ISO 800. Exposure 120 sec x 54.
Thor
- Sky Watcher ED80 Pro
- Vixen R200SS
- HEQ-5 Pro
- Nikon D200 / D300
- Philips SPC900NC
My SmugMug Gallery
LLEEGE
Running out of Oxygen
Reged: 03/03/05
Loc: Cloud-chester,NY
Re: M45 through 300mm telephoto. new [Re: ThorBob]
      #2102062 - 01/06/08 10:09 PM
Very nice.
"Okay! You draw the straws. I'm-a taking the parachute."
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: M45 through 300mm telephoto. new [Re: LLEEGE]
      #2102083 - 01/06/08 10:22 PM
Superb even I have a Nikon D40x with same lens...mind if I use the same parameters u did and post?...might be an interesting comparison
Orion 80mm ED Apo Refractor
8" Classic Dob (used as Newtonian on CG5 mount)
Meade 70-AZ-A 70mm Guider using PHD
LS60TCaK/B600/C
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC(1/4"ccd)& Quickcam 9000(1/3"CMOS)
Imaging Source DMK 21AU04.AS
- click for cloud prediction for Plymouth, MA. area
s58y
Reged: 12/12/04
Loc: Eastern NY
Re: M45 through 300mm telephoto. new [Re: FoxK]
      #2102239 - 01/06/08 11:37 PM
Very nice wide field image of M45. It looks like the modern Nikon 300mm f/2.8 lens has a lot less CA than the 25-year-old Nikon 300mm f/2.8 lens that I used to use for imaging.
Hutech 30D, SBIG ST-402 autoguider
SV80S, TV102iis
Old camera lenses: 800mm f/5.6, 180mm f/3.4
AP900, Barndoor tracker
http://www.pbase.com/s58y
Tomvictor
Reged: 08/09/04
Loc: N.59.11.47. Norway
Re: M45 through 300mm telephoto. new [Re: s58y]
      #2102474 - 01/07/08 04:07 AM
Nice one Thor, seems like the lens has very good edge performance when looking at the full picture at your web (if un-cropped?).
If you take some flats you will get rid of the uneven field illumination. I use a electroluminescent panel that works just fine.
Tom Victor
http://www.ccd-astrophoto.com/
Takahashi EM-200 - 10" LX200ACF - Artemis 4021M - Mini Borg 60ED - FLI CFW - DSI PRO II. Canon EF200L f/2.8 - 450D - Baader mod. 350D.
Edited by Tomvictor (01/07/08 04:38 AM)
novbabies
Reged: 06/05/05
Loc: Northern Georgia!
Re: M45 through 300mm telephoto. new [Re: Tomvictor]
      #2102505 - 01/07/08 05:04 AM
Thor, that is en excellent wide image - what must the temperature have been ?
Good Seeing!
Mark
Orion 12" XTi f/4.9
VERY old Edmund 6" f/8 reflector
Assorted binoculars
Buzzer
Reged: 07/21/07
Loc: Long Island, NY
Re: M45 through 300mm telephoto. new [Re: novbabies]
      #2103969 - 01/07/08 07:42 PM Attachment (35 downloads)
Thor, If you are using Photoshop, get gradientxterminator, here is what I did to your picture in 2 short processes. You took a very nice shot, Andy
Meade SN-10 Carbon Fiber
TMB 92ss
Mini Borg 50 Guidescope
Celestron CGE Mount
QHY8
Orion Starshoot Autoguider
http://buzzer.zenfolio.com/
"I THINK THE WEATHERMAN NEEDS MORE EXPENSIVE EQUIPMENT"
WANING CRESCENT OBSERVATORY
Dave M
Reged: 08/03/04
Loc: N.E Ohio
Re: M45 through 300mm telephoto. new [Re: Buzzer]
      #2103982 - 01/07/08 07:47 PM
Very! Nice widefield, Thor.. Nice color in the Neb.
Dave
Meade 16" F4.5 EQ Starfinder
Meade 10" SCT / Losmandy G11
Tak FSQ106ED
Canon 20D
SBig ST-4
http://www.spacew.com/gallery/image006006.html
Ps 19:1 The Heavens Declare the Glory of GOD.
tidroplane
Reged: 10/02/06
Loc: Everett, Wa. USA
Re: M45 through 300mm telephoto. new [Re: Dave M]
      #2104004 - 01/07/08 07:54 PM
Beautiful image Thor!!
