Observing >> Solar
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Did I capture my first plume?
      #2246269 - 03/09/08 02:57 PM
DMK: 200 subs stacked in registax
First time I ever used a 7nm H-alpha filter but this is the best I could do. I see others using the same or similar scope and having much better results. And looking at other posts today, I see there is some activity on the Sun that I can't seem to capture. I'm not sure at what exposure I should use...if I have good exposure to capture the roiling surface, is that too little for getting plumes?
I know I don't have a PST but I hope to get some better results...any comments are appreciated.
Orion 80mm ED Apo Refractor
8" Classic Dob (used as Newtonian on CG5 mount)
Meade 70-AZ-A 70mm Guider using PHD
LS60TCaK/B600/C
CG-5 Advanced GT Mount
Nikon D40x with T-Adaptors
Philips SPC900NC(1/4"ccd)& Quickcam 9000(1/3"CMOS)
Imaging Source DMK 21AU04.AS
- click for cloud prediction for Plymouth, MA. area
colinsk
Reged: 01/17/08
Loc: CA
Re: Did I capture my first plume? new [Re: FoxK]
      #2246356 - 03/09/08 03:55 PM
The h-alpha filters you see here are 1 to .2 Angstrom filters. Or around 100 times as narrow as a 7nm. You may indeed have captured a little prom there. Can you tell me the orientation of the image? You can use Tilting Sun to find it.
I just walked in and the proms are fresh in my mind.
Mahalo,
Colin Kaminski
Coulter 10.1" Dobsonian
TV-76/Baader Film White Light
LS60T/DS50/FT/BF1200
LDX-75
AT Voyager
Edited by colinsk (03/09/08 04:16 PM)
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Did I capture my first plume? new [Re: colinsk]
      #2246385 - 03/09/08 04:11 PM
I'm only about 70% sure that N is up here...but I mistakenly put a little tension on the usb cable that may have shifted it a bit. Oh well...it doesn't matter too much...I don't reall yhave the right equipment for solar pix Thanks!
LS60TCaK/B600/C
DesertRat
Reged: 06/18/06
Loc: Valley of the Sun
      #2246422 - 03/09/08 04:30 PM
No. At that bandpass I would expect the Solar disk to be overexposed to the point that even the surrounding space would appear bright enough to hide anything but the brightest prom in history.
Glenn
Brandon 94mm f7, Televue TV102 f8.6; GM8
Baader Wedge & Filters, Coronado SM90/BF30
IM715; C11 & C14; G-11 Gemini
FoxK
Reged: 11/07/07
Loc: Cape Cod, MA
Re: Did I capture my first plume? new [Re: DesertRat]
      #2247451 - 03/10/08 02:10 AM
Ok..thanks!
LS60TCaK/B600/C
7 registered and 12 anonymous users are browsing this forum.
Moderator:  Don W, spaceydee
