Privacy Policy |
Please read our Terms
of Service | Signup and
Dick
Reged: 08/19/06
Loc: Orlando
This was my project over the holidays. Bought an F4.0 Aerial Camera Lens from Surplus Shed just before x-mas for $175. Since I only own long focal length scopes, I felt a good Rich Field would fit nicely in my collection.
Specs appeared pretty good so I went for it. This is a 7 element lens assembly for 4.5 x 4.5 inch film and color corrected from 4900 to 7000 angstroms with 82% light transmission. 5 inch diameter front lens element. Total lens assembly weight is 15 lbs (heavy).
The design of the telescope evolved based on what I had laying around and what was at my local surplus store. One of my aluminum scuba tanks was made with a defective alloy and can no longer be filled. The scuba tank diameter was a perfect fit for the flange of the lens assembly. A 2-speed crayford focuser had to be purchased. I also had an old transmission jack not being used. Some 2" square aluminum supports left over from my fence and some other hardware from the local store completed the design. A local machine shop cut and milled the scuba tank for only $50 (good deal). Used a laser pointer for collimation. A little paint and "Sky Diver" was ready for the first clear night.
The Star test: I will try to summarize the 6+ good night of viewing I have had. I tested using eyepieces ranging from 52mm to 3mm with brands including Nagler, Seibert, Rini, Celestron, Smart Astronomy, and Meade. What amazed me the most was that all eyepieces keeped the flat field from edge-to-edge. I had expected only my Nagler 13mm Type 6 would be able to maintain flatness because of the Fast F4. Not the case. Stars were pinpoints across the complete field for all. Magnifications up to 150x still produced excellent views. (Jewels in the sky).
The Disappointment: This scope will not handle bright objects well. Mars, Sirus, and the Moon produced a significant purple halo around the object. I did expect this to some degree when doing my research. I installed a yellow filter which is commonly used on aerial cameras. The purple halo now turned yellow and was still present. I finally stopped the scope down to a 3" diameter hole using construction paper. The halo went away giving a pretty good view of each object.
Next Test: Will try different filters and try to split some double stars.
Overall, I built this as a rich field scope with no intention of high mag viewing. As a rich field, this is a high quality scope with excellent optics. Bright objects will be viewed with my longer focal length scopes.
Any comments would be appreciated.
-------------------- Dick
6" f22 classic catadioptic (homemade)
5" Nexstar5
4.5" F4 Refractor - Sky Diver
4.5" celestron reflector
3" Goto Refractor
Ptarmigan
Reged: 09/23/04
Loc: Arctic
Looking sharp. Cool telescope project right there. Any plans for astrophotography out of it?
-------------------- Ptarmigans=Cute and Cuddly
Meade Starfinder 8
Nikon 10x50
Rebel XT
John Jarosz
Astro Gearhead
Reged: 04/25/04
Loc: Chicago area, IL
Hi Dick,
Looks good. I love the scissors jack .
A "minus violet" filter will help on the Chromatic Aberration.
You asked for suggestions so here goes: How about replacing the 4 casters with 2 much larger wheels at the front? No wheels at the rear, instead just have posts to support the mount on the ground. To move it, use it like a wheelbarrow. The larger wheels will make it easier to move over bumpy ground and the posts will insure that it stays put when you get to where you're going.
John
-------------------- 6" F4.6(w/Paracorr) GEM reflector, 8" F11 Dall Relay Scope
6" F5 RFT Refractor, Garrett Gemini 20x80 LW
Dick
Reged: 08/19/06
Loc: Orlando
Hi Dick,
John
Thanks for the input John. I have been looking for filters and I am not sure which one to buy. I noticed Baader has several including a semi APO, minus violet, and skyglow. Will consider the minus violet your suggested.
Larger wheels on the scope would help on rough ground. For now, I have built a lazy susan platform which lets the small wheels float. This gives me the RA movement. Attached is a closer view of the scope for any of the other 12 people who bought the remaining lens assemblies at Surplus Shed (all sold in 1 week).
Edited by Dick (01/17/08 09:25 PM)
walt r
Reged: 02/13/07
Loc: Doylestown, PA
Looks great Dick. I sure a lot of us were wondering how well that lens would work as a telescope. Thanks for sharing.
-------------------- Walt
Obsession 18" f/4.45 #1370 AN/SC
MK67 Deluxe 6" f/12 Mak-Cass, Super Polaris GEM, JMI MicroMax DSC
DIY 60mm f/6 Achromat
Cookbook 245 CCD
Dick
Reged: 08/19/06
Loc: Orlando
I have been thinking about Astrophotography. My twin brother has been capturing / processing images for many years now. I am amazed how good images can be even on smaller 8" scopes. I will have to search for a good Goto motorized mount that can handle the weight. The OTA weighs 26 lbs without the bearings and pivot pins. Any suggestions on a heavy duty mount?
5" Nexstar5
3" Goto Refractor
fetoma
Reged: 09/26/06
Loc: NW Ohio
Orion Atlas
-------------------- Frank in NW Ohio
Vixen CF VC200L and R200SS
Meade SN-10
Celestron 9.25" and 6" SCT's
Meade 8" f/6.3 SCT
Intes-Micro M73
Stellarvue 80/480 LOMO Triplet
William Optics FLT-110 w/TEC Lens
Starlight Instruments 12.5" RC
Takahashi FS-60C
Celestron CGE
FLI ML8300 w/CFW-2-7
Canon T1i
www.jerseydevilastronomy.com
Dick
Reged: 08/19/06
Loc: Orlando
Orion Atlas
Thanks for the info. At first I was not sure what the meaning was of the words "Orion Atlas". After searching the net I now understand this is a mount that can handle 40-50 lbs. Sounds like a good option when I decide to do imaging.
5" Nexstar5
3" Goto Refractor
13 registered and 7 anonymous users are browsing this forum.
Moderator: Don W, Mike I. Jones