Clear skies.....David
AT111EDT
AT80EDT-CF
AT66ED
G-11, Gemini
ST2000XCM
FebStars
Reged: 02/02/06
Loc: MA
Re: M45 through 300mm telephoto. new [Re: tidroplane]
      #2104334 - 01/07/08 10:34 PM
Very nice, Thor. You have captured the majesty of the Pleiades!
Tom H
Orion ED80
Celestron 8
Televue Genesis 500mm
Orion EQ-G, LXD75 Mounts
"The cure for boredom is curiousity. There is no cure for curiousity."
ThorBob
Reged: 11/22/06
Re: M45 through 300mm telephoto. new [Re: FebStars]
      #2106923 - 01/09/08 04:38 AM
LLEEGE: Thank you!
FoxK : Thank you, and feel free to post a D40 version, could be interesting to see!
s58y : Thank you! This is my first try at AP with this lens, but for "normal" shooting it quickly became my all-time "long lens" favorite.
Tomvictor : Thank you Tom! Yes it is an uncropped shot, and I really should have made a few flats while I was at it. And those panels seem like a great idea! (specially considering the lack of daylight up here right now...hehe).
novbabies : Thank you! And truth be told, the temp was not bad at all; a couple of degrees above freezing..(strange climate indeed, 200 miles north of the artic circle and not a snowflake on the ground yet..).
Buzzer : Thank you! And I do have gradXterminator, but I have not yet figured the best settings for shots like these (ie: removing gradients without impacting the nebula). But you seemed to have nailed it; any suggestions as to settings?
Dave M : Thank you Dave!
tidroplane : Thank you David!
FebStars : Thank you; it is indeed a beautiful target!
Thor
- Vixen R200SS
- HEQ-5 Pro
- Nikon D200 / D300
- Philips SPC900NC
My SmugMug Gallery
ctcables
Vendor (Reco Labs)
Reged: 11/14/06
Loc: Oregon
      #2106970 - 01/09/08 05:38 AM
Do you have a post of the 40d photo? I have been looking at getting the canon 40d or the nikon D300, plan on using for day shots as well. help advice is great.
Telescope
F4.5
14.6 inch Fused Quartz Mirror strehl .996
18 PT carbonfiber mirror cell
Antearies Quartz secondary
2 strut carbonfiber
Feather Touch focuser
Main scope is 31 lbs
Time to build off and on for a year.
Buzzer
Reged: 07/21/07
Re: M45 through 300mm telephoto. new [Re: ctcables]
      #2111156 - 01/10/08 07:57 PM
Thor, I actually learned how to use it from,http://www.astropix.com/, This is a cd romm tutorial, on how to use photoshop and some plug ins, for Photoshop. I do not know Jerry Lodriguss , and have never met him, but I learned how to use it from this tutorial. I am sure there are explanations on the GradX website also. But buying the cd rom will elevate your shots, it help me tremendously. Andy
TMB 92ss
Celestron CGE Mount
QHY8
Andy Weeks
Reged: 12/12/07
Loc: Batavia, IL
Photoshop Tutorials new [Re: Buzzer]
      #2112170 - 01/11/08 07:27 AM
I agree. His tutorials (although written for PS7) are fantastic.
Photoshop for Astrophotgraphers
Andy in Batavia, IL (Mg 4.5 Skies)
10" SCT w/6.3 FR
Canon XTi (Unmodded for now) & Phillips SPC900 NC Webcam
My Astrophotography Blog
gewehr43
Reged: 07/07/06
Loc: Albuquerque, New Mexico
Re: Photoshop Tutorials new [Re: Andy Weeks]
      #2112535 - 01/11/08 10:56 AM
Very nice image!!
Daniel Z
10" Meade Starfinder on CI700
SV85S Apo on LXD500B
34mm Celestron Axiom
22T4 Nagler
13T6 Nagler
6.7mm Meade UWA
SolidAhmed
Reged: 10/16/06
Loc: Los Angeles
Re: Photoshop Tutorials [Re: gewehr43]
      #2116855 - 01/13/08 06:25 AM
The nebula in this picture is stunning.
Celestron C6-S GT Schmidt-Cassegrain w/XLT
Canon Digital Rebel XTi
F-S 18-55mm f/3.5-5.6 Lens
Vixen 10x50
www.InterstellarArt.com
Nature does not hurry, yet everything is accomplished.
14 registered and 8 anonymous users are browsing this forum.
