ProfMMC
Reged: 09/13/07
Loc: London UK
Finally my observatory build has started. Every decision has been made after hours of reading CN and looking at photos. To return the favour I shall bore you with pictures of my build.
I live 5 miles south of the heart of London. Light pollution is my middle name. I am hoping for a 10 fold or more increase in use of my scopes once this project is complete.
I will do as much as I can myself.
I have planned the build as a staged process that gives me maximum flexibility if I change my mind about anything.
Current objective is to build an 8 x 8 roll-off roof wooden observatory.
The base is made out of 4x2 timber, and sits on four brick pillars, one at each corner. I needed to gain a bit of height as I have to view over the shed next door, I wanted a wooden floor (warmer), I think a plug surrounded by earth will be better isolated, and finally and 8x8 6 inch deep screed is a hell of a lot more concrete.
The base is 90% complete. I have left the gap to allow for easy access to the hole for the plug.
-------------------- Orion Optics UK 350mm F4.7 Dob (dismantled)
Celestron 8SE f10, Meade 5000ED 127mm, ETX125 OTA f15
Revelation ED 80mm f6.8, Meade 5000ED 80mm f6
WO ZS66mm f5.9, WO ZS70mm f6
EQ6 Pro, CG5-GT, WO Eazy Touch
DSI I + II QHY6 Pro, Shoestring GPUSB EQMOD
Edited by ProfMMC (03/04/08 03:15 AM)
ProfMMC
Reged: 09/13/07
Loc: London UK
A close up of the hole. The shuttering at the top is 3x3 and the hole extends around 2 foot six down. The ground never freezes in London (we get an inch of snow once a year) so I have concluded that I do not need to go real deep.
Digging the hole was a nigthmare.
I hope I have got this decision right.
ProfMMC
Reged: 09/13/07
Loc: London UK
The shuttering is temporally held a few inches below the base.
ProfMMC
Reged: 09/13/07
Loc: London UK
I drove two 4 foot long lengths of thick reinforcing 3 feet
deeper, and have attacted the first layer of reinforcing.
Edited by ProfMMC (03/03/08 04:37 PM)
ProfMMC
Reged: 09/13/07
Loc: London UK
Three layers of reinforcing:
ProfMMC
Reged: 09/13/07
Loc: London UK
And reinforcing for the pillar:
ProfMMC
Reged: 09/13/07
Loc: London UK
Pillar in place and held upright:
Kaizu
Reged: 08/17/07
Loc: Finland
If you want to be sure that the ground never freeze, you can put styrofoam or some other isolating plates around the pier. The coldness is not bad and the wetness is not bad but together they can distort the pier and one time is enough.
Kaizu
-------------------- Some thoughts are so wise that they don't make me laugh
http://www.kaiforssen.fi
csa/montana
Den Mother
Reged: 05/14/05
Loc: montana
Congratulations on your building of your Observatory! We are never bored with members sharing their building of their observatories! It looks as though you are progressing quite nicely!
Please keep the photos coming, & best of luck with your continuing progress!
Carol
-------------------- Carol
AstroTech 16" Dob (Thanks ASTRONOMICS!)
Vixen 80MF/AstroTech Voyager
Masuyama's 7.5, 15, 25W, 35mm,
Pentaxes; 5XW, 7XL, 10XW.
14mm Meade 4000 UWA
TV Panoptics; 22, 35
DreamCatcher Dobservatory
ProfMMC
Reged: 09/13/07
Loc: London UK
Good to hear that I will not be boring anyone. A view down the pier. It does not look neat, but the reinforcing is there to do a job not look good.
Edited by ProfMMC (03/03/08 05:27 PM)
ProfMMC
Reged: 09/13/07
Loc: London UK
This is my bottom plate. It is going to be held in the pier by 3 18 inch lengths of 10mm threaded rod.
Edited by ProfMMC (03/03/08 05:30 PM)
ProfMMC
Reged: 09/13/07
Loc: London UK
An action shot: marking true north as the sun transits ...
Bowmoreman
Reged: 09/11/06
Loc: Bolton, MA
One thought before tyou get too far along... you probably should put additional concrete supports under the sides at midpoint... 8' span is kinda long; though I don't know the dimensions of your sill joists... If they are 10" or bigger you're probably OK...
Looking good and we LOVE long "boring" threads with lotsa pics, etc!
Clear enough skies
-------------------- Dave
Imaging: MI-250+ADM/SBS/Optec Libra: C11Hyperstar,TMB80SS
Visual: XT10i RTP
EP: 31T5,22T4,17T4,12T4,13Ethos,10XW,8Ethos;2x Powermate,Paracorr, 1.6X Antares, Hyperion8-24Zoom
Cameras: Mallincam Color Hyper Plus, QHY8
Guider: SBIG STV eFinder
Key Add-ons: Gerbings Heated clothes, WilderSkiesObservatory(BYO#90), Speco 9"Monitor
Pedestal
Reged: 03/11/06
Loc: Smoggy Bottom, Baytown,Texas
Looking good, so far. I would suggest you are going to need more support for your floor than just the four corners, though. Hubert
Hubert
www.smoggybottom.org
ProfMMC
Reged: 09/13/07
Loc: London UK
Yes I am going to check the need for further supports after the pier is cast. The base has only been put together now since I can use it to hold up the shuttering and the pier.
The base is just lying loose on the four pillars and can (with a bit of puff) be lifted up to rest against the fence.
Chris Schroeder
Reged: 12/11/04
Loc: N.E. WI Sky Glow
Great job so far, looking good
-------------------- Chris
10" DSH with SC DSC, CPC 800 XLT
M110 Doublet ED, AT 102Achro, ZS80FD 10th Anniv, ZS66SD, PST
CG5-AGT, EZ-Touch, Voyager
POD XL3 http://POD.SchroederCity.com
mikey cee
Reged: 01/18/07
Loc: bellevue ne.
It's hard to tell but is your lumber treated? If not you'd better brush on something! Termites and their little mud tunnels won't have to go far and you won't even be aware of the extent of their damage untilit's too late! Mike
-------------------- 7x35 and 10x50 sears tower binocs, 3" f/10 edmunds reflector, 2.4" f/11.7 manon refractor, 6" f/8 jaegers refractor, "The 8 Ball" 8" f/13.3 brandt refractor, 3" f/15.8 sans&streiffe refractor, 3.1" f/15 selsi refractor(towa 339), 2.4" f/15 sears refractor, selsi 30x30mm spyglass, criterion 5-draw 25x45x75x spyglass(1957), 4.25" f/14.8 tasco 20te.
cnstarz
Reged: 12/22/07
Loc: Kentucky, USA
I love the look of that pier, I've seen where others have a conduit for electrical inside the tube. Are you planning something similar?
-------------------- Matt
Apogee 50mm BB scope
ETX-60 BB
Meade 70-az
5" DIY Newt (wip)
C6-N on CG-4 GEM
Gallery
skybsd
Reged: 02/01/08
Hello, Living just south of you, I'm following your progress with very keen interest!
Although a couple of months into this most addictive of activities, I'm already having the beginnings of my own grand plans of "something a bit more permanent" in my garden, and have even already gotten the go ahead from my local planning office
Looks great! All the best!
skybsd
ProfMMC
Reged: 09/13/07
Loc: London UK
Yes I got treated lumber, and have brought a tin of preservative to paint the ends after sawing. I shall make sure that the timber is only resting on brick - not earth so it should last as long as I need it to.
I am thinking about the conduit, but no final conclusion yet.
skybsd: how far south are you? I find that being in south London means that the view south is better light pollution wise than it would be if you were north of the river.
