asteroid7
Reged: 10/19/04
Loc: CT
Orion GoTo Mounts new
      #2138225 - 01/22/08 02:36 PM
I already posted this on the Cloudy Nights Case & Casses Site but I thought I better post it here also.
I am trying to figure out if I can input MY OWN RA and DEC (as opposed to the telescopes data bank).
On my Celestron Goto, all I have to do is go the the RA & DEC mode and enter the coordinates and the telescope slews
to the object of my desire. Can this be done with the Orion GoTos?
I do not use the telescope's databanks very much for I am mainly interested in the thousand or so double stars and hundreds of variable stars that are NOT listed in the telescopes data banks.
Orion's manual isn't the quite clear about this. It says you
can save 25 user objects, but I do not want to save just go
directly to the slewing after I put in the objects coordinates.
Thank you
Rich
Clear Nights "Make My Day"
4.5" f/7 APM (TMB) APO Refractor CG5 GoTo with Orion extension tube
8" Celestron CPC (two)
Eyepieces:
40mm Pentax; 24mm Tele Vue Panoptic, 18mm Tele Vue Radian, 18mm HD Ortho, 15mm Celestron Omini,14mm Pentax,10mm Tele Vue Radian, 7mm,5mm & 3.5mm Nagler; 7.4mm Tele Vue Plossl.
2.5 Tele Vue Powermate
hudson_yak
Reged: 11/15/07
Loc: Hyde Park, NY, USA
Re: Orion GoTo Mounts new [Re: asteroid7]
      #2138666 - 01/22/08 06:06 PM
I also mentioned this in the other thread, but you can go into Utilities + Show Position and just slew the scope with the directional buttons until it displays the correct coordinates.
Meade 8" LX10
TeleVue-85 + Losmandy GM-8 + Berlebach UNI 24
Meade 12" LightBridge
Orion ED100
Orion SVP
Skylook123
Reged: 04/30/05
Loc: Tucson, AZ
Re: Orion GoTo Mounts [Re: hudson_yak]
      #2139354 - 01/22/08 10:37 PM
Yes, you can manually enter RA/DEC values as a User Object. I don't have my HC available, but the instructions are in the user manual for the SynScan. I believe you go to the Calogue menu, select User Objects, and pick a number. If there is no object in that catalog position (you can manually enter up to 25), then it will ask you for the coordinates to enter. If you previously entered an object in that slot, it will ask you if you want to edit it, or goto it.
A Bad Night With A Telescope
Beats A Good Night Doing Anything Else
Teeter 18" Truss Dob/Sky Commander DSCs, "Derrick"
Meade 10" LX-5 SCT/Atlas-G "Ol' Blue Eye"
Orion 90mm refractor,
Meade 10" Starfinder Newt/JMI NGCMax DSCs,
Celestron 10x50 Ultima Pro
10 registered and 13 anonymous users are browsing this forum.
